Technical Topics Wheels and Tires M340i 791m wheel/tire
      10-03-2019, 07:58 AM   #1
iPetey
iPetey's Avatar
69
Drives: 2020 BMW M340i xDrive
2020 BMW M340i  [0.00]
Hi all,
Currently i have 19x8 791M with 225/40/19. I've been reading that it might not be the best setup for the m340i. I have an interest in the 795M FERRIC GREY(which tire/size would be best?), however my primary question is how much are my 791M's worth? They have 2000 miles on them and the michelin RFT.
      10-03-2019, 12:18 PM   #2
amrh
Drives: 2023 M3Cx
Originally Posted by iPetey View Post
Hi all,
Currently i have 16x8 791M with 225/40/19. I've been reading that it might not be the best setup for the m340i. I have an interest in the 795M FERRIC GREY(which tire/size would be best?), however my primary question is how much are my 791M's worth? They have 2000 miles on them and the michelin RFT.
If you're in NJ, you may want to consider keeping the 791m wheels for winter use. I got 791m wheels, on my m340i, that have all-season tires, and have decided to keep them as my winter set.
As for the 795m wheels (I'm also wanting to get a set for summer), I believe they only come in 20 x 8 and 20 x 8.5, same width and offsets as the 791m wheels. I think the standard tire size would be 225/35 and 255/30. I'm sure you could go a tiny bit wider on tire size.
      10-03-2019, 12:31 PM   #3
iPetey
iPetey's Avatar
69
Yeah, thats a better idea. or i can just get the tires for the summer and slap em on these wheels. However i do really like the 795m wheels as well. Maybe another wheel brand is the way to go for the summer, as the price on those is pretty steep.
      10-03-2019, 01:41 PM   #4
amrh
Drives: 2023 M3Cx
Actually, correction - the 791m wheels that I have are 19 x 8, square. I want to get a wider rear wheel, so will want to go with a summer set.
The 795m wheels are a bit expensive, but I believe they're forged, so they should be light. As well, I like the brushed and matte combination on the spokes. Their only drawback is the offsets, so they would sit the same as the current wheels. I'd likely get spacers, if I got them. Otherwise, get aftermarket wheels with better offsets.
      10-04-2019, 07:12 AM   #5
iPetey
iPetey's Avatar
69
I actually just ordered some spacers. But i'm not sure which setup to go with. I was going to do 15mm in the front and 13mm in the back, but then i figured i should just do 13mm front and back.
      10-04-2019, 07:53 AM   #6
amrh
Drives: 2023 M3Cx
From what I've read on here, from people who have installed spacers, those seem to be the correct sizes. I would put them on - 15mm in the front and 13mm in rear - see how they look. I think it'll look great.
      10-05-2019, 04:47 AM   #7
BMWm340ixC1X
Drives: 08BMW335xia22
Finally another SO M340 .. what interior did you go with ?
      10-05-2019, 09:16 AM   #8
BarryB
BarryB's Avatar
Drives: 30Jahre M5 plus a few more M's
I also have the 8" 791 m with puny 225's
I am doing a test fit on tue with 2 new - 8.5" 791 for the rear with 265 ps4s's and 245 on the stock front rims. This "should" work (with spacers needed possibly)
I could probably get 4 cheap aftermarket rims for the cost of the 2 rears but like keeping the stock look but beefier and no real options avail yet......
Stay tuned........
Current non-BMW's
20 Jeep Grand Cherokee
03 Cooper S (Maxi Tuned 50bhp)
60 Impala (43k orig mi)
15 Turbo S (Kobb tune and Kline exhaust)
      10-05-2019, 04:04 PM   #9
iPetey
iPetey's Avatar
69
haha, they are rare but i really like that.
      10-08-2019, 03:21 PM   #10
wtfbrah
Drives: None
I thought NJ had some of the worst roads. 19 inch wheels in the winter?
      10-08-2019, 03:53 PM   #11
iPetey
iPetey's Avatar
69
Thats a fact, our roads are terrible. However, i been driving slammed cars since 2006. So having this stock height m340i, is actually a pleasure. I also don't drive my car during the week really, so it helps.
Spacers 15mm front / 13mm back:
      10-08-2019, 04:03 PM   #12
wtfbrah
Drives: None
I didn't mean in terms of comfort (I find the 19s perfectly stiff), but tire / wheel damage. hitting a pothole with 19s on RFT sounds terrible. have you had any tire issues in your cars? ever run tires with this little sidewall before?
PS the spacers look great
      10-12-2019, 11:53 PM   #13
kohlzor
Drives: 2017 M240xi
I want to do the same! Where did you find the 8.5 791m? I am looking for 2 Jet black.
Stay tuned........
      10-13-2019, 07:54 AM   #14
BarryB
BarryB's Avatar
Stay tuned........
Yes installed fits great but having dsc issues
Current non-BMW's
      10-13-2019, 08:56 AM   #15
Wmzorba09
Drives: Bmw M340 2020
Stay tuned........
Same....looking for 2 of the same
      10-18-2019, 04:09 PM   #16
Wmzorba09
Looking at replacing my Current setup square 225/40/19 on 19x18 front and rear with:
8/32 rear tires 265/35/19
9/32 front tires 245/35/19
Replacement rims are: 19x9 front, 19x10 rear
Also what about bolt pattern alignment? Are they the same? Wheels I'm looking at are M 437 off a 2018 M2.
Any issues? Thx.
      10-19-2019, 08:21 AM   #17
BarryB
BarryB's Avatar
Any issues? Thx.
I think it has a different bolt pattern.....
Current non-BMW's
      11-22-2019, 09:32 PM   #18
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
Hi all,
My car also came with the same wheel/tires.
I ordered two 19x8.5 791M rear wheels today, and plan to put on 255/35/19 Pirelli Cinturatos to match the ones in the front, for a staggered setup.
      11-25-2019, 01:51 PM   #19
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
Decided to go with Michelin A/S 3+ instead of just changing the rear tires.
      11-25-2019, 02:43 PM   #20
BarryB
BarryB's Avatar
Stay tuned........
FYI I got mine from bmw with a small discount (bmw cca)
Zero issues with the 265/35's in the rear.
Current non-BMW's
      12-13-2019, 08:17 PM   #21
Gdiddy23
2015 BMW F30  [0.00]
Any issues? Thx.
Bolt pattern is 5x112 on G20. The previous gens typically run 5x120 so doubt it will work. I found this problem out first hand from my previous set of AG rims I have for my 335i.
2020 M340xi PB (sold)
2020 Ram 1500 Laramie (Daily)
2019 Shelby GT350R (Weekend)
      12-16-2020, 12:04 AM   #22
50M
50M's Avatar
Drives: m3
Hey man,
Debating 245s up front. Re: the DSC issues, any chance you could share what happened. Would really appreciate the insight/help!
Cheers.
