07-24-2019, 04:02 PM | #309 |
Rep 992
07-24-2019, 10:08 PM | #311 | ||||||
BMW Fan
449
Rep 725
The chief engineer says that 1st gear is very steep, and 2-6 are closely bunched together with 7 and 8 being highway gears. There's no skip shift. No GM automatic has ever used that technology. That was only for vehicles with the T-56 and its derivatives. As for the weight distribution, the 991/992 are around 38/62 with mid engined cars like the 720S and 488GTB around 42/58. Moving away from 50/50 isn't a sacrifice and it will be almost impossible for the C8 to come in at a static 30/70. I don't know where you got that rumor. Quote:
The C7 didn't feel like the other cars because it runs a significantly larger front tires than the others, which dulls steering feel. Jason Cammisa had a good article on this recently as he noticed that the GT350 is very hard to keep in a slide because they sacrificed steering power for feel, making it tough to turn the 285s up front quickly. Nothing about the C7's chassis can be drawn from regarding the C8. The C7's snappiness was not evident in the Z51 and GrandSport model but did rear its head in the Z06 and ZR1. The C8's move to a midengine layout should solve that problem. I don't know how you could draw a parallel between the two. The C8 also should provide better steering feel due to its much shorter, more direct linkage to the steering rack, and narrower tires across the range. Quote:
The actual structure itself is very stiff. From MT: Quote:
If you look at the C8 chassis, the size of the center tunnel and the way it ties the chassis structures together should tell you enough. This is also an all aluminum chassis, which something many of its competitors don't feature. These corners you talk about being cut, I'm not seeing them. Quote:
Both cars are designed to be extremely versatile for sports cars. They've been within about 200lbs of each other for about 25 years now and this generation hasn't changed that. Yes, there are engineering compromises that need to be made. The Corvette, especially not a base model, cannot be a hardcore sportscar with the ride of a cement truck. I don't know how much you think $60K 500hp sportscars are supposed to weigh though. Quote:
07-25-2019, 07:39 AM | #313 |
Rep 1,966
From Road and Track....nothing on Fuel Economy that I've seen anywhere yet
Doesn't anyone care about the gas mileage?
Below, we've listed every specification that GM has provided so far regarding the C8 Stingray. ENGINE Type: LT2 6.2L V8 VVT with direct injection and Active Fuel Management (cylinder deactivation) Bore & stroke (in / mm): 4.06 x 3.62 / 103.25 x 92 Block Material: A319-T7 cast aluminum with cast-in iron cylinder liners and nodular main bearing caps Oiling System: Dry sump-type (7.5-qt. capacity); includes oil-spray piston cooling Oil Type: Dexos 2 0W40 synthetic Cylinder Head Material: 319-T7 cast aluminum Combustion Chamber volume: 59cc Compression Ratio: 11.5:1 Valvetrain: Overhead valve, two valves per cylinder; dual-equal variable valve timing. Valve Size (in / mm): 2.13 / 54 hollow (intake) & 1.59 / 40.4 sodium filled (exhaust) Fuel Delivery: Direct injection with Active Fuel Management: Max pressure: 2,175 psi (15 Mpa / 150 bar) Firing Order: 1-8-7-2-6-5-4-3 (all cylinders); 1-7-6-4 (with deactivation) Throttle body: 87mm single bore (electronic) ECU: GM E99 (32-bit processing) Horsepower (hp / kW @ rpm): 495 / 369 @ 6450 rpm (with performance exhaust) Torque (lb.