Technical Topics Wheels and Tires Track Wheel/Tire Setup - M340i xDrive
      06-01-2021, 06:04 PM   #1
tarrant64
Drives: M340i
I need some help/suggestions on what to do about an uneven tire wear issue I have with the M340i. Just destroyed a set of MPS4S's (225/40/19) over 1.5 track days (2 separate weekends). More interesting was a sign of not enough camber likely in the front with how I destroyed them.
I'm not new to track, but this is the first time I've come across this particular issue so looking for some input on a better setup. Tire pressures didn't seem to make a difference in adjustment.
Looking at going with a dedicated set for track, wheel+tire. But not sure if I need to look at doing more to address the wear issue like camber adjustments, or if a wider tire overall will just solve that issue. I like the idea of staggered, but I can't seem to find a lot of confidence in what that setup needs to be (other than I know you can configure the car supposedly from factory that way).
      06-01-2021, 08:04 PM   #2
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
I will be trading my M2 for a M340i next week and this is something I have started researching already.
Seeing your picture, the only logical solution I see would of been to back off and let the tires cool down, did you monitor temps ?
PS4S are street tires that can go on track but that's about it. I think Apex is supposed to come out with wheels but the demande will be super high and it may be hard to get a set.
As for camber I am not aware of camber plates available yet for the G series and it is not adjustable from the factory
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      06-01-2021, 08:54 PM   #3
tarrant64
Drives: M340i
As for camber I am not aware of camber plates for the G series and it is not adjustable from the factory
Wasn't on track that long to really put that much heat into the tires honestly . 6-7 laps at a time - 14 minutes tops that includes a warm up and cool down lap. I don't go too long into sessions because I the track have all day and like to avoid head soak. I know the tires were getting 'hot' just based off of the increase in psi I had to let out. Just…never had an issue with heat so much in what I thought was a better tire than the MPSS I used to run.
Thanks for the heads up on the Apex wheels, will have to give those a look.
      06-03-2021, 02:18 PM   #4
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
I have good hopes that G80 M3 lower control arms could be fitted to the G20 to add some camber. Unfortunatly I can't seem to find any web site that as the G80 parts for viewing or available yet.
I really like this method because it adds no NVH vs camber plates.
Daily: 2023 X5 45e
      06-03-2021, 06:03 PM   #5
tarrant64
Drives: M340i
You mean like from here?
https://www.getbmwparts.com/v-2021-b...ntrolarmsparts
      06-03-2021, 07:11 PM   #6
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
Yes, all the control arms I find are for other cars or older M3's, I think I will check at my local dealer if there system as access to G80 parts.
Daily: 2023 X5 45e
      06-04-2021, 04:14 PM   #7
Datka
Datka's Avatar
450
Drives: 2009 M3 ,2021 M340i
You destroyed your good tires that are good for the street, not for the track.
Also 225/40 are too narrow for such a heavy car.
Camber plates is the only solution here and running wider tires is a must.
"Racing is life. Anything before or after is just waiting." Steve MCQueen
tarrant64116.00
      06-05-2021, 10:50 AM   #8
tarrant64
Drives: M340i
Thanks for...stating back to me what I already put in my OP? lol.
But yeah, wider tires are for sure a must. It's worth pointing out, this is just a softer tire from my experience from the Pilot Super Sports (which I've done casual track days on previously without this issue - period). But more pointedly, this is an occasional track tire - per Michelin directly (pic attached).
I'm not finding a lot of people that have done any adjustments with camber plates though on this car -which is what I'm looking for feedback on.
      06-05-2021, 11:48 AM   #9
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
I searched but no camber plates available as of now.. best option for now is using more endurance tires like Goodyear Eagle F1 Supercar 3 and crossing fingers M3 control arms fit and are not too expensive (if they ad camber)
Daily: 2023 X5 45e
      06-05-2021, 03:03 PM   #10
tarrant64
Drives: M340i
You are literally the 3rd person that has told me to check out the Eagle F1 Supercar tires. I will honestly add that to my top list of choices. Thanks.
      06-05-2021, 07:28 PM   #11
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
I was at the track yesterday for the last time with my M2 and a fellow member (M2C) was there with these tires, he was FAST and the tires had a beautiful even wear.
Daily: 2023 X5 45e
tarrant64116.00
      06-08-2021, 07:40 AM   #12
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
Update !
