03-09-2020, 12:12 AM | #1 |
Rep 40
TPMS Retrofit Possible Issues G20
HI all,
Unfortunately, most AU cars don't come with the TPMS RDC, but with the simpler RPA. For my old F31 330i, I simply bought the wheel senders, had them fitted, recoded my car (thanks to others having done the same) and all was good, pressure and temp at all 4 wheels. Got a brand new G20 M340i and same setup again, no real TPMS. Bought some senders from eBay, cheaper instead of genuine though. The part# didn't match realOEM, but the vendor said they were compatible.... with Fxx and G20... This time had to VO code the 2VB (And code every ECU), as couldn't find the individual codes, or affected ECU list anywhere. Unfortunately, all I get is RDC failure, so I'm hoping its the sender units not compatible, and not something else (additional hardware maybe) needed for the car. Anyway, I've ordered some more of the more genuine type, and will have to pay again to get them fitted, to see if this solves the issue. If anyone has any thoughts or ideas to assist it would be greatly appreciated. In the meantime, I'll try to compare the CAF's from before and after to narrow down the effected ECU list so can better share the how-tos for those who follow. |
03-23-2020, 12:18 AM | #2 |
Rep 40
Solved
Solved the problem.
Got rid of the cheap "compatible" version and installed the BMW version. Installed, reset, everything working as expected/ |
08-23-2020, 11:17 AM | #3 | |
Rep 3
Thanks in advance mate. |
08-23-2020, 06:23 PM | #4 |
Rep 40
The simplest is to VO Code 2VB (ESys or equiv) then recode DSC_BRS, HU_MGU, KAFAS4, RAM, DKOMBI, DBC_BODY3 (all all ECUs)
Alternately, for all the individuals, I found the codes matching the F30/F20 Retrofit from https://f30.bimmerpost.com/forums/sh....php?t=1104376 But the ECUs names are different and from the list above. slower process, but also possible. If you do the VO code, then software updates keep the changes and you don't have to recode after updates. Hope that helps |
07-31-2022, 01:21 AM | #5 |
Rep 28
Hi kabongSteve,
Sorry to resurrect an old thread but I thought it would be good to see if I could get your help done in in Aus too. I've just got my M340i but it has no proper TPMS unfortunately. I'm thinking of buying the sensors and coding with Bimmercode. I just wanted to check if you needed any additional hardware or control modules? Thanks in advance. |
08-03-2022, 09:48 PM | #6 | |
Rep 63
Cheers |
08-04-2022, 07:32 AM | #7 | |
Rep 28
Will Bimmerutility be able to do this? I'm a BMW noob and still trying to work out the difference between the coding programs. |
08-09-2022, 06:23 PM | #8 |
Rep 63
[QUOTE=Wackjam;29183925]Thanks for the help.
Will Bimmerutility be able to do this? I'm a BMW noob and still trying to work out the difference between the coding programs.[/QUOTE Bimmer utility is based on esys, so you shiuld be able to do it. |
08-13-2022, 07:25 PM | #11 | |
Rep 63
Your car probably have an indirect TPMS where it uses ABS sensor to detect change in wheel roatation per a certain distance. Direct TPMS requires pressure/temperature sensor in each wheel to send the data to car ECU which in turn you get an actual pressure reading and faster response when there is a leak. |
07-12-2023, 09:52 PM | #13 | |
Rep 457
So to install these do you need to remove the tires, install them and then reinstall and re-balance the tires? Or is it simpler than that? |
07-12-2023, 09:54 PM | #14 | |
Rep 457
07-14-2023, 06:32 PM | #15 | |
Rep 63
You need esys to add FA "2VB" then code DSC, BDC, Kombi, Headunit. Bimmercode can be used to code temperture if it is not auto code with esys FA code. |
11-14-2023, 11:17 AM | #16 | |
Rep 9
1. Purchase the necessary equipment: You’ll need to buy the TPMS sensors. Make sure to get the BMW version, as some cheaper “compatible” versions may not work. 2. Install the sensors: The TPMS sensors should be installed on your vehicle. They are usually shipped in a “sleep mode” to save battery life. After installing and inflating the tire to the proper pressure, wait a minimum of four minutes to sync the new sensor to the vehicle2. 3. Code the vehicle: The simplest way to code the vehicle is to VO Code 2VB (ESys or equivalent) then recode DSC_BRS, HU_MGU, KAFAS4, RAM, DKOMBI, DBC_BODY3 (all all ECUs). Open the FAList file: In the “Expert Mode”, choose “FA-Editor” then open the FAList file. You can find the “FAList” folder on the left and expand it until you see the “SALAPA-element” folder. Edit the FAList: You will see many codes which respectively mean the values of the function into the vehicle options. Now you can delete or add FA from the bottom left window. Apply changes: After making the necessary changes, click the apply changes icon and click the save button1 to save your changes. Upload the new FAList to your car: In this step, you need to upload a list of vehicle options stored in your computer to your car1. Choose “VCM” below “Expert Mode” menu and open the FAList file. Verify the new FA: The new FA must be verified before it can be written to the car. So right click on the FA folder and choose "calculate FP". FP is a vehicle profile. Expand the SALAPA-Element folder and check the option codes you entered are correct or not. 4. Reset the TPMS system: The low tire pressure warning may still display until the TPMS system is reset through iDrive or the BC button on the turn signal stalk. |
11-15-2023, 01:54 AM | #17 |
Rep 2,047
You can just code the modules using the modified fa without writing to VCM. But the steps look fine but they are for modifying fa.
Load modified FA in coding tab. read ECU. select the modules and code them |
12-02-2023, 10:54 AM | #18 |
Rep 9
After some research with few sources, confusing me on the VO code.
May I know which one below correct? Something not understand why DSC2? how it relete to Tire pressure and What is RAM? 1. VO code BDC_Body (Body Domain Controller) ,DSC2 (Dynamic Stability Control), HU_NBT (Next Big Thing head unit),DKOMBI (Instrument clustry displays) 2. VO code - DSC_BRS (part of Dynamic Stability Control), HU_MGU (Media Graphic Unit), KAFAS04 (CAMERA-BASED DRIVER ASSISTANCE SYSTEMS), RAM, DKOMBI (Instrument clustry displays), BDC_BODY3 (variant of BDC) 3. VO code - DSC (Dynamic Stability Control), BDC (Body Domain Controller), HU-MGU (Media Graphic Unit), DKombi(Instrument clustry displays) |
12-02-2023, 11:56 AM | #19 |
Rep 2,047
1 and 2 are the same thing it only the names are different but modules are same.
DSC is needed incase you want FTM which uses speed sensors to calculate wheel radius to figure out if the tyre is deflated. |
12-10-2023, 03:30 AM | #20 |
Rep 9
Thanks Nine90 for the feedback
New learner here, what should I do for the cafd file not found for BDC_BODY3 module. Thanks. Last edited by jayfam67; 12-10-2023 at 10:22 AM.. |
Tags |
g20, rdc, tpms |
