03-08-2021, 02:59 PM | #1 |
Rep 16
Injecting CAFD Fails
So i have updated all modules. Most of them are working besides 1
DSC_VIP_IB4. It has no coding. And when i try to inject/flash coding. It throws this error: Code:
<> Read SVT before TAL execution started. TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. <ExecutionID=2021/03/08-00:18:02.567> <[] prepareTALExecution started [PROGRESS]> <[] prepareTALExecution finished [PROGRESS]> <[] prepareVehicleForCoding started [PROGRESS]> <[] prepareVehicleForCoding finished [PROGRESS]> <[DSC_VIP_IB4 - 39] prepareECUforCoding started [PROGRESS]> <[DSC_VIP_IB4 - 39] prepareECUforCoding finished [PROGRESS]> <[DSC_VIP_IB4 - 39] authenticateECUforCoding started [PROGRESS]> <[DSC_VIP_IB4 - 39] authenticateECUforCoding finished [PROGRESS]> <[DSC_VIP_IB4 - 39 - cafd_00003d78-007_015_005] Transaction type: cdDeploy; Message: TA started [TRANSACTION]> <MCDDiagService<id=62651, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: negative response : securityAccessDenied, link=DSC_VIP_IB4_39_ETHERNET> [DIAGSERVICE]> <[] job failed with negative response error: code: repeat job description: Service WDBI_PLAIN returned a negative response with response code securityAccessDenied; LinkName: DSC_VIP_IB4_39_ETHERNET severity: ERROR [THROWABLE]> <[DSC_VIP_IB4 - 39 - cafd_00003d78-007_015_005] Transaction type: cdDeploy; Message: TA finished [TRANSACTION]> <[DSC_VIP_IB4 - 39] -MessageID is used multiple times, so MessageText may be ambiguous-job failed with negative response error: code: repeat job description: Service WDBI_PLAIN returned a negative response with response code securityAccessDenied; LinkName: DSC_VIP_IB4_39_ETHERNET severity: ERROR [WARN]> <[DSC_VIP_IB4 - 39] - [Exception - DSC_VIP_IB4 - 39] job failed with negative response error: code: repeat job description: Service WDBI_PLAIN returned a negative response with response code securityAccessDenied; LinkName: DSC_VIP_IB4_39_ETHERNET severity: ERROR > <[DSC_VIP_IB4 - 39] prepareECUforCoding started [PROGRESS]> <MCDDiagService<id=230634, job=com.bmw.psdz.jobs.uds.MCD3_PrepareECUforCoding, service=DSC - DiagnosticSessionControl, description=error: negative response : conditionsNotCorrect, link=DSC_VIP_IB4_39_ETHERNET> [DIAGSERVICE]> <[DSC_VIP_IB4 - 39] prepareECUforCoding finished [PROGRESS]> <[DSC_VIP_IB4 - 39] authenticateECUforCoding started [PROGRESS]> <[DSC_VIP_IB4 - 39] ECU Authentication error: seed empty or not available [PROGRESS]> <[] ECU Authentication error: seed empty or not available [THROWABLE]> <[DSC_VIP_IB4 - 39] There was an error during TAL execution, please check the log files. [WARN]> <[DSC_VIP_IB4 - 39] There was an error during TAL execution, please check the log files. [WARN]> <[DSC_VIP_IB4 - 39] - [Exception - DSC_VIP_IB4 - 39] ECU Authentication error: seed empty or not available> <[DSC_VIP_IB4 - 39] finalizeECUCoding started [PROGRESS]> <[DSC_VIP_IB4 - 39] finalizeECUCoding finished [PROGRESS]> <[] There was an error, please check the log files. [WARN]> <[] - [Exception - DSC_VIP_IB4 - 39] ECU Authentication error: seed empty or not available> <[] finalizeVehicleCoding started [PROGRESS]> <[] finalizeVehicleCoding finished [PROGRESS]> <[] finalizeTALExecution started [PROGRESS]> <[] finalizeTALExecution finished [PROGRESS]> <TAL execution