-ft./ Nm @ rpm): 470 / 637 @ 5150 rpm (with performance exhaust) TRANSMISSION & AXLE Type: M1L 8-speed dual clutch (DCT) CHASSIS & SUSPENSION Front Suspension: Short/long arm (SLA) double wishbone, forged aluminum upper and cast aluminum L-shape lower control arms; monotube shock absorbers (46mm /); Magnetic Selective Ride Control 4.0 available on Z51. Adjustable front lift with memory is available Rear Suspension: Short/long arm (SLA) double wishbone, forged aluminum upper and cast aluminum L-shape lower control arms; direct-acting stabilizer bar; monotube shock absorbers (46mm); Magnetic Selective Ride Control 4.0 available with Z51 Steering Type: Bosch/ZF variable-ratio rack-and-pinion with electric power assist; includes Active Steer Stops with available Magnetic Ride Control 4.0 Steering ratio: 15.7:1 Turning Circle: 11.6 m (std.); 11.1 m (with FE4 Magnetic Ride Control) Brake Type: Front and rear E-boost-assisted discs with Brembo four-piston/two-piece front calipers and four-piston/monobloc rear calipers. With Z51: Front and rear E-boost-assisted discs with Brembo four-piston monobloc caliper at front and rear Brake Rotor Size (in / mm): Front: 12.6 x 1.18 (321 x 30) Front: 13.3 x 1.18 (345 x 30) – with Z51 Rear: 13.6 x 1.02 (339 x 26) Rear: 13.8 x 1.06 (350 x 27) – with Z51 Wheel Size: Front: 19-inch x 8.5-inch (w/5 x 120mm bolt pattern) Rear: 20-inch x 11-inch (w/5 x 120mm bolt pattern) Tire Type and Size: Stingray: Michelin Pilot Sport ALS Stingray with Z51: Michelin Pilot Sport 4S Front: 245/35ZR19 Rear: 305/30ZR20 EXTERIOR DIMENSIONS Wheelbase (in. / mm): 107.2 / 2722 Overall Length (in. / mm): 182.3/ 4630 Overall Width (in. / mm): 76.1 / 1934 Overall Height (in. / mm): 48.6 / 1234 Track (in. mm): (front) 64.9 / 1648 (rear) 62.4 / 1586 INTERIOR DIMENSIONS Headroom (in. / mm): 37.9 / 962 Legroom (in. / mm): 42.8 / 1086 Shoulder Room (in. / mm): 54.4 / 1381 Hip Room (in. / mm): 52.0 / 1321 WEIGHTS & CAPACITIES Dry Weight (lb. / kg): 3366 / 1530 Cargo Volume (cu. ft. / L): 12.6 / 356.8 |
07-25-2019, 08:43 AM | #314 |
Rep 1,011
07-25-2019, 08:55 AM | #315 |
Rep 3,030
I am buying a sports car in this price range within 12 months but I just cannot get past the looks, hybrid Ferrari/Camaro .... looks like a Duplo set car.
07-25-2019, 09:16 AM | #316 |
Stop the hate, get a V8
3850
Rep 8,625
Probably similar to C7 if not better. Mine can get 30mpg on the highway pretty regularly; AFM turns off half the cylinders, and 7th gear is like 0.49:1 I think.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
07-25-2019, 10:37 AM | #317 | |
Primo Generalissimo
4661
Rep 4,021
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
07-25-2019, 11:07 AM | #318 |
Rep 1,916
Another plus is that it allows more room for wider wheels. My C6 Z51 has 325/275 tires on wider wheels without having to do a wide body conversion.
"The Constitution was never construed to authorize Congress to infringe the just liberty of the press, or the rights of conscience; or to prevent the people of the United States, who are peaceable citizens, from keeping their own arms.” Samuel Adams |
Rmtt8208.00 |
07-25-2019, 11:42 AM | #320 | |
Rep 1,912
Drives: Here and There
Viffermike1753.00 |
07-25-2019, 12:39 PM | #321 |
Rep 3,466
I think it's fairly challenging to take that engine to "500hp" as well, a bunch of guys on the camaro forums try to do it with some exotic intake manifolds and other mods, pushing a 6.2 to nearly as much power as the bigger engine in the C6 Z06 at 505hp. Due to the small block pushrod configuration which has packaging, weight and CG advantages, you have more difficulties revving up to astronomical RPM levels where more HP would be possible. In this "give and take" reality, this is probably a reliable SAE number that they were able to make with the already decent LT1 basis.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
07-25-2019, 01:05 PM | #322 |
Rep 2,750
I contacted one of the top 3 Corvette dealers in the US and he already has 400 deposits out of 600 allocations for next year. I decided to put my name in line in case I decide to get one when my lease ends next June.
