01-31-2021, 07:38 AM | #1 |
Rep 16
330e M wheels & suspension
I drive a 330i m sport, and regularly see 330e’s out and about in identical colour and spec, but there appears to be something different when I look at the wheels and arches. Like the wheels are smaller or it’s riding higher. Is the 330e M on standard 18’s, with the usual m-sport suspension setup?
01-31-2021, 07:42 AM | #2 |
Rep 252
The 330e must have the standard se setup as they ride a bit higher. I must be getting old but I do like a slightly softer ride now. The Audi S line and to a lesser extent, the M-sport ride is too crash for today’s pothole ridden roads.
01-31-2021, 07:52 AM | #3 |
Rep 8,081
I think that’s correct, the e uses standard suspension. I’d swap the order of Audi S line and BMW though, M-Sport suspension is firmer in my opinion, my current Audi on S-Line suspension is fairly compliant. I did consider deleting M-Sport suspension on my 330i order but decided to stick with it as I prefer the lower stance.
01-31-2021, 10:51 AM | #4 |
Rep 16
That explains it then, I knew there was something different but couldn’t put my finger on it. The M suspension is definitely firm so if comfort is important then standard is a good choice.
01-31-2021, 11:13 AM | #6 |
Rep 57
I’ve got a 330e M Sport Touring on order. It had to have 19” run flats (company rules - have a spare or have run flats) so I’m happy to hear it doesn’t have the M sport suspension. I was worried it might be a bit harsh.
01-31-2021, 12:20 PM | #7 |
Rep 1,154
Mine is on 19's with run-flats with adaptive M-sport suspension. I'd say the ride is only marginally better than my mates on 18's with the normal M-sport suspension, but it's less crashy over bumps and bad surfaces.
02-01-2021, 05:16 AM | #8 | |
Rep 320
That's how the 330e comes., even in M Sport. I'm not even sure there is an option to have M Sport suspension from factory. There are now a few companies that do lowering springs specific to the 330e.
Arrived: '20 330e M Sport in Mineral Grey
'03 MY 996 Turbo in Arctic Silver Gone: '18 Golf GTI Performance DSG in Tungsten |
02-01-2021, 05:20 AM | #9 | |
Rep 858
The M Sport Pro package comprises 19" light alloy Double-spoke style 791 M wheels, Bicolour Jet Black with run-flat tyres, Adaptive M Suspension, Sun Protection Glass, M Seat Belts, Extended High-gloss Shadowline exterior trim and M Rear Spoiler. ... or is that something different? Not going to even try to pretend I understand BMW's packages fully. The brochure states the following as standard fit on an M Sport: SAFETY & TECHNOLOGY
... however not sure whether to believe anything in the brochure - as that suggests the rear brake lights are "dynamic" from SE upwards, but apparently thats not the case.
For cheaper charging, switch to Octopus Energy using this link and get £50 free credit Last edited by willougs; 02-01-2021 at 05:28 AM.. |
02-01-2021, 12:16 PM | #10 | |
Rep 619
M Sport Vanilla version gets you M Sport suspension which is passive and harder than non-M Sport M Sport Pro Give you Adaptive Suspension (Active and Variable depending on conditions of each wheel) I deleted M Sport Suspension (passive) off my F10 as I prefer a softer ride... I could tell the difference compared to the test car And I added Variable/Adaptive Suspension to my G30 M Sport, and it is great So you are right, the "Pro" Package adds Adaptive Suspension to the G20 (I have added it to mine) M Sport Vanilla suspension also denoted lowered suspension normally, I think on the G20 too... if you have the Adaptive Suspension it is not lowered And last tip if you have "Pro" you don't have to delete M Sport passive suspension, it is effectively replaced by the Adaptive setup My 10c worth
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud Alpine White F10 M Sport - Gone to Stud |
willougs265.00 |
02-01-2021, 01:48 PM | #11 |
Rep 320
Not true for the 330e though. Which is what this thread refers to.
02-01-2021, 03:03 PM | #12 | |
Rep 619
https://g20.bimmerpost.com/forums/al...ictureid=78982
02-01-2021, 03:56 PM | #14 | |
Rep 858
So, the 330e M Sport comes with standard suspension? (more comfort but higher ride height than M Sport Suspension) And the M Sport Pro package upgrades that to Adaptive M suspension?
02-01-2021, 05:47 PM | #16 |
Rep 517
I had the G20 330e Sedan and now I have the G21 330e, and the info in the pictures explain how the M-suspension is set for this car.
In both cars I've had the Adaptive M suspension with 18's and the ride is good in comfort mode. In the G21 is like 30% softer in comfort mode than in the G20 though, much nicer if you ask me. You can always make the suspension stiffer by switching to Sport anyway.
Previous BMWs: 330e Touring xDrive (G21, 2021), 330e (G20, 2019), 530e (G30, 2018). |
willougs265.00 |
02-02-2021, 03:49 AM | #17 | |
Rep 858
02-02-2021, 03:54 AM | #18 |
Rep 8,081
From the brochure - you can download from website as a pdf.
Ian
02-02-2021, 04:19 AM | #19 |
Rep 517
Yes, exactly. Here you have them without needing to fill out a form to get the download link:
Sedan: https://www.bmw.no/content/dam/bmw/m...4324806844.pdf Touring: https://www.bmw.no/content/dam/bmw/m...4328076271.pdf
02-02-2021, 04:37 AM | #20 |
Rep 858
Ah ok, the brochure I have is dated Nov20 downloaded from BMW UK site. The one that I can see that information in seems to reference models not available here.
Combine the two and its a pretty useful resource. Thanks
02-02-2021, 08:38 AM | #22 |
Rep 8,081
Closing by holding lock button on key fob, same as with windows (and powered tailgate on G21)
Jasperistops28.50 |
