Technical Topics DIYs and Coding Discussions Engine Sound Setting Coding Tutorial w/ Bimmercode
      11-16-2020, 02:53 PM   #89
cilas
Drives: Z4 30i (G29)
Originally Posted by AlexxZeman View Post
I guess the only way to have a good sound and burbles for 320i, not only when in Parking mode but also while driving would be an aftermarket exhaust replacement.
The burbles you can "add" the OEM ones or custom ones, with Bootmod3. Is expansive, but it does the job.
      11-17-2020, 09:44 AM   #90
AlexxZeman
AlexxZeman's Avatar
Germany
23
Drives: BMW G20 320iX
Yes, sure, Bootmod3 can solve not only issue with burbles and add pops but also increase a power. The only downside you will lose your warranty in a moment ((
      11-22-2020, 03:41 AM   #91
X32G20
Drives: G20
Has anyone figured out how to get the selected exhaust options to stick? Would love to do this to have sporty the whole time but wish it would stick/remember my setting
      12-23-2020, 06:50 AM   #92
mikeyb74
mikeyb74's Avatar
Drives: G20 330ix M Sport
I was just going to ask the same question.
      03-13-2022, 06:26 PM   #93
okankaymak
Drives: 2021 330xi M Sport
Let me revive this thread. Anyone figured out how to save the engine sounds selection? I updated to the latest software but it's still resetting everytime.
      03-14-2022, 01:23 PM   #94
G30M
G30M's Avatar
3787
Drives: BMW M550i; Kia EV6 GT
Originally Posted by g20beam View Post
Hey guys, so I figured I'd tell you all how to code this option if you're looking to do exhaust modifications and want to minimize engine sound output digitally. There's actually an effective way to achieve this in iDrive 7 with the help of Bimmercode. I have a muffler delete w/ catless downpipe setup and this setting really helped to minimize the sound output level of my car. I'm on Bootmod3 AGG tune, while the pops and bangs are still there, the engine noise is massively muted in the 'reduced' engine sound setting.
To do this, go into HU_MGU expert mode. Use the search bar at the top of the menu. Type in SOUND and you will see two lines of coding pop up; enable both of these codes, and press code. Attached are results if done correctly, you can access this menu in general settings.
Enjoy!
hi does anyone know if this works / won't break the car for 2021 M340i ?
thanks
      03-15-2022, 02:43 PM   #95
twinturbomann
twinturbomann's Avatar
91
Drives: 2020 BMW X5 M50i, 2022 X6 X40i
Tested on a 22 X6 msport
I tested coding the 2 sound settings in this thread and it didn't make any sound diff but when I set the m_sound active it made the diff sound setting functions work on a g06.
      05-27-2022, 05:53 AM   #96
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
thanks
G80M4 ,
Sometime ago, I coded this into my "20 M340 & didn't notice any difference so I un-coded it
Al
Retired: 2014 328i
BMW CCA
      06-28-2022, 03:06 PM   #97
Willi4m
Drives: E30 323i and 320e 2022
Hi,
I did the manipulation to activate the exhaust menu and the sport plus option. Despite this, my exhaust valve does not open. Am I the only one?
      07-14-2022, 06:46 AM   #98
calvin-my
Malaysia
Drives: F15 40e, G20 330i
I noticed the G30 LCI came with the engine sound setting by default.
I coded off ASD and activated engine sound on my G20. So first thing before drive, switch to sport engine sound 😉
chrish_22111.00
      08-23-2022, 03:52 AM   #99
siwatkins
Drives: BMW M440i XDrive Coupe (G22)
Same on my G22 M440i - engine sound setting is available on idrive 7, and setting it to sporty, means the exhaust flap is open, even in comfort which I’ve checked.
      08-10-2023, 02:00 PM   #100
chrish_22
chrish_22's Avatar
111
Drives: 2023 330i
Has anyone done this on idrive 8?
      08-24-2023, 03:49 PM   #101
arathur
Drives: 2022 BMW M4 Competition
I tried this on my 2022 M4 Competition. I'm assuming it has iDrive 8. Using this tutorial, I was able to unlock the engine sounds menu. I can scroll through it but cannot click anything to make any changes.
      08-24-2023, 05:28 PM   #102
chrish_22
chrish_22's Avatar
111
Drives: 2023 330i
I coded off ASD and activated engine sound on my G20. So first thing before drive, switch to sport engine sound ��
You have the LCI G20 3 series with Idrive 8? How did you have the sound setting by default? I can't find it. Do you have any pictures? Is it the "sporty, balanced, reduced" sound options?
