2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK 330e hesitant take up from stationary
      04-28-2024, 05:58 AM   #1
djcowlin
djcowlin's Avatar
285
Drives: G21 330e
I've noticed an annoying quirk with my '71 plate 330e Touring. When starting in electric drive from cold, there's a hesitation before the car takes up drive (forward or reverse). The first bit of throttle travel does nothing, and, once you've pressed harder to get the car moving, it tends to jump forward (or back). This doesn't happen once it's warmed up.
Has anyone else noticed this? I could live with it but don't want to collide with my gate posts.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG
      04-28-2024, 07:28 AM   #2
paulockenden
586
Drives: 330e xDrive Touring
72 plate 330e touring here, and I normally drive in electric mode.
Nope. Haven’t seen that at all. Sounds like your accelerator pedal might need calibrating. Perhaps.
      04-28-2024, 11:13 AM   #3
MisterG
England
23
Drives: M340i Touring, TVR Chimaera
Is this just the first “move” of the day?
It may be the electric handbrake release.
Usually with my m340i when I put it in gear after first start I’ll give the accelerator a gentle prod to release the handbrake.
djcowlin284.50
      04-28-2024, 11:25 AM   #4
paulockenden
586
I presume that what you're describing isn't the slight stickiness that you get with auto-hold switched on. That should be quite 'gentle', but you could try switching it off before you move off, to double check that it isn't that.
MisterG22.50
djcowlin284.50
      04-29-2024, 03:03 AM   #5
djcowlin
djcowlin's Avatar
285
Drives: G21 330e
Thanks, both. It is the first move of the day, so it could be the handbrake - it's worse in cold weather. I'll try releasing the handbrake first and see if that makes a difference.
