11-19-2021, 04:39 PM | #89 | |
Rep 15,858
Had them fitted at our local National Tyres. Manager, a Polish guy, commented as I got them out of the boot, "see you have one of the best winter tyres". He rated them very highly. |
11-20-2021, 12:43 AM | #90 |
Rep 1,220
There’s a German BMW dealer that sells winter wheels via eBay.
I was looking at a package but noticed small print at the end of the listing that said “Not for the 3 Series PHEV”. So there are some very model specific rules, beyond what you see on the online accessories configurator. |
11-20-2021, 01:17 AM | #91 | |
Rep 146
Of course there is, this is BMW we are talking about It seems to me that if you asked them what colour they preferred, black or white, the answer they would give would have you scratching you’re head in confusion This subject about tyres, warranties etc could be put to rest by BMW being open and honest. RFT tyres have been out for a while as have star marked tyres so to still be discussing what as a customer we are allowed is ridiculous. How difficult is it for them to say something along the lines of….if you use anything other than star marked approved tyres then you void warranty….. Not impressed and I don’t even have a car yet. |
11-20-2021, 04:36 AM | #92 | |
Rep 2,176
This probably sounds like pretty harsh criticism but the fact is it’s based on personal experience over many years. I’ve had far better feedback and much more committed interest in past problems from the dealers and if you can establish a good ‘working relationship’ with one that is worth it’s weight in gold almost. ……The thing is I’ve found their products just so damned good over the years I still keep buying them despite the company’s shortcomings! |
11-20-2021, 06:36 AM | #93 | |
Rep 15,858
Getting through to the right person can sometimes help, but there is definitely an arrogance, certainly on initial approach when you challenge their responses. Problem with the written word, they have to cage it, due to liabilities and interpretation. I'm currently in dispute over the T&Cs for the extended warranty. BMW won't answer simple questions, what appears in print is not interpreted that way 'between' all those involved. The warranty department have washed their hands of it, total arrogance. The only way forward is using the Financial Ombudsman for clarification. I've had a similar challenge with Bosch, over a washer/dryer. Had to take the issue to top level (CEO office) as the technical department was so arrogant and contradicted all the written data and the user manual. The specific model (two different machines) had a design/software fault, period. Service engineer replaced parts, performed specific tests which failed, and still the technical department said there was nothing wrong with the machines. Bosch never admitted there were issues, (that would open a can of worms), but offered an upgrade to a different model. Many of the same components, has worked faultlessly as expected. What I have noticed with BMW, they used to be more specific years ago, even on technical points/advice, that is now diluted, often vague. |
11-20-2021, 06:45 AM | #94 | |
Rep 5,681
Providing the correct size, speed rating and load rating has been fitted I can't see how non-star marked tyres could cause a component failure on a RWD car and even with X-drive the only excuse would be the manufacturing tolerance isn't tight enough and that could cause differences in rolling circumference that the system can't cope with. However, we've seen the post regarding EU legislation on tyre tolerances so I can't see BMW wanting to go down that route (plus of course it would potentially prompt some uncomfortable questions about the design of their 4WD system if it can't cope with tyres made by premium tyre manufacturers). So personally I'll do what I've always done when replacing tyres which is to look at what I want from the tyre and then use independent reviews to point me in the direction of which one is likely to be best suited to my needs. If the solution is star marked then fine but if it's not that's also fine as far as I'm concerned; I will however make sure the set conforms to BMW's specification for my car in terms of size, speed rating and load rating. |
bmnut813.50 |
11-20-2021, 08:43 AM | #95 |
Rep 326
5 pages of this now and has anyone any evidence of warranty claims being refused based on non star marked tyres being used?
The manual clearly states 'recommended' tyres. Been a BMW owner for nigh on 20 years and never once had a warranty claimed refused and I have never purchased and probably never will, a star marked tyre.
bmnut813.50 |
11-20-2021, 09:40 AM | #96 | |
Rep 5,681
I've been in the BMW ownership camp for almost as long as you and my experience is the same as yours; I've never fitted star marked tyres come replacement time and have never had a warranty claim refused (including one which related to the drivetrain on an X-drive car which is where the use of non-star marked tyres is most likely to be an issue). |
11-20-2021, 11:13 AM | #97 | ||
Rep 15,858
Here's a post on this forum... True or not... who knows. Quote:
11-20-2021, 11:42 AM | #98 |
Rep 922
I do note on the My BMW App, the tyres bit lists:
Manufacturer Model Size Season BMW Star marked type Quite how the app knows I do not know. Suspect it doesn't not least as 3 are saying correctly, and the 4th has no details and says "no" to Star Marked (when it is), but I will find out next week when the Cros Climate go on. Happy to be Guinea pig.
11-20-2021, 01:06 PM | #99 | |
Rep 5,681
And if we're talking about suspension components also potentially falling foul of this I had both the rear springs on my E46 M3 replaced under extended warranty even though by that time the car was on Vredestein Ultrac Sessantas rather than the original equipment Michelin Pilot Sports. This would have been about 11 or 12 years ago now and I can't honestly remember whether star marking had been introduced back then; however, the Vredesteins certainly weren't a BMW approved tyre but it didn't cause any problems whatsoever with the warranty claim. A lot of the stories I've seen about warranties being invalid have related to X5's and X3's so I wonder if this was more a thing with vehicles that had the earlier versions of the X-Drive system? |
11-20-2021, 01:37 PM | #100 | |
Rep 15,858
I'm also aware of users having work under warranty with different tyres, aftermarket suspension parts, etc. Been there myself, so not in anyway saying a non star marked tyre automatically invalidates warranty work. In fact when I had new front springs under the extended warranty, both occasions I was on my Vredestein tyres and Koni FSD dampers fitted.
The difference these days, most dealers (and BMW UK) have experience and know "where to start" with typical xDrive transmission issues. My posts, comments, reasoning, is for users to make a choice with "eyes wide open". |
11-20-2021, 02:01 PM | #101 | |
Rep 146
We would all know where we stand then Thanks to everyone for chipping in though, great forum |
11-20-2021, 03:39 PM | #102 | ||
Rep 5,681
My F31 335d did most of the 80k miles I had it on non-star tyres but, as the transmission never juddered, I find it hard to believe the lack of a star rating was the sole cause of the problems with the X3 you mention. If it was perhaps the model in question had an older generation X-drive system that was more tyre sensitive? Quote:
Of course it's reasonable to draw attention to the worst case scenario but (IMO) that should be accompanied by some context around the probability of it happening. Reading some of the threads on this subject you could be excused for thinking the use of non-star tyres is a cast iron guarantee that BMW will invalidate your warranty but it really isn't! |
11-21-2021, 02:34 AM | #103 | |
Rep 2,176
11-21-2021, 02:45 AM | #104 | |
Rep 2,176
11-21-2021, 02:49 AM | #105 | |
Rep 2,176
11-21-2021, 02:56 AM | #106 | |
Rep 2,176
11-21-2021, 03:02 AM | #107 | |
Rep 2,176
I’m sure we all feel better informed on this issue relating to tyres to decide for ourselves what suits us best as individuals! |
11-21-2021, 07:35 AM | #108 | |
Rep 326
11-22-2021, 02:34 PM | #109 | |
Rep 15,858
Modified version of the ATC13 in the latest G80/82 M-cars has even greater cooling features in the clutch pack. |
11-23-2021, 02:20 AM | #110 | |
Rep 2,176
