02-13-2024, 11:12 PM | #1 |
Rep 5
Xdrive or RWD?? M340i
Hey I’m new to this platform and It seems you guys are well educated people on here.
I have a question I live in Florida and plan on getting a M340 2022-2023, should I plan on getting Xdrive or RWD is there a better version which one has more power which feels better and will make me more happy. Overall, does the price difference matter in between getting a Xdrive or Rwd M340i |
02-13-2024, 11:58 PM | #2 |
Rep 410
Stock for stock, xDrive is typically faster from a dig. RWD is faster on a roll. All depends on driver, car, and road/weather conditions. Technically they make the same power at the engine but there is more drivetrain loss on xDrive which equates to slightly lower numbers on a dyno.
If you plan on adding more power, xDrive is nice to have for added traction. RWD has weaker axles as well. You don’t have to worry about snow in FL so RWD would still be a good option. I personally love having xDrive. Tons of grip and power off the line which is what I’m most concerned with, acceleration from a stop or low speeds. I want to be able to floor it from 40 and have no traction issues. I’ve seen plenty of RWD ones (not stock) break traction at those speeds. Of course you can battle that with a better tire setup. I also like having it because I feel safer in bad weather when I have my son with me. Just my .02 cents, happing hunting!
02-14-2024, 08:40 AM | #6 |
Rep 794
XD = better overall performance and traction/safety
RWD = more fun Take your pick. |
Aymu1.50 tturedraider4974.50 |
02-14-2024, 10:11 AM | #7 | |
Rep 6,003
02-14-2024, 11:02 AM | #8 | |
Rep 3,337
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
02-14-2024, 11:06 AM | #9 |
Rep 545
RWD - for the win
Im biased as im in Florida
2020 - M340i RWD | Executive
(Retired 2015 - 335i RWD A8 | MP LSD, BM3, MP Exhaust, M Sport Conversion, 245/35/18 square, VRSF Chargepipe, Rear Brembo upgrade) (Retired - 2010 328i) (Retired - 1987 325i Vert) |
02-14-2024, 12:08 PM | #10 |
Rep 341
The axles are indeed the same its just that all the power goes through the rear axle alone on RWD whereas as soon as you ask for any sort of get up and go with XD it starts putting power to the front axle thereby reducing the strain on the rear axle a lot. That said the RWD is a robust setup for normal spirited driving but the treatment some guys give them would break any setup eventually!
02-14-2024, 02:10 PM | #11 |
Rep 410
My point was to simply state that in comparison to xDrive, RWD cannot handle as much and will have failures first in regards to the axles. This is something to consider if the power goals get to a certain level. Most won’t have to worry but it’s worth mentioning.
02-14-2024, 03:27 PM | #12 |
Rep 82
Since you're asking this question, my assumption is you don't have tons of driving experience, thus xDrive would be both faster and safer choice for you in every condition.
02-14-2024, 07:07 PM | #13 |
Rep 478
Typically AWD is more expensive to buy and maintain.
You don’t need it for snow where you are, but it will offer better traction in the rain, which is a factor in Florida, for sure. I picked it for better overall performance and I have mountain driving nearby. I also might relocate someplace that gets snow at some point Where you live and because you are buying used, it truly is a toss up, and I would choose the car with the best options.
'22 M440xi GC (BSM/Tacora) Previous: 2017 M240i Convertible; 2016 X5 50i; 2017 Boxster 718s; 2012 328iT Sport; 2009 X5 3.0; 2006 M3C; 2006 530xiT; 2003 325xiT; 2002 330i Sport; 2001 Z3 2.5; 2001 330i.
zlatko117.50 |
02-14-2024, 07:10 PM | #14 | |
Rep 1,946
02-14-2024, 07:49 PM | #15 |
Rep 4,143
It's 99% rwd until l you need awd.
But I won't drift. And if you force it to drift the awd will break. So awd no Brainerd for me. But it's annoying coz I can't drift it. It just won't. Awd kicks in. And if I force it, then it will break. |
02-15-2024, 06:26 AM | #16 | |
Rep 1,946
It may feel like RWD but those front wheels are always gripping and calculating. I believe it’s much more than 1 percent front wheel drive. Perhaps searching this forum could bring up a better explanation. |
02-15-2024, 08:12 AM | #17 | |
Rep 4,143
This is suggestive when my car's rear end went sideways at 55mph when driving straight onto loose tarmac (roadworks) from normal tarmac. Traction control was fully on also. In the rain the rear also goes sideways randomly when I was sure there wasn't any visible puddles. TC fully on. However people have said European traction control is different from American traction control. But I doubt that has anything to do with power sent to wheels while driving straight. I have to say that Americans report driving around in the snow with all season tires with no issue so I'm not sure how that is possible with RWD. So maybe your cars are different. Despite that if you think you can drift then you're also wrong. Try as I may as soon as I turn the wheels power gets sent to the front and it won't drift drift. Last edited by G30M; 02-15-2024 at 10:00 AM.. |
02-15-2024, 09:34 AM | #18 |
Rep 83
xDrive is indeed rear biased, one of my favorite AWD setups, and I have owned quite a few AWD sports sedans. With DSC off, you can rotate the rear with good throttle application. Not talking about drifting by the way, just good ol fashioned cornering prowess. Being in Colorado, USA, xDrive is a must.
02-15-2024, 04:29 PM | #19 | |
Rep 517
2023 BMW M340i xDrive
2020 BMW 330i xDrive 2018 BMW X3 xDrive30i |
02-15-2024, 04:35 PM | #20 |
Rep 1,635
Save the weight, save the money, go RWD.
And make sure you get the Adaptive M Suspension no matter which way you go, that's actually far more important. |
02-15-2024, 04:37 PM | #21 | |
Rep 1,946
From all my time in the m340i xdrive it’s always felt like an AWD car. On almost every twist and turn. |
02-15-2024, 04:42 PM | #22 |
Rep 517
That’s because during acceleration and spirited driving, the fully-variable AWD system directs power between the front and rear axles (with most going to the rear). At normal cruising speeds, all torque (read: 100%) is directed to the rear wheels.