I just ordered these and chose AD08R because Supercar 3 were only available after my track weekend (19-20) June. I am conscious I may wear the front tires prematurely for now until we can add more camber and will try to be cautious with tire rollover and pressures/temps.
I also plan on using these wheels for winter tires so I don't end up with 3 wheel sets.
19x8.5 et30 weight: 22.4lbs
245/40-19
Daily: 2023 X5 45e
tarrant64116.00
      12-20-2021, 08:42 PM   #13
McSampa
Drives: 2021 BMW M340i
Well, I may have overdriven the front drive side tire a little bit.... This is a product of 2 track days and 1 autoX day. Camber plates made a ton of difference on grip, but as you can see, tire wear is not even.
Guys at the track said this is a normal issue with 4s and I should try Eagle F1s or the Cup 2s... unfortunately, those tires are not made in the sizes needed for the staggered M340i.
Any luck upgrading wheels?
      12-22-2021, 09:49 PM   #14
Datka
Datka's Avatar
450
Camber plates are available for these cars?
      12-23-2021, 10:20 AM   #15
NoVaRob21
Drives: BMW M440Xi and X3 M40
I was going to potentially go with Cup 2s next summer, if you use the stock staggered set up wheels, they have fronts in the OEM size, but for the rear you have to go down from 35 to 30 side wall. This will also drive a reduction up front to 35 to make sure you have the diameters close enough to not freak out the xDrive system.
      12-23-2021, 10:46 AM   #16
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
It's not clear yet, I ordered millway street model for G80 and will see if they fit.
Vorshlag makes them for the Supra but it's not clear on there site if they actually fit the G20.
Daily: 2023 X5 45e
      12-23-2021, 12:33 PM   #17
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
I would personally go for a square setup using 4 same size wheels, the AWD system need to be under 2% difference I believe and 225 front cup2 will get destroyed just as fast as ps4s.
The OEM staggered sizes are really a compromise for safe, comfortable and "sportyish" daily driving.
Daily: 2023 X5 45e
      12-23-2021, 12:46 PM   #18
NoVaRob21
Thanks for the insight, I was also looking at getting a new set of wheels to make seasonal swapping much easier and I was going to go wider in front and back by 1/2" so I may be able to go as high as 245 up front and 265/275 rear
      12-23-2021, 01:39 PM   #19
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
Did you take a look at this thread ?
https://www.bimmerpost.com/forums/sh...php?p=27119379
Pretty much the best we have for now on max clearance and what can/could fit.
There are other threads about fitment but they either talk about 20-21inch wheels or winter tire setups.
Daily: 2023 X5 45e
      12-23-2021, 03:54 PM   #20
Datka
Datka's Avatar
450
According to McSampa he has camber plates already, so I guess they are available. Maybe he will clarify this for us. I cant find any info for c.p. offered for this platform. They have them for G8x already, but I don't think they will fit.
As far as fitting 245 tires up front, even R compound tires, I really think they will get destroyed mounted on such a heavy car, especially awd. Mine is rwd.
If I ever take this car to the track, it will be with camber set to at least 3.2F/2R and r-comp. tires. To be competitive on the track that is.
As I said, I have not tracked this car yet, but looks like I will next year as I just sold my e92M3.
I did track my previous street car f30 340i w/c. plates and r7 hoosiers and was very impressed by basically stock everything exept c.plates, tires and brake pads.
M340 I with track package feels a lot more capable from what I see so far.
      12-23-2021, 05:53 PM   #21
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
I ran 6 events last summer on 245/40-19 Yokoyama Advan AD08R and flipped them mid season to even camber wear. Yes the shoulders were dead but still managed to make the same times I was doing with my M2 that was equipped with AP BBK kit all around, Ohlins, R888R, Camber Plates. Indeed the G series platform is very impressive to say the least.
This coming summer I will be running 255/40-19 Eagle F1 supercar 3 with camber plates. I have fingers crossed Dinan also releases there sway bar kit, this + the MonoBalls bushing I already have should make my M340i complete.
Daily: 2023 X5 45e
      12-23-2021, 08:06 PM   #22
Datka
Datka's Avatar
450
Your tires survived 6 days on this car without camber plates?
I am very surprised tbh. What run groups are you running in?
I was as fast or faster than m2 comp. with my f30 340i so I believe you that this car is faster if properly modded.
