2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums AUSTRALIA BMW Drive Recorder - has anyone optioned this?
      01-28-2020, 05:54 PM   #23
DrMilan
Drives: G01 30i, G20 330i, G05 40i
so guys, just making sure do you need to get driver recorder when you order the vehicle in Australia, or can i just add it later through the BMW website??
im going for the 330i with visibility pack
      01-28-2020, 06:14 PM   #24
Slideit
Slideit's Avatar
49
Drives: BMW 330e
I asked a dealer about this, and they said it's "better" to do it as part of the build, though obviously you can get it later yourself.
Not sure why. I guess they have a bigger invoice to show if you buy it through them at order time ?
But I suppose if you get it as part of the build, the assumption is it will be working when you pick up your car, as opposed if you buy it later and it doesn't work for some reason, you have to take it in for a check.
      01-28-2020, 09:54 PM   #25
yaholez
Drives: 2019 G20 330i
Don't forget if you add it to your build you pay LCT on it, while if you add it on later you don't.
      01-28-2020, 10:16 PM   #26
Slideit
Slideit's Avatar
49
Drives: BMW 330e
True. I didn't seek clarification at the time, but I was told it works out the same on cost. So unless that's a lie (possible!) they might charge different amounts as a build option vs adding through the Connected app store.
      01-30-2020, 12:04 AM   #27
bcoz
spectator
bcoz's Avatar
Drives: 330d Sedan
Only if total list price (ex on roads) is > $75,526 (for Fuel Efficient cars like 330i).
      01-30-2020, 01:29 AM   #28
Sergeant Skinner
Sergeant Skinner's Avatar
166
Drives: 2020 BMW M340i XDrive
Yaholez is spot on.
I foolishly spec'd it for my M340i during the build phase and paid LCT and Stamp Duty on it. No one knew and this was before it was available on the ConnectedDrive store so I feel slightly less bad
      01-30-2020, 02:15 AM   #29
Slideit
Slideit's Avatar
49
Drives: BMW 330e
Originally Posted by PBJ View Post
Yaholez is spot on.
I just looked at the App Store, it says $429 for unlimited. Any idea how much it cost you as part of the main purchase?
      01-30-2020, 03:45 AM   #30
bcoz
spectator
bcoz's Avatar
Drives: 330d Sedan
BMW Drive Recorder (code 6DR) is $273 ex GST/LCT.
So cost will be $300 inc GST (for Fuel Efficient <= $75,526), else $390 inc GST+LCT (+ stamp duty where applicable).
Slideit49.00
      01-30-2020, 07:50 AM   #31
Sergeant Skinner
166
Oh yeah looks like it was only $273 so I guess it's still a bit cheaper selecting it when ordering the car!
Now I feel way better haha!
      01-30-2020, 07:22 PM   #32
Slideit
Slideit's Avatar
49
Drives: BMW 330e
I had a feeling they weren’t going to have it cheaper to buy later
I’d be interested to hear if anyone has had the unfortunate experience of it recording because of an incident, to see if it works as advertised.
      02-02-2020, 08:24 PM   #33
DrMilan
i was at the dealer today and he confirms its cheaper to include it in the build.
      02-03-2020, 02:24 AM   #34
Slideit
Slideit's Avatar
49
Drives: BMW 330e
This is good to know!
      04-16-2020, 07:44 AM   #35
NoSUV4Me
NoSUV4Me's Avatar
61
Drives: G20 330i M Sport
Has anyone had trouble activating drive recorder after purchasing from the portal?
It hasn't appeared in the Apps List, and when a manual update/refresh is requested (via option button) it fails to do anything....grumble.
      05-06-2020, 04:37 PM   #36
NoSUV4Me
NoSUV4Me's Avatar
61
Now that it's working....memory fills up fast!
That 20G hard drive- surely is not just for music ??
I've had about 10 x30 sec drives recorded and said memory already full.
Anyone else come across this or a workaround (apart from constantly exporting to USB)
      05-07-2020, 12:40 AM   #37
Slideit
Slideit's Avatar
49
Drives: BMW 330e
I read the manual and nothing amazing was revealed.
Did you try an export one of the files and determine the size on a PC? Are the 30s files around 2GB?!!
      05-07-2020, 06:43 AM   #38
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
On my ‘drive recorder’ widget in iDrive is shows as 3/10 recordings. So maybe 10 is a coded max?
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      05-07-2020, 07:19 PM   #39
Slideit
Slideit's Avatar
49
Drives: BMW 330e
That's interesting. I'll have to dig into mine once I get my car.
      05-08-2020, 01:16 AM   #40
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
Yes, that’s correct.
Max 10 recordings before you have to delete some.
      05-08-2020, 01:31 AM   #41
Slideit
Slideit's Avatar
49
Drives: BMW 330e
I bet soon you'll be able to buy an "upgrade" where they change the parameter from 10 to 100 for only $99.95.
      05-15-2020, 11:56 PM   #42
TikiTourer
Old Member
TikiTourer's Avatar
New Zealand
65
Drives: M340i, Mineral White
2020 BMW M340i  [0.00]
2013 125i  [0.00]
I purchased it from the drive store today for my M340i , and the app appeared in my car apps within 5 minutes. I don't think it downloads the feature as such; its probably already there and when you buy it, an activation is sent to the car.
It's easy to configure and you can set it to automatic to start anything up to 20 secs before a prang and 20 seconds after. Hopefully never needed.
Or you can activate it manually by a long press on the camera button by the gear shift.
I've tried it a couple of times and it works fine.
I resisted the urge to order it until my in car software was stable; it was upgraded to 03/2020/44 last week and everything works really well now.
oh, and after I bought it, my Phone Drivers Guide App was updated to include instructions on how to use Drive Recorder. I'm a bit surprised that that happened!
      05-16-2020, 12:19 AM   #43
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
This is really good news to know that the software side of these cars is now pretty stable. I have always been somewhat reluctant to buy a new model until some of the bugs had been ironed out....hence my purchase this year of a model that had already been Beta tested overseas for a year or so.
      05-16-2020, 02:23 AM   #44
GeniusAdam
BMW Genius
Ukraine
116
Drives: BMW
Originally Posted by Randall View Post
It’s only available with 360 cams ?
Yes.
