2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Remote Software Update
      07-22-2020, 06:16 PM   #45
alexmcred
alexmcred's Avatar
Ireland
12
Drives: 318d GT M Sport
Originally Posted by Triggsuk View Post
Mines just popped up with 11/2019 update, its loaded and is sat on the screen that shows preparations complete you will be notified when the upgrade can be installed!
Not sure what it's waiting for now
I was also expecting the 07/2020 but I'm guessing that will be around Feb 2021 at this pace
Mine seems to be stuck on this the last couple of days. Not sure what the problem is that it’s not starting to install.
      07-23-2020, 02:25 AM   #46
Yossi123
Drives: 330xi G21
I had the same problem and the cause was the car battery not being fully charged.
Check out this thread it has all the info: (esp. posts #38,50, 53) https://g20.bimmerpost.com/forums/sh....php?t=1685107
      07-23-2020, 05:06 AM   #47
Blackers
Blackers's Avatar
62
Drives: 330e
Same problem, I turned the engine off and it started loading
      07-23-2020, 07:39 AM   #48
machman767
machman767's Avatar
235
Drives: 320i M Sport+
Mine has just done the update, but this is confusing me.....
      07-23-2020, 08:33 AM   #49
del82
Drives: BMW M340i xdrive
UK is left hand
Current: 2020 M340i
Past: M140i, Z4 35is
      07-23-2020, 08:36 AM   #50
machman767
machman767's Avatar
235
Thanks, it genuinely confused me because I thought traffic is on the right too.......call it lockdown fever!!
      07-23-2020, 10:06 AM   #51
Funboy78
Drives: ‘72’ BMW M340d G20 LCI
Mine appeared stuck, but then I realised what the issue was.
Car must have the engine running. You must be connected to the BMW car WiFi (even if not active or set up) it must be selected.
You will the see things move again as I did.
Now the transfers completed I’ve just locked the car and left it installing. Shame still no android auto tho......
Will check back in half hour and see what pops up, doesn’t sound like any major changes have been made.
      07-23-2020, 12:49 PM   #52
Funboy78
Just checked, all updated, all good...... but..... looks exactly the same lol.
Can’t see this widget BMW voice update, that still responds and looks the same, can’t find the daytime running lights button to turn on/off either?
Maps look the same also, so overall can’t say anything has changed that I can clearly identify. Not sure if anyone else has noticed anything or not?
      07-23-2020, 01:13 PM   #53
machman767
machman767's Avatar
235
Think it might take a day or two for things to appear, I've not got Spotify available yet.
Update: just looked, Spotify has appeared but no sign of rear DRL's.
      07-23-2020, 04:58 PM   #54
Funboy78
Don’t see why it would take a day or two? The update has been done. I had Spotify already, just had to sign back in.
DRL I only looked for as it mentioned it was part of the update, clearly not lol
      07-24-2020, 01:52 AM   #55
ramparts
Drives: M40i
Awkward German to English translation.
Should say drive not traffic
      07-24-2020, 02:55 AM   #56
del82
I'll be honest - I had to ask Google to be sure! The traffic should be drive I agree!
Current: 2020 M340i
      07-24-2020, 02:58 AM   #57
del82
I thought the DRL was only on 07.2020 update? I went from 11.2019 to 07.2020 - DRL only came up on 07.2020.
Try resetting iDrive (volume for 70 seconds, restarts twice) and updating apps.
Current: 2020 M340i
      07-24-2020, 03:07 AM   #58
machman767
machman767's Avatar
235
The DRL's are definitely mentioned in the 11.2019 release notes. I'm relieved it wasn't just me that got confused by the traffic thing!
      07-24-2020, 03:22 AM   #59
Funboy78
The only update appears to be 11.2019 so although it states that is a feature, clearly it’s not in this update.
It appears M340 owners appear to have 07.2020. Not sure if that was direct from dealer as opposed to OTA update.
My guess is 07.2020 isn’t available as an OTA, only through a dealership.
      07-24-2020, 03:29 AM   #60
Sergeant Skinner
Sergeant Skinner's Avatar
166
Drives: 2020 BMW M340i XDrive
It's correct terminology, albeit confusing. You drive on the left in UK / Australia etc.
While colloquially we might call it "right hand drive", it's not an accurate term because that only means "steering wheel on right", not where you drive. In this instance because if left hand drive cars came visiting the UK, the lights have to be set up to be on the UK side of the road, i.e. left hand traffic, so you don't blind people coming they other way.
They just want to say that irrespective of whichever side your steering wheel is on, what side do you actually drive on so we can ensure the lights don't blind people.
      07-24-2020, 04:05 AM   #61
del82
The only update appears to be 11.2019 so although it states that is a feature, clearly it's not in this update.
My guess is 07.2020 isn't available as an OTA, only through a dealership.
It is strange. OTA seems to only be 11.2019 at the moment. Those with 07.2020 have been updated by dealer which is what happened to me during some warranty work.
Since updating to 07.2020 I've noticed the light symbol is on the dash. When I turn off rear DRL setting, it goes. Defo wasn't like that before the update.
Current: 2020 M340i
      07-24-2020, 07:16 AM   #62
Dave330d
Drives: M340i touring
Updated mine this morning. Noticed that fold mirrors on lock was working again. This worked for a while before but then stopped for some reason
      07-25-2020, 01:42 AM   #63
theabbot
Drives: F30
My 2019 320i has just had the OTA update and I was hoping that it might have solved my Apple carplay problems, but no! It still connects as and when it feels like it. Does anyone else have this problem or found a solution? It's been back to the dealers and they say it works fine!
Thanks
      07-25-2020, 07:40 AM   #64
OM3RTA
391
As far as I've heard the newest update will remove the digital key for Android for iOS' digital key.
      07-27-2020, 06:54 AM   #65
RoboPapa
Drives: BMW
I completed an OTA Update to 11/2019.70 yesterday and noticed that coding for Assisted Driving View remained but coding for Lane Change Assist was removed.
Anyone else notice this and can it be re-coded or has that option been completely removed?
      07-27-2020, 09:10 AM   #66
srbs73
srbs73's Avatar
551
Drives: BMW i4 M50
Thanks
One thing I noticed is it seems to fill up the mobile devices with duplicates when mine doesn't connect. I have an iphone, watch and two ipads on my Apple ID and it seems to register the connections to multiple copies of each. I delete the duplicates and it works fine again until the duplicates appear.
Assumed it was an apple issue where it shares the WiFi info across devices.
