07-16-2023, 04:40 AM | #221 |
Rep 2,047
Should work without coding since the car is already coded for amber turn signals.
US spec vehicles are the ones not coded for amber turn signals and need extra coding to work. Here is some issue with G82 CSL taillight not sure if its might be related to G80. Only issue ive seen is flickering of tail light when car is locked and unlocked if welcome light is on. This personally i have seen for OEM units. Not sure about the aftermarket units, some sellers also have the same issue with their lights. Ive also seen some website selling GTS taillight for G80 have a disclaimer for this issue. You can contact Bayoptiks or other aftermarket sellers and confirm if its has the same issue. |
07-17-2023, 05:47 AM | #222 | |
Rep 649
CURRENT///G80 M3CX | Isle Of Man Green | Kyalami Orange | Bi-Color 826M Wheels
FORMER ///F80 M3 ZCP | Yas Marina Blue | Black | DCT | Black 666M Wheels FORMER ///F87 M2C | Alpine White/Orange | DCT | Black 788M Wheels FORMER ///F87 M2C | Sunset Orange/Orange | 6MT | Black 788M Wheels FORMER ///F82 M4 | SSII | Full SO | 6MT | Black 437M Wheels |
07-17-2023, 02:49 PM | #223 | |
936
Rep 4,326
Drives: M340
But if you go purchase OEM EU/UK/ROW spec lights, they will 100% need to be coded which is the main reason why this thread exists to begin with.
biggripper726.50 |
07-23-2023, 01:25 AM | #224 | |
Rep 165
Bonus - I took my drone out to check the brake force flashing and now all lights rapid flash on hard breaking. Previously only the third brake light worked before this rear taillight coding change. Will check if there is any difference in behvaior with my front DRLs when turn signal tomorrow. Thanks again |
07-23-2023, 11:40 AM | #225 |
Rep 165
To close the loop on this - someone mentioned their DRL/turn signals changed to “euro style” after coding the rear tails.
I don’t see any change in mine. DRL on the side of the working turn signal dims off when flashing, and back on after the flash stops. Same as before taillight coding. |
07-23-2023, 01:04 PM | #227 | |
Rep 165
Yes, my rear brake and signal are separated euro style after coding. |
07-23-2023, 07:21 PM | #229 |
Rep 165
07-23-2023, 11:41 PM | #230 |
Rep 2,047
The front DRL are controlled by FLM module. The rear lights are controlled by BDC.
So if you coded the BDC only then front DRL wont be affected. It likely the FLM modules where also coded. |
07-25-2023, 08:56 AM | #231 |
Rep 165
Question for you guys that have decoupled the brake/turn signals in the rear.
... I was thinking it would look better to have the turn signals act as brake lights (the thin line) and use the brake lights (the square leds) as a turn signal. Does anyone know how to swap them around? Thanks much |
07-25-2023, 11:05 PM | #232 | |
Rep 345
chrish_22111.00 |
08-02-2023, 09:47 AM | #233 | |
936
Rep 4,326
Drives: M340
I am not sure how LCI cars are coded. Someone will have to give it a try.
08-22-2023, 07:56 AM | #234 |
Rep 29
So I drive a 2021 m340i and I have changed my tailights to GTS style ones. I did straight plug and play basically and now Im getting tailights and brake light malfunction with rapid blinking when I turn the blinkers on. Could this potentially fix my issue or would the issue have something to do with the wiring? I even purchased bimmerutility thinking I could maybe turn off the cold/warm monitoring but could not find the option to do so. Anyone has any ideas what could be the issue?
08-22-2023, 09:46 AM | #236 |
Rep 29
08-22-2023, 02:30 PM | #238 |
Rep 29
09-20-2023, 10:54 PM | #239 | |
Rep 35
Drives: 2023 M4 Competition xDrive
Thanks! |
09-20-2023, 10:56 PM | #240 |
Beware of cheap bait!
709
Rep 715
Need wiring added, not plug and play like G20.
09-21-2023, 06:06 AM | #241 |
Rep 188
Drives: BMW M440i
09-23-2023, 12:14 AM | #242 | |
Rep 35
I've ordered all the parts and will attempt to do this mod. Will keep this thread post for all the G22/82 owners who've lost hope. A question though, can I splice the fog lights for left and right together on the same pin for dual fog lights to work or does the fog light button not care about which fog light is connected? |
ExplodingFires33.00 chutoy149.50 |
