Technical Topics Suspension / Chassis / Brakes Anyone with eibach lowering spring?
      10-31-2020, 05:34 AM   #23
willh330e
Drives: 330 e m sport
330e lowering
Originally Posted by TheDudeMan View Post
I'm also looking into Eibach since the drop isn't as dramatic as the H&R. The less of a drop, the better for the factory struts. Otherwise, I would never recommend doing just springs.
HI
Did you end up lowering your 330e ? i have fitted 20' 795m wheels and think 20mm would look just right
many thanks
      10-31-2020, 12:20 PM   #24
TheDudeMan
TheDudeMan's Avatar
Ukraine
252
Drives: 20' 330i & RX 350
Originally Posted by willh330e View Post
HI
many thanks
No. I'm waiting for Dinan springs to come out. I also don't own a 330e, its a 330i.
For some odd reason, Eibach hasn't released these springs for the US market.
      03-17-2021, 04:06 AM   #25
philisme
Drives: BMW 1M Coupe + M2 + 330e
2016 BMW 330e  [0.00]
2012 BMW 1M coupe  [10.00]
2017 BMW M2  [0.00]
Hi,
Yesterday my Eibach Pro Kit lowering springs were installed on my 330e Touring (G21) M-Sport. My car has the M-adaptive suspensions (but without lowering from factory as it's a PHEV).
I now have a fault in the dashboard regarding the "chassis". And the ride is very bumpy. It's like drive a slammed car, it almost makes me sick. I really don't like it...
BMW 1M Coupe - AW - 2012
BMW M2 DCT - BSM - 2017
BMW 330e iPerformance - GSM - 2016
      04-30-2021, 04:30 AM   #26
GSG20
Drives: BMW G20
The wheel setup looks amazing. Do you mind sharing the wheel specs?
      01-22-2022, 08:27 AM   #27
Danzi
Drives: BMW G20
Originally Posted by lance666 View Post
Currently on normal suspension with eibach pro kit springs.
Do u guys think it does have reverse jake effect?
Anyone using eibach as well, pls share your pic if the dropped is similar?
Yours is a msport suspension ? just by lowering you felt big diff making your ride more uncomfortable?
      01-24-2022, 01:35 AM   #28
DRuw
DRuw's Avatar
Netherlands
131
Drives: G21 330e MSport Individual
Originally Posted by philisme View Post
Hi,
Any update on this? Since you have the fault on the dash, I think something is wrong... damage on dampers during install perhaps?
      01-31-2022, 08:26 AM   #29
jp0319
Drives: M340i xDrive
It's 320i m sport.
Thanks! Hope the front will drop alittle more to balance the drop.
From these pictures it "appears" that your rear wheels are slightly more flush than the fronts, this could be causing more shadow on the front making it appear that there is more gap. The best way to tell for sure would be measure from the center of each wheel to the wheel arch to see if the fronts are actually different than the rears. The eye can play tricks on you, measurements are a better way to tell.
      03-09-2022, 02:30 PM   #30
doublespoke
Drives: BMW 330e
Hi,
Any update on whether this was resolved and if so how? Am in a similar situation with h&r lowering springs for the 330e but on a G20 with Adaptive suspension: bouncy ride takes the air out of your lungs whilst speaking and intermittently get “chassis function restricted” on dash whilst the dampers stiffen up when this happens.
      05-09-2022, 11:11 AM   #31
tyranniux
Drives: G21 M340i
Also having this, had ACS springs fitted today and have the chassis error and bouncy ride, any resolution?
