Technical Topics DIYs and Coding Discussions Bimmercode Expert Mode Cheat Sheet
      01-12-2021, 05:47 AM   #23
jpaulo
Drives: 3 series
Great thread!
Looking forward to try on a 320i and report back my results.
      01-12-2021, 11:48 AM   #24
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
has anyone done this after the 07/202 OTA update? I've tried with my eternal adapter and it doesn't seem to connect. Worked fine on the prior software.
      01-12-2021, 01:33 PM   #25
JTYAMSHAYIN
JTYAMSHAYIN's Avatar
Drives: BMW 330i
Done something specifically? or just coding in general? I just coded my car and its on the newest update.
      01-12-2021, 01:48 PM   #26
EDMG20
Drives: Bmw 330i M-Sport {THP}
Same here, I just recoded all my favourite things. There should be no problems with adding pervious coding options.
330iToy71.00
      01-12-2021, 02:19 PM   #27
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
I cannot even get the Bimmercode app to connect at all
      01-12-2021, 02:20 PM   #28
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
I cannot connect at all
Would using an iPhone 12 matter?
      01-12-2021, 03:44 PM   #29
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
I can't even get access to car. Says connection error.
      01-12-2021, 03:55 PM   #30
biglesias31
biglesias31's Avatar
Drives: BMW X3
Make sure you have the beta version of BimmerCode
      01-12-2021, 04:40 PM   #31
Andy3661
Andy3661's Avatar
122
How do you get the beta version?
      01-12-2021, 05:02 PM   #32
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
I do I've coded tons of things before. Never had an issues until after this update
      01-12-2021, 08:29 PM   #33
JTYAMSHAYIN
Drives: BMW 330i
What device are you coding off of? I used both my IPhone and Ipad yesterday and I just used the normal Bimmercode App , i didn't have to request the beta. Make sure the Bimmercode App is up to date, then completely close the app and open it back up again to confirm it's not still on a previous version.
      01-12-2021, 09:11 PM   #34
claykin
Drives: various BMW
Originally Posted by fakca38 View Post
Can the errors in the picture be corrected with bimmercode?
Why not take it to your bmw dealer and let them fix under warranty? Or is there more to this story?
      01-13-2021, 05:00 AM   #35
biglesias31
Drives: BMW X3
Go into Settings in the app and send a support request email asking to test the beta version of the app
Andy3661121.50
      01-13-2021, 06:31 PM   #36
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
Ok, i got it working, had to turn on local network in privacy settings for the app.
Another question - does anyone have the HUD? I noticed after the update the REV indicator isn't there. I either turned something off or the updated removed it. Thoughts?
      01-13-2021, 07:02 PM   #37
njfoses
Drives: 20 M850i, 22 X6 M50i
https://g20.bimmerpost.com/forums/sh....php?t=1768645
      01-13-2021, 10:58 PM   #38
AndyTeb
Drives: BMW 3 series xdrive msport+
Can someone please share the codes to change the ambient light colours, thanks.
      01-14-2021, 01:18 AM   #39
helmet91
helmet91's Avatar
Netherlands
298
Pretty sure that's an ESYS thing, not BimmerCode.
      01-14-2021, 12:00 PM   #40
andy5468
andy5468's Avatar
90
Drives: BMW G20 M340D LCI
Happy to share my own personal settings, which I put together with support from others in this group.
I have coded mine with Bimmercode beta in expert mode to replace the Bronze and White and also the Green and White with Red and Blue. This will not change the displayed colours shown in the I drive screen, but will replace your strips, door bins, map light and footwell light colours and orientations as indicated below.
This is my personal list which I use to re code my colours to my preference after each BMW software update. I have to code both 360A and 360D.
Works fine on my UK G20 running 07/20.54 software. Code at your own risk. Coding in expert mode can damage your car.
BDC module > Expert coding > 360A LicLciColorLibrary > LIC_LCI_COLOR_LIBRARY_DATA > G20G21G26G28G80_Lichtpaket_code1 (selected option) > Custom value
1. Original hex values:
Byte 18 - D7
Byte 19 - 6E
Byte 20 – 14
Byte 23 - D7
Byte 24 - 6E
Byte 25 - 14
Byte 28 - D7
Byte 29 - 6E
Byte 30 - 14
2. New hex values:
Byte 18 – FF
Byte 19 - 00
Byte 20 – 00
Byte 23 – FF
Byte 24 - 00
Byte 25 - 00
Byte 28 – FE
Byte 29 – 0A
Byte 30 – 0A
BDC module > Expert coding > 360D LicLciColorProfiles > LIC_LCI_COLOR_PROFILES_DATA > G20G21G26G28G80_Lichtpaket_code1 (selected option) > Custom value
Byte 2 – 01 bronze
Byte 3 – 00 white
Byte 16 – 04 green
Byte 17 – 00 white
New hex values:
Byte 2 – 01 (Map Lights, Door handles, Door bins, Footwells) Now Red Colour
Byte 3 – 03 (Door / Dash strips) Now Blue Colour
Byte 16 – 03 (Map Lights, Door Handles, Door Bins, Footwells) Now Blue Colour
Byte 17 – 01 (Door / Dash Strips) Now Red Colour
Appreciate 6
EDMG2076.50
Andy3661121.50
SlwG2010.00
Snoopy848.00
      01-25-2021, 07:41 AM   #41
Basti@G20 320D
Basti@G20 320D's Avatar
Sweden
25
Drives: E30, E36, E46, F30, G20
This topic is way to good not to be at the top....come on guys coding cheat sheet ....
EDMG2076.50
B530e283.50
      01-26-2021, 05:07 PM   #42
Paolo73
Paolo73's Avatar
Italy
184
Drives: Bmw M4 YMB
Byte 18 - D7
Byte 19 - 6E
Byte 20 – 14
Byte 23 - D7
Byte 24 - 6E
Byte 25 - 14
Byte 28 - D7
Byte 29 - 6E
Byte 30 - 14
2. New hex values:
Byte 18 – FF
Byte 19 - 00
Byte 20 – 00
Byte 23 – FF
Byte 24 - 00
Byte 25 - 00
Byte 28 – FE
Byte 29 – 0A
Byte 30 – 0A
Byte 2 – 01 bronze
Byte 3 – 00 white
Byte 16 – 04 green
Byte 17 – 00 white
New hex values:
Byte 2 – 01 (Door / Dash strips) Now Blue Colour
Byte 3 – 03 (Map Lights, Door handles, Door bins, Footwells) Now Red Colour
To have all red?
Write the step please.
      01-26-2021, 07:58 PM   #43
chris_portimaog20
Drives: 2019 Bmw 330xi
Rear DRL
1. HU_MGU->HMI_SPEECH->DAYDRIVING_LIGHT_REAR->aktiv
2. BDC in Expert Mode > 3702LicFeatures->Feature_4 ->activ[/QUOTE]
no need anymore for bimmercode for rear DRL activation
it is now part of ID7 since the update
      01-27-2021, 12:32 AM   #44
andy5468
andy5468's Avatar
90
Originally Posted by chris_portimaog20 View Post
Rear DRL
It's worth adding that if you had previously activated your rear DRL's with this coding, you may find you need to reverse / deactivate this coding otherwise your rear DRL's may not work correctly through ID7 when the latest BMW software update is applied.
I had exactly that issue.
After the 07/2020 coding update, I had to change the 3702LicFeatures back to not activ to get my rear DRL's to operate through ID7. It was required though prior to that update.
Rear DRL's can now be enabled through the standard Bimmercode coding options, rather than through expert mode.
