08-12-2020, 04:40 PM | #45 |
Rep 310
I did some more fine tuning of the MATCH-UP 7BMW integrated DSP after two days of listening.
I've followed the instructions in the Audio-Fischer Sound Tuning magazine for fine adjustments of phase/delay hoping to get ideal front sound stage. Once I got familiar with the process, I must say that it's fairly easy to do it by ear. The end result is Fantastic! Finally the stage is right in front of me. Not below, not to the middle of the car, but directly in front in the eye line. Adjusting the time aligment of left and right woofers with mids further improved the midbass and lower bass precision. All in all, this is now a great system. Even with factory woofers, I am very impressed with it. I don't think I'll upgrade the OEM under-seat woofers as i really don't see the need for that. I am sharing my sound setup file in the attachment. Just remove the .pdf extension after downloading. Beware that my car is left-hand drive. So for RHD cars, you can just load this configuration, then navigate to TIME, and switch the time alignment/distances of left channels to right, and vice versa for fronts, rears and woofers. Center channel distance should remain as it is. This will set the stage to RHD directly in front of the driver. Here is the link to Audiotec-Fischer Sound Tuning magazine: http://audiotec-fischer.de.dedivirt2...70d008e6b1.pdf I am attaching my sound setup file.(BMW G20 LHD, OEM woofers, ETON components for L,R and Center channel) You can find it at the bottom of this post. Just remove .pdf extension and then load the .afpx file into the DSP tool. Below is the screenshot of time-aligments for LHD. For RHD, just switch the distances of left to right, and vice versa. Feel free to use this DSP setup file, and let me know how it sounds with your setup. Last edited by Calamari; 08-13-2020 at 05:09 AM.. |
08-12-2020, 04:55 PM | #46 |
Rep 222
Awesome! Thanks very much.
Just checked what I actually have. Looks like it's the RAM: View post on imgur.com EDIT. After a bit of ringing around I've bitten the bullet and getting the Match UP7DSP with module and RAM harness professionally installed and tuned on Tuesday. Hopefully with the full Bavsound setup, it'll be much better than the HiFi. Hoping it'll be even better than the HK in the X5 (albeit with less speakers). Last edited by AustraliaG20; 08-13-2020 at 12:02 AM.. |
pneumodoc235.00 |
08-13-2020, 04:58 AM | #47 | |
Rep 310
I expect it to be much better than HiFi and even better than HK. I'm saying this because I remember my impressions with HK in one of the G20 test cars I drove last year. HK sounds good and is louder than HiFi. But I would never call it great. It's not clear and precise as my current system. The soundstage is not even close to a well tuned match up system. There is a member of X3 forum from Malaysia that has F10 with HK and G01 with HiFi that he upgraded with MatchUp 7 amp and aftermarket speakers. He claims that sound in the X3 is much better than HK in his wifes F10. He said that he would never order HK again, because HiFi with matchUp amp and upgraded speakers is much better system. Here is the link to his whole thread. It's a great read: https://x3.xbimmers.com/forums/showthread.php?t=1559784 Last edited by Calamari; 08-13-2020 at 05:12 AM.. |
AustraliaG2078.00 |
08-13-2020, 01:14 PM | #48 | |
Rep 15
Configuring the MatchUp 7DSP
I'm still figuring out what the best configuration is. |
08-13-2020, 02:37 PM | #49 | |
Rep 424
Really looking forward to hearing your thoughts once it's in. Will consider this at the end of the year, although seems like it's a bit difficult to find a place that sells the Up7DSP online in the US. |
08-13-2020, 04:13 PM | #50 | |
Rep 310
Why did you put front and rear input into front center full? As I've read in the docs, It should be only a.combination of the front L and R. Especially because RealCenter algorithm relies only on the front channels. |
08-14-2020, 04:53 AM | #51 | |
Rep 15
The original config-file from Audio-Tec has the Front-Center-Full on the AMP Out E, while my G21 has the center on AMP Out G. Do I have to change this AMP-out channel or stick on the config Audio-Tec provided? |
08-14-2020, 10:07 AM | #52 | ||
Rep 310
You can do a quicj test. Just load the Audiotec-fischer's Limousine setup and check if it sounds good. If you have LHD car, you can use my setup which is basically standard limousine config with fine time-alignments (for driver-centered front stage.) |
