Technical Topics Wheels and Tires 19" or 18" wheels? Performance(summer) or all-season?
      06-27-2019, 01:39 AM   #1
deoxys
Drives: 2012 328i Sedan
Hi guys, I'm considering ordering an M340i. It's really hard for me to decide what wheels to choose. What I care most is not their performance on track, instead, I care a lot about ride quality (smooth, comfort, quiet). I only consider RFT.
I know perf/summer tires come with increased top speed limit and are staggered. But how do they compare to all season tires in terms of ride quality and noise?
As far as I know, the tires on M340i are (all rfts):
18" & 19" a/s: Bridgestone Turanza LS 100A; pirelli P7
18" perf: Goodyear F1 Asymmetric 3, Michelin PS4 ZP (not PS4S)
19" perf: Goodyear F1 Asymmetric 3, Bridgestone Turanza T005
Any comments (good or bad) on those tires?
      06-27-2019, 02:43 AM   #2
Ilyam5
Drives: 06 M3
The car looks good with 19 and the ride quality is surprisingly good. Out of all the tires you listed Michelin Ps 4s in by far the best tire . soft, quite ride with best dry and wet grip. It is non run flat so you need a plug kit to deal with flats.
It comes with Cooling pack and gives you mobility kit so you do nOt need a spare so you do not loose trunk space
Summer tire is best for performace in over 40F. But in cold temps, especially under 32 you would loose performance and they are dangerous/ unrideble in the snow
deoxys37.50
      06-27-2019, 10:43 AM   #3
alex2364
alex2364's Avatar
2874
2020 BMW M4  [10.00]
2023 BMW X3 M40i  [10.00]
I would get summer tires just because it's staggered. You won't be able to put any power down especially if you're getting RWD. Why are you getting a M340i if your main concern is ride quality? Sounds like you should get a Lexus.
deoxys37.50
      06-28-2019, 12:41 AM   #4
deoxys
Thanks for the input. Maybe I should consider the cooling pkg, it's $900 more than just 19" tires but the tires seem much better
      06-28-2019, 12:41 AM   #5
deoxys
Would staggered mean more costly to repair/replace?
      06-28-2019, 06:42 AM   #6
Jbrock22
Jbrock22's Avatar
222
Drives: 2pw
BMW   [0.00]
If you go staggered you can't rotate so your tires don't last as long.
      06-28-2019, 06:58 PM   #7
pkancel
pkancel's Avatar
Drives: BMWs
You cant rotate but it also depends on the tire and treadware so get a higher treadware, 300+ and keep the tires inflated at the correct PSI and they will last just fine. Rotating can help but not always the case, tires, alignment, proper air pressure in the tires, etc all factors in longevity.
      07-03-2019, 12:02 PM   #8
TTG
TTG's Avatar
Drives: M340
I am on the same boat. My current configuration is 792M with all season runflats but I am thinking about switching to all season non runflat 18s.
This car will be nothing but a daily driver and I don't want to deal with the harshness of 19's on horrible Seattle roads and invisible pot holes filled with water on dark winter days. I am also assuming tire replacement will be much more cost effective on the 18s as well.
Jury is still out, I might just go buy 18" take offs but then I am tired of storing a set of wheels in my garage.
      07-06-2019, 10:58 AM   #9
deoxys
I definitely understand how bad the roads are in Seattle. I've driven my 2012 328 with 18" Pirelli P7 AS over there and I always complained about road noise. Last time I went to Seattle, I rent a Q70 with 18" Michelin MXM4 non-rft. I would say it was definitely quieter than my 328, but still considered as "noisy".. so I guess when the roads are bad, any tire won't change anything significantly...
I do believe that 18" is more cost efficient, but 18" seems nothing special for a ~60k M performance car
      07-07-2019, 10:27 AM   #10
deoxys
Blank
      07-07-2019, 12:43 PM   #11
WXdrivefun
WXdrivefun's Avatar
Drives: G20 330Xdrive
When I speced my G20 M-Sport 330, I specifically decided on Sport Non-runflats. The Michelins Pilot sport 4S are one of the best summer tires even for daily driving, they are quieter and smoother compared to runflats. Of course it depends on quality of your local roads.
From my past experience with non-BMW vehicles, I had non-runflat sport all seasons tires from Michelin, and they still retain their similar, smooth quite ride performance, still great in dry and wet weather.