07-25-2019, 01:27 PM | #323 | |
Rep 2,942
Think about what the C8 will be in the next 5-6 years -- and what the C9 could be in, say, 2025. Realize that except for some key revisions (the ditching of leaf-spring use being one), the hardware of the C8 fundamentally differs little from the C7. That will allow Chevy to incrementally develop the Corvette, year by year, to drive consistent sales and keep the car vital in the landscape of both its competition and the automotive industry in general. The more I think about what the C8 is, the more I'm impressed with the thinking behind it and its positioning as basically a Halo car for the masses. I mean, Ford isn't really even building passenger cars anymore, and its comparable Halo car is effectively unobtanium -- and Dodge isn't even in that game anymore now that the Viper is dead and the Hellcat(s) are milking the muscle-car wayback machine niche for all it's worth. What does that say about the direction Chevy wants to go with the C8? Everything, in my mind.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
07-25-2019, 01:29 PM | #324 |
General
17208
Rep 18,697
I really wasn't asking why GM didn't use them for the C8; I understand why they didn't. I was asking if WestRace thought they were a design compromise on previous generations.
07-25-2019, 01:53 PM | #325 | |
Rep 3,616
people think that more tire is always better. in reality its often not the case. Cars like the viper and other front engine sports cars need to run a huge tire up front for grip/lap times... at the expense of steering feel and balance on the limit. my 458 runs a 235 tire up front and a 295 in back. There is almost zero understeer. and the front end darts in way faster than my gtr did with 285s up front. You don't need much tire up front when there is no weight
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
07-25-2019, 05:35 PM | #326 |
Rep 1,358
Drives: 981CS/428/is250/JLU Rubicon
Just got back from seeing the C8 live and in the flesh!
Was supposed to meet a fellow bimmerposter to sell him some tires I posted, but I told him let's just meet at my local Chevy dealership that is having a preview show tonight from 4-8pm of the new C8.... he was all for it of course
Got lucky and was invited to get a sneak peek before the crowds descend upon the place later today.... got to sit in in and take pics and videos and talk to the Chevy reps all about this amazing new Vette. Never been a Vetter guy until I saw this bad boy debut the other day and even more so now that I got to see it in person. The car is a game changer!!! My love for a 981 Cayman is fading fast and now I'm seriously considering selling my pride and joy 92 NSX to get one of these!!! Sales guy told me as of right now there is a $5000 ADM and a lottery for the first allotments Z51 pkg will be about $8k, but well worth it. Not much other pricing info as of right now but should be ready by early August Unfortunately the car displayed was in my least fav color(Lake Blue) but was still beautiful... the interior is futuristic cockpit style with very nice Nappa leather throughout.... everything is driver focused and at your finger tips If my wife wouldn't kill me I would have put my deposit down right there, that's how sold I am on this car!!! Figure I'll just wait it out and when a couple of my other cars are paid off in a year or two there will gen some good deals on some CPO's. Anybody in the Temecula area should go check it out today!!! 4-8pm. It's gonna be crazy so get there early or maybe show up late would probably be better. I'll try to post more pics and vids later as I'm running short on time right now but here are a few... |
9
IllSic_Design2122.50 Framamind159.50 Red Bread4463.00 NickyC17445.00 irishbimmer1139.00 3798j11350.50 Darth One6612.50 clee1982797.50 Kief4428.00 |
07-25-2019, 05:54 PM | #327 |
Rep 3,535
Drives: 328d Wagon, M2 Comp, i4 eD35
What did you think of the door handles? When I saw how they're slanted (and you have to hit a button underneath to open the door?) it made me wonder about the ergonomics/human factors of it. Looks like it'll be super awkward to try and use your right hand to open the driver's door or left hand for passenger's side.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
07-25-2019, 06:00 PM | #328 | |
Rep 1,358
07-25-2019, 06:37 PM | #329 |
Rep 10,647
Drives: M4 CS. Former G82, x2 F82, F80
Good grief this thing is amazing. Most likely my next car in 2-3 years after the M4 unless something great in a manual comes out for similar pricing (fat chance but I can dream).
I don't even mind giving up my love of individuality for this, because I have to imagine they're going to sell a boat load and we'll see them everywhere. |
07-25-2019, 07:07 PM | #330 | |
Rep 1,916
Rmtt8208.00 |
