08-27-2021, 10:16 AM | #1 |
Rep 263
Drives: BMW G20 330e MSport Xdrive
Strut Brace
Ive done quite a bit of mods on the car since i got it 9 months ago
Ive never spent so much time and money on a car, testament to how much i really love it Ive felt i lacked total confidence in cornering and so ive added a strut brace Instant cure, so much better positive cornering prowess I get its not for everyone but may interest some of you guys
JohnBoySAFC
BMW Msport 330e xdrive 2020 |
08-28-2021, 01:37 AM | #3 |
Rep 263
Youll have to take my word
A marked difference
JohnBoySAFC
08-28-2021, 01:43 AM | #4 |
Rep 8,087
I will take your word, I’m not disputing it - I’m just amazed.
johnboysafc99.00 |
08-28-2021, 02:05 AM | #5 |
King of the North (living in the east...)
1058
Rep 2,158
Me too.
The angles introduced, look like they would flex like a M power badged rubber band.
2021 M340i in mineral white, options galore
Previously 2018 440i GC in MG 2015 330D F30 MSport EBII 2012 Alfa Guilietta 2.0d Veloce 2009 Fiat bravo sport 2000 ST Mondeo |
08-28-2021, 04:44 AM | #7 |
Rep 183
08-28-2021, 07:26 AM | #8 | |
Rep 263
It works believe me or not The mountings are already there so presumably the brace was specifically designed Physics are not, it works for me and thats all that matters Just thought id share
JohnBoySAFC
08-28-2021, 09:11 AM | #9 |
Rep 8,087
And thanks for sharing. Your car looks great and I don’t think anyone was being critical, it just looks like the convoluted angles wouldn’t do much - but if it works, it works.
johnboysafc99.00 |
08-28-2021, 02:31 PM | #11 |
Rep 15,858
Not from the way it is assembled, unless we are seeing it wrong. There is only one countersunk screw each end of the middle connector, so adds virtually nothing to the side to side rigidity. Unlike the boomerang brace which does have structural rigidity in the 'U' form.
08-28-2021, 04:15 PM | #12 | |
Rep 19
The photo below shows the 2nd bolt. Not my car by the way. |
HighlandPete6658.50 |
08-28-2021, 07:30 PM | #13 |
Rep 1,068
i have the burger strut bars , felt a slight difference but the struts will only do so much. on the fence about ordering the h&r sway bars, which would make a bigger difference imo
2020 G20 Twilight Purple M340i xDrive, 2017 F80 30 Jahre, 2011 E92 335i xDrive///M3, 2012 E93 ///M3 -- Retired |
08-28-2021, 11:06 PM | #14 | |
Rep 2,700
I installed the OEM M440i strut braces and did feel a difference, it's like the suspension is doing more work than before when a part of the impacts was absorbed by the chassis.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
08-29-2021, 06:47 AM | #15 | |
Rep 908
08-30-2021, 06:55 AM | #16 |
Rep 15,858
Thought that was the case. The cross bar is still very limited to how it helps, unless welded to the strut parts. It is the two struts that add a bit of rigidity, much like the standard parts fitted to many production models.
08-30-2021, 10:16 AM | #17 |
Rep 1,228
I wonder what fitting parts like these does in the event of a crash? The car is specifically engineered to crumple, to protect both the occupants and any person or vehicle that you collide with.
It’d be interesting to know how such struts affect the Euro NCAP rating, or what the insurance hike is for fitting them. |
08-30-2021, 12:17 PM | #19 | |
Rep 213
08-30-2021, 12:24 PM | #20 |
Rep 388
Some insurers don't have an issue as long as it's reported, their main issue should be Stirling Moss hooning his big heavy G20 into corners like he's racing at Brands Hatch on the way to do his weekly shop at Tesco...😆
06-06-2023, 05:24 PM | #21 |
Rep 16
Drives: 2018 X3 30d M Sport;2021 M340i
Can you please put in a link or name of the supplier for your strut brace.
Oh and further comment the M440 has strut braces as standard equipment so I don't think a design issue they are just the standard round tube with flattened ends though. I have seen article where standard parts numbers are listed to do a G20 order & fit. On the pre LCI the 440 & 340 have the same dimensions. |
06-15-2023, 05:16 PM | #22 | |
Rep 132
I had initially bought the Z4 M40i strut braces with the mind to fix them with nuts and bolts like the BMS/Dinan braces. After seeing that thread I bought 51648491817 "connection upper rear" from the M440i which goes under the slam panel and has nuts welded on so no need to faff around with using/losing a loose nut. |