finished [TAL_EXECUTION_FINISHED]> TAL-Execution finished with status: "FinishedWithError". TAL execution finished. Duration: "14s". <> Read SVT after TAL execution started. Read SVT after TAL execution finished. Tried multiple esys versions/multiple psdzdata... Nothing seems to work. Anybody has an idea what could cause this? Btw is it possible that esys upgraded my IB3 to an ip 4 (shipping data of car = 07/19). I Vaguely dont remember IB4 being part of the list of modules. Same with Kafas 4 that popped out of nowhere. Do i need to downgrade them by editing the SVT from the ECU? So change KAFAS4-> KAFAS3 And DSC_VIP_IB4 to IB3 as basevariant? Or should it work? OR do i need an FSC code in orde to make it work? I have recent psdzdata and esys if you want to take a look. Sure we can figure something out. Btw car is still driving but thewhole dash lights op |
03-08-2021, 03:39 PM | #2 |
Rep 3,056
I suggest to try downgrading your ECU or try to reflash it once again with different psdzdata.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
03-09-2021, 12:44 AM | #3 | |
Rep 16
Changed btld I have downloaded latest psdzdata and it's extracting but from what it looks like, the crc of the the files seems to match. Do I just read the original ecu, change base version from the Vip unit to ib3 and calculate a new target on that? Got it sorted thanks to @[ifr]. Everything is at is is everything on 11/20 besides vip 07/20. Car needed to be in diagnostics mode, then it flashed eventually. Bringing everything slowly to life Last edited by sadisticpandabear; 03-09-2021 at 06:22 AM.. |
02-09-2024, 05:22 PM | #4 | |
Rep 35
03-16-2024, 12:59 PM | #7 |
Rep 5
Got similar problem on my G11 cant inject cafd
Read SVT before TAL execution started. TAL execution started. <ExecutionID=2024/03/16-17:37:32.110> <[] prepareTALExecution started [PROGRESS]> <[] prepareTALExecution finished [PROGRESS]> <[] createFingerprint failed with exception, using default value 24 03 16 8f 00 01 01 00 00 00 00 00 00 [WARN]> <[] - [Exception] For input string: ""> <[] prepareVehicleForFlash started [PROGRESS]> <[] prepareVehicleForFlash finished [PROGRESS]> <[ICAM3 - 6] prepareECUforFlash started [PROGRESS]> <[ICAM3 - 6] prepareECUforFlash finished [PROGRESS]> <[ICAM3 - 6] authenticateECUforFlash started [PROGRESS]> <[] createFingerprint failed with exception, using default value 24 03 16 8f 00 01 01 00 00 00 00 00 00 [WARN]> <[] - [Exception] For input string: ""> <[ICAM3 - 6] authenticateECUforFlash finished [PROGRESS]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: TA started [TRANSACTION]> <[ICAM3 - 6] performEcuFlash started with protocol UDS [PROGRESS]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: 100% progress on ECUId:ICAM3_0x06 [100% of swfl_00002c17-003_004_005] [TRANSACTION]> <[ICAM3 - 6 - swfl_00002c17-003_004_005] Transaction type: swDeploy; Message: TA finished [TRANSACTION]> <[ICAM3 - 6] finalizeECUFlash started [PROGRESS]> <MCDDiagService<id=43200, job=com.bmw.psdz.jobs.programming.zgw.MCD3_Finaliz eECUFlash, service=RC_CPD - RoutineControl CheckProgrammingDependencies, description=error: positive response with negative content, link=ICAM3_06_ETHERNET_06> [DIAGSERVICE]> <[ICAM3 - 6] finalizeECUFlash error [PROGRESS]> <[] job failed with negative response error: code: