05-17-2022, 10:34 AM | #1 |
Rep 820
Drives: 2021 BMW X3 M
Add more bass to H/K system?
Has anyone added more bass to the Harmon Kardon system? By that, I do not mean adding actual subwoofers in the trunk. I mean changing out the speakers or the under-seat subs. The bass is pretty underwhelming, to say the least. I expected more from it. If anyone has added any speakers to really bring out the bass please comment below.
2014 BMW 335i M-Sport - SOLD
11-02-2022, 09:40 AM | #3 |
Rep 47
How can I incorporate this harness to add a small trunk sub? I have a low profile 10' shallow enclosure sub just laying around and Id like to install it in the trunk, im not great with car audio although Ive wired up a sub years and years ago.
The HK amp has 10 channels but only 9 are used? IS there a guide anywhere when adding an aftermarket sub to the HK system? The sub states 500w RMS but Id be happy with even half of that, can buy a cheapo amp if needed, battery is already in trunk, just dont know how to incorporate the harness. |
11-02-2022, 10:10 AM | #4 | |
Rep 13,011
If you are not satisfied with the extra bass of this aftermarket amp setup then replace the OEM woofers with SWS-8Xi and the Soundstream amp. |
11-16-2022, 07:31 AM | #5 | |
Rep 126
11-16-2022, 08:37 AM | #6 |
Rep 13,011
11-16-2022, 06:16 PM | #7 |
Rep 10
11-21-2022, 05:09 AM | #8 | ||
Rep 7,484
The man, the myth, the legend.. |
Technic2305.50 |
11-21-2022, 05:10 AM | #9 | |
Rep 7,484
You can amplify the under seats, add a trunk woofer.. different harnesses out there if you don't have HK. |
AddictedTo///M220.00 |
11-21-2022, 06:48 AM | #10 |
Rep 10
Awesome! Do you use it currently? I want to throw my sub in the trunk but wasn’t sure what harness to go with, the ones listed on their website don’t mention the HK system so I wasn’t sure!
11-21-2022, 07:28 AM | #11 | |
Rep 7,484
HK is also referred to as Top Hi-Fi (Option 688). So that would be the one to go for. |
11-21-2022, 02:15 PM | #12 |
Rep 10
12-02-2022, 02:44 PM | #13 |
Rep 7,484
Billfitz has dropped many a knowledge bomb on here so I have much respect for him educating us all. Whatever your upgrade it would be worth your time reading up his posts on Hoffman's Iron Law.
Looking forward to photos of your build. |
12-04-2022, 08:41 AM | #14 |
Rep 234
Hey guys, I appreciate everyone's input. I have a 2023 coming in hopefully this week. Like you I gotta have more bass. I did a custom job on my vette. Made my own fiberglass box and whole works.
My only concern with the HK upgrade. The crossover? Example my vette has a pioneer hu and I have the capability of changing the crossover levels from the hu. How would I go about this issue. I'm always changing the levels depending what music I'm listening to. |
12-08-2022, 01:11 PM | #15 |
Rep 147
Do you happen to have a step by step on installation and plug-in of that harness for the underseat woofers?
12-08-2022, 03:06 PM | #16 |
Rep 7,484
I am afraid not. I lost all my photos with an iCloud error. When I purchased the harness he sent me a PDF on wiring options. For example, how to connect an aftermarket amp. The rest is simple trim removal and wiring. There are plenty of guides on here of installs on other series. The under seat guides are pretty much all the same. Loads of videos too on how to loosen the seats and remove speakers etc.
12-08-2022, 03:08 PM | #17 | |
Rep 7,484
rmedina115.50 |
12-16-2022, 08:19 PM | #18 |
Rep 54
Hey, been following this post and I ended up swapping the woofers with sws-8xi. Two things popped up after the install.
1.The mids and tweeters now sound muffled. Doea anyone know why this would happen after unhooking the underseat woofers? 2. When I get out of the car and shut the engine off, there is a loud increasing bass Humm that seems to happen through the new woofers. Like a 40hz tone that starts at a low volume then eventually turns up louder. Happens for about 20-30 seconds until the amp finally turns off. I'm using the LOC with audio sensing for the remote on wire to the amp. Do you think I should use another signal for the switched 12v? 2023 m340 with HK and using a wavtech 2ch LOC and technic pnp harness. Last edited by kapa1122; 12-16-2022 at 09:37 PM.. |
12-16-2022, 11:57 PM | #19 | |
Rep 13,011
1. Mid/tweeters are powered by a separate amp from the woofers in the HK system -RAM power mids/tweeters, Booster power woofers. Wherever the muffled sound is coming from is not from the woofers.
2. WavTech Link2 turns on/off with the OEM Booster - Booster on/Link2 on, Booster off/Link2 off. Booster will turn off 2-8 minutes after engine off/all doors and trunk closed. Whatever noise is coming from the Booster when car is off is amplified by the gain on the aftermarket amp. Either reduce gain, or set Link2 to turn on/off with engine - 12V switched line is required. Quote:
12-17-2022, 07:19 PM | #20 |
Rep 100
Question regarding the 8-ohm HK under seat subs...if I use the Technic harness (add a sub) and choose to run an external amp for the two under seat subs, how do I power those subs with 8-ohms? (assuming most, if not all amps run between 1-4 ohm)
12-17-2022, 09:21 PM | #21 |
Rep 13,011
8ohms means less max power than what the aftermarket amp outputs are rated, i.e. if the output is 150W max at 4ohms then technically it should be 75w max at 8ohms. However, most aftermarket amps may output more than half its max power at 8ohms as its circuitry may adapt to changing resistance.
Tags |
bass, h/k |