08-16-2020, 08:07 AM | #53 | |
Rep 15
According to the 7DSP installation manual (fig. 1 page 22), I read the subwoofer out is on E and F, while the center output is on G. I did check this using the DSP tool and identify each channel with the speaker connected. I will try to use your settings to see if it makes a difference. Last edited by ETan; 08-16-2020 at 02:15 PM.. |
08-16-2020, 10:21 AM | #54 | |
Rep 2,180
Last edited by Encanto; 08-17-2020 at 09:13 AM.. Reason: Fixed center channel assignment |
08-16-2020, 04:00 PM | #55 | |
Rep 310
This different layout of output channels is probably the difference between MatchUP 7BMW and 7DSP unit. Regardless of the difference in the output channel letters, you can set the corresponding channels with the delays/distance values from my setup and see if it works for you. The best test tracks to determine the center of the stage are the ones with pronounced vocals and not much instruments. My configuration file is from MatchUp 7BMW amp(with integrated DSP). BRAX, HELIX and MATCH are just different brands under the Audiotec-Fischer group. If you see BRAX DSP in my config file, then 7BMW has BRAX DSP inside. If my file doesn't work with 7DSP amp, you can just pull standard BMW touring setup (or limousine, cause some people said that limo setup works better in a touring) for 7DSP, and then set time delays/distances for all channels manually. It's pretty much what I did (along with a few more options like "light" effect of pronounced treble to give a little brightness to my ETON tweeters. I think I also enabled StageXtender effect). This should enough to hear a noticeably improved sound from your system. Let us know how it goes. Last edited by Calamari; 08-17-2020 at 02:04 AM.. |
08-16-2020, 09:25 PM | #56 | |
Rep 2,180
-Channel A/B = Front speakers -Channel C/D = Rear speakers -Channel F/G = Woofers -Channel E = Center The UP 7BMW and the UP 7DSP are the same units, the difference is the 7BMW has its 12+ and ground connections in the same Molex 20-pin connector as its inputs and outputs, the 7DSP has its 12V and ground in a separate connector and not in the Molex. The 7BMW can also be powered by the 12V and ground in the separate connector. If you got a 7BMW for your F30 HiFi and now you get a G20 HiFi then you can install the 7BMW in the G20 HiFi as long as you use the new G20 RAM harness and the 2ch add-on module. Last edited by Encanto; 08-17-2020 at 09:13 AM.. Reason: Fixed center channel assignment |
08-17-2020, 02:11 AM | #57 | |
Rep 310
08-17-2020, 03:01 AM | #58 | |
Rep 15
08-17-2020, 05:40 AM | #59 |
Rep 310
08-17-2020, 09:12 AM | #60 | |
Rep 2,180
08-17-2020, 12:34 PM | #61 |
Rep 15
Looking at both documentations (7BMW and 7DSP) they have add the channel letter to the Pin-assignments.
I also had checked each channel, by muting all other channels within the DSP tool except the one to check, which speaker gave sound. I had to reconfigure the channel routing. This is how I have configured the IO Main routing. Last edited by ETan; 08-17-2020 at 12:47 PM.. |
08-17-2020, 01:16 PM | #62 | |
Rep 2,180
Somehow it only makes sense to Match. |
08-17-2020, 02:32 PM | #63 | |
Rep 15
Maybe a personal preference, but I had to tweak the low frequencies for getting more bass from the front and rears to fill up some gaps between the subwoofers. |
08-17-2020, 05:16 PM | #64 | |
Rep 310
Did you enable bass enhancement effects? Also, is.there a reason why you combined all channels with 25% instead of mixing only 2 left channels to the left woofer, and 2 right channels to the right woofer. Despite the fact that low frequencies are not very directional, it still doesn't make sense that left woofer gets half of the lower end from the right side and vice versa. I just double checked the standard DSP setup file from Audiotec-Fischer, and they are mixing only two left channels (50% each) for left woofer, and right channels to right woofer. What are your first impressions after initial setup? Last edited by Calamari; 08-18-2020 at 03:56 AM.. |
08-21-2020, 01:59 PM | #65 | |
Rep 15
I was just playing around with the Bass and I thought to mix both lef and right for the Subs. The bass sounds great, but using the time alignments, it looks like its comes from front. I bought a DaytonAudio UMM-6 Calibrated USB Measurement Microphone, to measure the dynamics within the car. Currently I used the default equalizer settings from AudioTec. |
08-25-2020, 04:12 PM | #66 | |
Rep 15
Calamari208.50 |
