07-13-2022, 09:44 AM | #1 |
Rep 57
M performance side skirts
I have some genuine side skirts to fit, I plan to do this with 3M tape and some self tapping screws.
Can anybody recommend some suitable fixings? Do people also use any other adhesive such as the betalink? |
07-13-2022, 11:21 AM | #2 |
Rep 256
I have the m performance kit and I have installed 2 of them on my own cars. I personally wouldn't use self tapping screws as you will have to drill into the underside of the car to make the holes.
I used 3m automotive tape and tiger seal. It's been on for nearly a year and still rock solid. Use the 3m tape on the underside. If you used it on the outside then the sill wouldn't be flush with the car due to the thickness of the tape. Use the tiger seal for the side. |
07-13-2022, 11:26 AM | #3 |
Rep 15
I work for 3M - the tape provide in the kit will be spot on, no need to drill holes - unless you want to...clean both surfaces first to be sure is clean and apply good pressure after bonding...
07-13-2022, 12:16 PM | #4 | |
Rep 62
07-13-2022, 01:08 PM | #6 | |
Rep 57
I was going to order some VHB tape |
07-13-2022, 01:11 PM | #7 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
There is no tape provided and there will be a gap if a sealant isn’t used. They aren’t the easiest to fit at all due to the contours involved.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
07-13-2022, 02:09 PM | #9 |
Rep 256
Use the same process here as I mentioned. However you will need help to get it aligned. I also bought 'C' clamps from screwfix to hold the sides in whilst it bonds, the larger black bit at the side of the bumper.
07-13-2022, 02:11 PM | #10 |
Rep 256
That's a poor job by BMW. They shouldn't have used tape at that part of the side sill, as the tape is thicker than the inside bit of the sill, so it won't be flush. I used tiger seal at this area and its flush and holds tight.
I have used a combination of 3m tape and tiger seal and it's pefect. Even the factory boot lip is held down with tape. So in certain parts it tape will do its job. |
07-13-2022, 02:19 PM | #12 | |
Rep 560
07-14-2022, 07:34 AM | #14 | |
Rep 560
I bought the complete kit and it came with a box of tape, clips, beta link all sorts. I just gave to BMW to fit and had no idea where each product is used But as others have said, don't tape the sides on as the tape will cause the sides not sit 100% flush and in my case even started to come apart. |
07-14-2022, 10:30 AM | #15 | |
Rep 256
I would say its not permanent but gives a strong bond. |
Tags |
side skirt |