the programming dependencies are not correct description: FinalizeECUFlash failed - service RoutineControl CheckProgrammingDependencies delivered incorrectResultError_MasterIO_SlaveNIO; LinkName: ICAM3_06_ETHERNET_06 severity: ERROR [THROWABLE]> <[ICAM3 - 6] There was an error during TAL execution, please check the log files. [WARN]> <[ICAM3 - 6] - [Exception - ICAM3 - 6] job failed with negative response error: code: the programming dependencies are not correct description: FinalizeECUFlash failed - service RoutineControl CheckProgrammingDependencies delivered incorrectResultError_MasterIO_SlaveNIO; LinkName: ICAM3_06_ETHERNET_06 severity: ERROR > <[] finalizeVehicleFlash started [PROGRESS]> <[] finalizeVehicleFlash finished [PROGRESS]> <[] prepareVehicleForCoding started [PROGRESS]> <[] prepareVehicleForCoding finished [PROGRESS]> <[] finalizeVehicleCoding started [PROGRESS]> <[] finalizeVehicleCoding finished [PROGRESS]> <[] finalizeTALExecution started [PROGRESS]> <[] finalizeTALExecution finished [PROGRESS]> <TAL execution finished [TAL_EXECUTION_FINISHED]> TAL-Execution finished with status: "FinishedWithError". TAL execution finished. Duration: "1min 58s". <> Read SVT after TAL execution started. Read SVT after TAL execution finished. |
03-16-2024, 01:16 PM | #8 | |
Rep 35
03-18-2024, 10:04 AM | #10 | |
Rep 16
(e-sys should check for that). My problem originally was cause car kicked me out of diagnostic mode while flashing. No idea why, had to enable diagnostic mode right before flashing |
03-18-2024, 12:44 PM | #11 |
Rep 35
03-30-2024, 10:46 AM | #13 |
Rep 5
ICAM3 [6]
BTLD_00002C15_004_008_006 CAFD_00002081_003_118_001 HWEL_0000207D_004_004_001 SWFL_00002C16_022_001_001 SWFL_00002C18_021_003_001 SWFL_00002F16_001_003_003 SWFL_0000333D_001_003_001 UNKN_FFFFFFFF_255_255_255 After trying flash swfl always jumping in same Cafd UNKN_FFFFFFFF_255_255_255 I dont know how to sorted out BTLD_00002C15_004_008_006 CAFD_FFFFFFFF_255_255_255 HWEL_0000207D_004_004_001 SWFL_00002C16_022_001_001 SWFL_00002C18_021_003_001 SWFL_00002F16_001_003_003 SWFL_0000333D_001_003_001 UNKN_FFFFFFFF_255_255_255 description: FinalizeECUFlash failed - service RoutineControl CheckProgrammingDependencies delivered incorrectResultError_MasterIO_SlaveNIO; LinkName: ICAM3_06_ETHERNET_06 Can anyone tell me which Depencies I need it to check |
04-09-2024, 11:35 AM | #14 |
Rep 5
ICAM3 [6]
BTLD_00002C15_004_008_006 CAFD_00002081_003_118_001 HWEL_0000207D_004_004_001 SWFL_00002C16_022_001_001 SWFL_00002C18_021_003_001 SWFL_00002F16_001_003_003 SWFL_0000333D_001_003_001 UNKN_FFFFFFFF_255_255_255 BMW G11 After trying flash swfl always jumping in same Cafd UNKN_FFFFFFFF_255_255_255 I dont know how to sorted out BTLD_00002C15_004_008_006 CAFD_FFFFFFFF_255_255_255 HWEL_0000207D_004_004_001 SWFL_00002C16_022_001_001 SWFL_00002C18_021_003_001 SWFL_00002F16_001_003_003 SWFL_0000333D_001_003_001 UNKN_FFFFFFFF_255_255_255 description: FinalizeECUFlash failed - service RoutineControl CheckProgrammingDependencies delivered incorrectResultError_MasterIO_SlaveNIO; LinkName: ICAM3_06_ETHERNET_06 Can anyone tell me which Depencies I need it to check |
04-15-2024, 08:55 PM | #15 |
Rep 4
I'm not sure, but I've tried everything. Maybe someone else has experienced the same issue. https://enginetechpro.com/