For M340i, sport non-runflats would match perfectly.
      07-08-2019, 04:43 PM   #12
TTG
TTG's Avatar
Drives: M340
I am one of those people who actually do not mind RFTs. (only exception is our Mini Cooper S)
But having said that I just changed my order to 18" 790M with all season non RFTs. IMO the 18s look good on this car and it is less of a PIA for me for daily driving. Also, 18s are unique to M340 just like the 792 wheels.
If I want a set of dedicated 19 or 20 summer tires, I might go aftermarket or look for take offs from folks on this forum.
Far a daily / a lease, I am happy 18s and looking fw to a somewhat more comfortable ride.
      07-29-2020, 07:28 PM   #13
3erMan
3erMan's Avatar
Drives: 2021 BMW M340i
Bumping thread to see how everyone feels about their decisions on 18 vs. 19 and RFT vs. non-RFT. Any regrets? I don’t have a strong preference, but I’m not a big fan of the style of the 18” rims. As far as tires go, I’m assuming performance tires are summer only. Correct?
      07-31-2020, 03:06 PM   #14
dillonykyang
Drives: 2020 BMW 330i
18 for comfort!
      09-06-2020, 05:33 PM   #15
deoxys
I went with the 19" all season ones. I don't have any complaints. They are quieter than my old car with 18" wheels but that might just be because the overall better noise control of G20. No regrets at all. I do think 18" ones will be even quieter
      09-06-2020, 05:57 PM   #16
Rocket455
Grumpysaurus Rex
Rocket455's Avatar
Drives: 2022 M550i
1972 Firechicken  [0.00]
1969 Toronado  [0.00]
1970 Camaro  [0.00]
I don't think you're really going to gain that much ride comfort downsizing from 19" to 18" than if you were going from 20" to 19". My car came with the stock 19x8 square setup w/225/40 RTFs, and I recently upgraded to 19x8.5 square w/235/40 Michelin PS4Ss. The ride wasn't bad with the stock set up, but the larger tire size and non-RFT have really made the ride much more comfortable. Running 235/40s on 19x8.5s would already give you more meat on the tires than stock, and I know BarryB is running 245/40s without rubbing on his fronts. The only reason I would ever even consider 18's is if the roads will really, really bad and littered with sharp potholes.
      09-07-2020, 04:48 PM   #17
deoxys
Bumping thread to see how everyone feels about their decisions on 18 vs. 19 and RFT vs. non-RFT. Any regrets? I don't have a strong preference, but I'm not a big fan of the style of the 18" rims. As far as tires go, I'm assuming performance tires are summer only. Correct?
Do the stock rims fit your new 19x8.5 ps4s?
      09-28-2020, 08:46 AM   #18
helmet91
helmet91's Avatar
Netherlands
298
I have staggered 791Ms with summer RFT... I need something to drive in the winter, but NL really doesn't get snow. I'm looking at some 18" BBS XRs with Michelin PS4 A/S for the "winter" here in a square setup in lieu of actual winter wheels.
      09-28-2020, 11:41 AM   #19
TTG
TTG's Avatar
Drives: M340
It has been a year since I have taken delivery of my car with 18" go flats and I am LOVING them. No complaints at all besides the fact that it takes a while to clean them.
Also, over the summer we took a 5K mile road trip to MidWest and knowing the fact that I had a spare tire in the trunk made the whole experience a bit more better!
deoxys37.50
      04-12-2021, 01:49 PM   #20
RIOBLAST
RIOBLAST's Avatar
Sweden
34
Drives: 330xi G21 ELSD
[QUOTE=TTG;26737705]
What tires came with your car?
      04-12-2021, 06:28 PM   #21
Ramsey
Ramsey's Avatar
32
Drives: 2020 M340 xi
2005 545i  [0.00]
2011 335 M Sport  [0.00]
Mine came with the 790 18x7.5 wheel, All season, 225x45 tire. It is driving me absolutely crazy in terms of looks.
I have been looking at my options for a wider tire and wheel.
The $$$ is a concern at this point, otherwise I would have jumped to something better right away.
One question: has anyone tired a wider 18”
Tire, like an 18x9” with a staggered aggressive setup.
The reason I ask is because I think the 18” wheels and tires will be more economical than 19s.
      04-18-2021, 09:14 AM   #22
Jay performance
China
Drives: G20 325
19 for daliy drive, 18 for track days
