12-07-2020, 03:03 PM | #1 |
Rep 256
Recent update, increased fuel consumption?
So I've recently updated my G20 320D to the most recent software download, July update I think. Now I normally get about 530 miles to a full tank and it normally shows a estimated 520 ish miles when full.
Since the update it now shows 470 miles and half a tank got me 200 miles with 220 miles left. I've not changed my driving style. Has anyone else experienced this and is it possible for a software update to make the car less fuel efficient? |
12-07-2020, 04:43 PM | #2 | |
Grumpy Old Git
443
Rep 923
Retired:
12-08-2020, 06:26 AM | #4 |
Rep 15,858
My thinking as well.
~10% drop in mpg (in a diesel) is not unexpected in winter... particularly in Scotland with lower average temperatures. Part of it will be the extra electrical load. Remember the auxiliary electric heater element is power hungry. Will show more on something like a 320d, compared to a 330d. |
12-08-2020, 08:23 AM | #6 | ||
Rep 1,154
12-29-2020, 11:52 AM | #7 |
Rep 47
I updated my 330d xdrive the other day, 420miles range before update, and 300miles range after update. Very odd. Upon brimming the tank after the update I had 430miles range, whereas previously it was showing 530 range
12-29-2020, 01:23 PM | #8 |
Rep 1,154
It's because the update will have wiped your previous driving data no doubt. The range on fill up will show more if you've been averaging a higher MPG before you filled up, and the opposite with lower MPG. That's all it'll be.
01-01-2021, 05:08 AM | #9 |
Rep 256
A great answer, I think this might be it. I just filled up the other day and already it was showing about 15 miles more than my last fill.
01-30-2021, 07:32 PM | #11 |
Rep 256
Update, that's 3 full tanks and averaging 450 miles now, since the update. That's down by about 90 miles before the remote software update, where I averaged about 540 miles.
Driving style hasn't changed. If it possible that the update has somehow increased my full consumption? |
01-31-2021, 03:51 AM | #13 | |
Rep 15,858
If it is OBC, could simply be a software change where the tolerance is different. I had that once on my E91, after a software update/rewrite. The mpg read a different average, (under read by over 5%). Calculated, on brimmed tanks, no difference than before. There was the option to correct it, experimenting with the 'correction factor', but I never bothered. Remember it is colder at the moment, so add that into the mix, as we've mentioned before. |
01-31-2021, 04:58 AM | #14 | |
Rep 213
Last December and January covering 2,584 miles - average 37.86mpg This year November to January (thanks to lockdown) 2,626 miles - average 37.33mpg. I also think it is colder this year and I am doing shorter trips but still only 0.5mpg difference. I am quite happy with overall consumption given the type of car and spec it is. |
01-31-2021, 05:08 AM | #15 |
Grumpy Old Git
443
Rep 923
As stated by others.... diesel cars in cold weather with short journeys see lower mpg than in warmer weather due to longer engine heat up times. I had a diesel 520d (2 cars) over 11 years and lower winter MPG was always the case. I’m sure you will see an improvement as we get into spring/summer.
As others have stated mileage between full (to the top) tank comparisons is the way to get accurate figures.
Retired:
01-31-2021, 06:27 AM | #16 |
Rep 256
Thanks for the advice folks. I always take note of my millage once I fill up from empty and when I refill. From this, I work out how many miles I did on a full tank. That's were I've been getting my rough averages from before the update and now.
Just found it odd that once I installed the update I got lower milliage and quite a bit at that. As you all said, I'll give it to the warmer months and see if there's a difference. |
11-30-2021, 06:48 AM | #17 |
Rep 77
I don't agree with the colder weather reasoning. I updated in the summer. I filled up, made a 150 mile journey and range stated 658 miles, 69.9mpg. Since the update after making that same journey after filling up its now range of 521 miles and mpg has dropped down as well. That was August, when it was nice and warm. Been into the garage who said the update hadn't installed properly. Still doing the same. Also, the range now drops or fluctuates a lot on short trips where it never used to. I can't remember the software it was on before, think it ended .54. But it's a hell of a drop and the only thing that's change is the software.
I can go to the gym, maybe a mile away at most. Loses up to 10 miles in range! |
11-30-2021, 07:19 AM | #18 | |
Rep 15,858
Like previous posts, are you actually calculating the brimmed consumption? Have you previous 'accurate' points of reference? The range figure is a rolling calculation, so it is possible to see the sort of losses you notice on a cold 'mile' trip. How much it drops depends on how much fuel in the tank at the time. Logically (and in reality) nearly full tanks have bigger range variables, than when nearly empty. |
11-30-2021, 07:35 AM | #19 | |
Rep 77
I make the same trip each month and usually when I do I've brimmed the tank before setting off. Before the update, I'd never arrive with a range that didn't start with a 6**. Very occasionally it would be a 5, but more 585+. So I'd have travelled approx 150miles, still with a range of 600+. Totting up the miles covered on those tanks, the stated range + miles covered added up would be within say 10/20 miles of actual miles covered. So I'd say was accurate. I also didn't have the fluctuating, or sharp drop in miles on shorter trips I've been seeing since. |
