Technical Topics Suspension / Chassis / Brakes NEW RELEASE: Dinan BMW G20 M340i (RWD) Springs/Bumpstops & Monoballs
      06-10-2020, 07:38 AM   #45
saido
Drives: M340i
Originally Posted by amrh View Post
Do you feel 10mm front and 13mm back is good, in terms of aesthetics? Is there much of a difference - especially the front?
Thanks!
Honestly, I think it is just right...I think a few mm more in the front won't make a difference, but it works. The back is perfect.
I considered wider in the front, but figured a staggered setup would be better.
amrh296.50
      06-10-2020, 10:02 AM   #46
saido
Drives: M340i
I posted some more pictures under G20 Photo Shot of the Day, they're more clear than the ones I previously posted.
amrh296.50
      06-13-2020, 07:44 PM   #47
longlasting
Drives: 2015 m3
Description says 1 inch off front and rear. Does that hold true 100% of the time when springs are on car ? Can springs be less then 1 inch drop or more then 1 inch ?
      06-15-2020, 07:40 AM   #48
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
There can be some minor variance (1/16" one way or the other). When you first get them installed it may be more like 1/8" until they settle however.
      06-16-2020, 05:40 AM   #49
longlasting
Drives: 2015 m3
Nice I just purchased and will report back when installed!
      06-16-2020, 07:29 PM   #50
chenry
Drives: BMWs
okay ordered
      06-18-2020, 09:49 AM   #51
amrh
Drives: 2023 M3Cx
So, I just had the Dinan springs installed. The car looks amazing! Better yet, from my short drive back, I can tell it drives much better. Less body roll and more control. Feels more planted, as well. Again, short drive back, so will need to drive more to see how the dynamics changed.
Unfortunately, my mechanic didn't install the bump stops. He felt that the OEM bump stops are more robust (his term). He told me this after he had completed the install, as I was picking it up. So, I couldn't argue the point, and certainly wasn't going to have him go through and install them. It's fine - it's a leased car. I just wish he would have asked me, while he was doing the install.
Otherwise, love the way it looks and drives (so far). Of note, I don't "think" it needs spacers. I was going to add spacers, but looking at it, after the drop, I think it looks fine.
      06-18-2020, 10:29 AM   #52
chenry
Drives: BMWs
congrats - get those pics up!
      06-18-2020, 11:15 AM   #53
Alex_bm
Drives: Giulia QV
AWD version is needed, ASAP!
      06-18-2020, 12:52 PM   #54
Gdiddy23
2015 BMW F30  [0.00]
+1
2020 M340xi PB (sold)
2020 Ram 1500 Laramie (Daily)
2019 Shelby GT350R (Weekend)
      06-18-2020, 12:54 PM   #55
Gdiddy23
2015 BMW F30  [0.00]
If you asked him to install the bump stops and we're obviously willing to pay, he should have installed them? That's like somebody not wrapping a vehicle bc they think the stock paint looks "robust" enough with it lol.
I would have been salty about that and I bet when used in combination, it will make even more of a positive difference
      06-18-2020, 03:36 PM   #56
Dinan_Engineering
Drives: Any BMW
I would recommend traveling on some less then ideal roads and see how jarring it may or may not be. With the factory bump stops the transition between spring and bump stop is not going to be ideal when compressed and utilizing all the suspension travel. Of course it's all comes down to the sensitivity of the driver as well.
      06-18-2020, 05:22 PM   #57
longlasting
Drives: 2015 m3
Price you guys getting quoted to install springs ??
      06-18-2020, 06:42 PM   #58
amrh
Drives: 2023 M3Cx
Your reply has put me more at ease. It made me remember and realize that bump stops, primarily, help with the ride. Hopefully, it's not bad. Coming from a F80 that was lowered (a bit), I'm sure I can handle some jarring.
I'm assuming the only way to install the bump stops is to remove the springs, correct?
I had mine installed for $550.
      06-18-2020, 06:51 PM   #59
Dinan_Engineering
Drives: Any BMW
Correct. Be the same process as installing the springs themselves hence recommendation to install at the same time.
amrh296.50
      06-22-2020, 08:52 PM   #60
Gdiddy23
2015 BMW F30  [0.00]
Any feed back on the bump stops and springs?
      06-23-2020, 07:12 AM   #61
Desrste
BMW4LIFE
Desrste's Avatar
30
Drives: '16 428i GC. '08 535, '84 e30
Will these work on g20 330i RWD?
      06-23-2020, 07:19 AM   #62
Dinan_Engineering
Drives: Any BMW
Never has been tested but if history is any indication they probably will "fit" but the front will be a bit too stiff for the 4 cylinder and cause a bit of a reverse rake given the slight difference in front end weight. We have a 330i xDrive due to arrive the tail end of the month and will begin to make some reverse correlations between the 2 models on the suspension side among other things.
      06-23-2020, 08:40 AM   #63
Gdiddy23
2015 BMW F30  [0.00]
M340 xdrive anytime soon?
      06-23-2020, 10:02 AM   #64
Dinan_Engineering
Drives: Any BMW
No car to base anything off of although the 330i xDrive depending on what is disconvered on it may give us enough clues on the M340i xDrive. Won't really know until we dig into it.
      06-23-2020, 02:08 PM   #65
chenry
Drives: BMWs
Going rate here in SoCal seems to be $250 for springs and bumstops, add another $75-$100 for alignment
      06-23-2020, 02:55 PM   #66
amrh
Drives: 2023 M3Cx
So, I've driven some more, around town and highway. To be honest, the ride is good. Sure, it's a bit more bumpy - as expected when lowering - but, it's still good. When going over dips, it handles them well, with composure. Hard bumps in the road don't feel any different, than before.
I was concerned about the bump stops not being installed - I'm not any longer, after having driven a couple hundred miles, this past weekend.
Yes, I would have preferred that the bump stops be installed. In my case, to get them installed, I don't believe is worth the time and money - I just don't think the ride will be much different. I'm in NC, and the roads aren't too bad. Might be different if I were in an area where the roads are bad.
That's insane! How is SoCal cheaper than NC - in any regard! haha I can't get an alignment, here, for less than $100...usually around $130.
