11-08-2023, 01:51 AM | #331 |
Rep 51
Hi guys,
I wanted to VO code the correct wheels for my g87. It came with the bicolour wheels but the dealer swapped for the black which I wanted. I’m assuming if I delete and add the wheels in VO they will then show correctly on the ID8 Am I correct this will work Thanks |
12-04-2023, 09:07 AM | #333 |
General
10493
Rep 40,999
Drives: 2018 Alpina B6 650ix GC
If you mean for BimmerUtility, you have to get from Developer's website.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
04-02-2024, 09:43 AM | #335 |
General
10493
Rep 40,999
I am almost positive DKOMBI8 is a Secure Code ECU, meaning it cannot be coded without a backend connection to BMW Server.
04-02-2024, 10:08 AM | #336 |
Rep 7
04-02-2024, 10:19 AM | #337 |
General
10493
Rep 40,999
No. They can't, nor can anyone else, FDL Code a Secure Code ECU. PSdZData does not even contain CAFD files for this ECU.
04-02-2024, 10:39 AM | #338 |
Rep 7
ok... My CAR g20 Lci is id8, I want to coding instrument panel to ms cluster because my car isn't now, I try to coding HU_MGU 3010 M_GMBH but is not work, How can I do? thanks~
04-02-2024, 11:55 AM | #339 |
General
10493
Rep 40,999
No idea. If it requires FDL Coding any Secure Code ECU, you can't do it.
04-03-2024, 06:33 AM | #340 |
Rep 2
License Activation
downloaded the ISTA version 4.36.40 from MEGA. I cannot seem to find the ISTA-D KG.exe file or the keygen folder. I also do not have the ISTA_DAPI.dll file. I therefore cannot go past the register key installation aspect. Can someone please assist?
04-03-2024, 09:22 AM | #342 |
General
10493
Rep 40,999
This Thread is for BimmerUtility as Title indicates, and has absolutely nothing to do with ISTA.
04-18-2024, 11:01 AM | #343 |
Rep 91
I've installed the "NBT EVO ID6 Apple CarPlay Touch Screen" in my 2015 X5 F15 and BimmerCode cannot access it because its not the original state.
Will BimmerUtility be able to do basic coding of the HU, such as adding temperature to the tire pressure display? Last edited by 1004ron; 04-18-2024 at 11:08 AM.. |
04-18-2024, 11:10 AM | #344 |
General
10493
Rep 40,999
Yes.
1004ron26.50 |
04-18-2024, 07:56 PM | #346 |
General
10493
Rep 40,999
It should, although without knowing why update no longer works with BimmerCode, I can't say if BimmerUtility will work.
04-30-2024, 11:59 AM | #347 | |
Rep 35
Maybe because I was trying to do it on my iPad - not sure if it would have anything to do with that vs using Windows, but coding the MSA memory or even coding MSA off didn't change anything. Similar to BC, it says coded successfully but no dice and reverts back to pre-coding values once you exit and re-enter. If I recall correctly BC stopped working and it would not be able to work due to some technical reason per the dev at BC. I haven't yet tried with my computer, but with my (limited) knowledge of networking I don't really know why iOS can't interface with it. |
04-30-2024, 12:02 PM | #348 | |
General
10493
Rep 40,999
Pickle of the Turk65.50 |
05-02-2024, 10:46 AM | #349 |
Rep 16
My car is 2022–01 BMW G31 LCI, istep 11/2021
How ever BU also says it can not find cafd mapping for ACSM5… other modules are ok not all though. How do I fdl code it … Issue is, I FA Decoded pedestrian protection 8TF, now errors about front pressure sensors is gone. But this error pops up instead acsm: Coding data record defective (number of ignition circuit implausible) As if something tells it that there is more ignition pistons (like in belts) |
05-02-2024, 11:52 AM | #350 | |
General
10493
Rep 40,999
