04-28-2024, 09:46 PM | #1 |
Rep 865
i4 Not charging, lights and clicks then error
Hi folks. Starting this afternoon my i4 has decided not to charge. I get an error the charger clicks, there are numerous clicks that come from the back of the car but it's not charging on my L2 at home.
When I open the charge port the light is white, I plug in and it turns blue for about half a second then flashes orange. The car tries to reinitialize the charge state several times basically repeating this loop. I'm going to assume it's a problem with my wall charger but I don't know that for sure? Any help would be appreciated.
2023 i4 eDrive40
2022 Acura MDX |
04-28-2024, 11:43 PM | #2 |
Rep 199
Flip the breaker off. Count to 10. Flip the breaker on.
Try another charger. Double check all your software settings to make sure it's not a delayed charge. Take a flashlight and look into the charger and plug to see if there's any debris. Lower the charge limit on the car to 16A and see if the problem continues. |
04-29-2024, 06:45 AM | #3 | |
Rep 865
I’ll try a DC fast charger tonight. Have not lowered the charge limit will try that.
2023 i4 eDrive40
2022 Acura MDX |
04-29-2024, 10:57 AM | #5 |
Rep 865
Honestly I forgot that was even an option.
2023 i4 eDrive40
2022 Acura MDX |
04-29-2024, 11:04 AM | #6 |
Rep 3,071
04-29-2024, 02:15 PM | #7 |
Rep 437
If you can try another car on the same charger and receptacle/breaker that would help eliminate any source outside the vehicle.
In other places of discussion this issue was raised, and it ended up requiring a dealership visit to update the software to the latest version. Or the CCU is bad and needs to be replaced. Either way it doesn’t seem like any of the diy based resets worked. |
04-29-2024, 06:09 PM | #8 | |
Rep 865
2023 i4 eDrive40
2022 Acura MDX |
