11-18-2019, 02:10 PM | #112 |
Rep 230
Did some experimenting over the weekend. For those of you who guessed the auto-dim sensor was IR activated, you were correct. In separate trials I applied predominantly white light, UV light, and IR light...IR had the strongest effect by far. As stated previously, this would explain why some tints of the same visible light transmission rating can exacerbate the problem more than others, as IR transmission rates surely vary widely among different films. Comparing the two photos you can see just how bright the backlighting can get in the day time when the sensor is saturated with IR.
Driving the IR circuit with stepped PWM, I was able to achieve 12 distinct levels of instrument cluster brightness. The brightest setting being significantly brighter than I've ever seen in this car during the day time, even on a bright sunny day before my windows were tinted. The next step is miniaturizing everything and designing an unobtrusive case for it, then optimizing it to run off a small LiPo pack. (And yes, I am fully aware how utterly ridiculous it is that I am resorting to this on a brand-new $50k car. But based on the feedback from my dealer so far, I have little hope this is going to be fixed via coding any time soon.) Last edited by 2020g20; 11-18-2019 at 06:38 PM.. |
11-18-2019, 05:01 PM | #113 |
Rep 114
So if IR is to blame primarily for the dimming issues would that imply that ceramic tints which block UV and IR more then basic tints could be to blame?
11-18-2019, 06:34 PM | #114 | |
Rep 230
Compared to carbon, probably not a huge difference. I'm reading 40% vs. 45/50% IR rejection. A far bigger difference than that would be how sunny your state is or what season it is right now for you. I know I wouldn't be noticing it as much here if it were July instead of mid-November. |
11-18-2019, 06:38 PM | #115 |
Rep 114
I'm in the northeast so it's dark by 4:30 unfortunately. Im worried about my tint causing this to happen. Leaning towards dyed tint at this point just to avoid this problem.
11-18-2019, 06:41 PM | #116 |
Rep 259
Yes I have ceramic tint and noticing this problem frequently. Slowly getting used to it though. Thankfully, the HUD dimming is not affected - so still able to see all the vital information clearly.
11-19-2019, 02:11 PM | #121 |
Rep 3,961
11-19-2019, 04:13 PM | #122 |
Rep 1,532
Yes. It's great, no issues day or night.
Prior's: E36, E46 x2
11-19-2019, 05:29 PM | #124 |
Rep 230
That definitely goes to show you it's situational. I have Suntek CXP 35% (same film as you but lighter), and I see the dimming issue every time I drive during daylight. But the amount of sunlight we've been getting in ATL may be less than where you're at. Plus we have a ton of tree cover here and I live/work around tall buildings, so I'm constantly in and out of the shade as I'm driving.
I also get the feeling this is somewhat subjective. I almost always drive with dark polarized sunglasses in the daytime, so dimming behavior some people may label as "no issues," I would see as constantly fading between "marginally acceptable" and "unreasonably dim". |
11-20-2019, 06:45 AM | #127 | |
Rep 1,532
11-20-2019, 08:40 AM | #128 |
Rep 230
11-20-2019, 08:43 AM | #129 |
Rep 230
Received further confirmation from a local dealer that BMW knows there is a problem, but has provided no fix: "I’m sorry to hear that your experiencing some lighting issues in your instrument panel. I spoke with one of our shop Forman’s and unfortunately BMW North America hasn’t instructed a solution. They have however stated right now there’s not a specific coding remedy for your problem, but has said after market tint is most likely the cause. Any solution has to be verified by BMW first, we’re unable to rely on customer suggestions. Our best recommendation is that you bring the car in so they can take a closer look at the issue."
In other words, "We know what's causing it, but we definitely aren't going to fix it. But how about you take some time off of work and waste half a day bringing your car in anyway so we can tell you that in person?" Last edited by 2020g20; 11-20-2019 at 09:01 AM.. |
Poochie9104.50 |
11-20-2019, 01:40 PM | #130 | |
Rep 24
11-20-2019, 04:39 PM | #132 | |
Rep 230
Maybe you should consider dealer-installed tint if you want to avoid the problem completely. That's probably the route I'd have gone had I known about this beforehand. |
