Technical Topics DIYs and Coding Discussions Engine Sound Setting Coding Tutorial w/ Bimmercode
      06-22-2020, 09:12 PM   #67
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
I'm on a slightly older version. 2019.7.38.
then, It's not firmware problem...
VipinLJ1941.50
      06-23-2020, 11:58 AM   #68
VipinLJ
VipinLJ's Avatar
Yes sir. That’s why I posted my firmware version in case someone thinks it’s because they have an old version. Mine is older
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      06-23-2020, 05:53 PM   #69
jk1112
Drives: 2019 BMW 330i
In my 330i this sound configuration seems to modify both the ASD and the exhaust valve.
Example: in comfort driving mode if I select "sporty" in the engine sound menu, I can hear ASD clearly. You can also hear the exhaust flap open, has a very distinct click.
VipinLJ1941.50
      06-23-2020, 05:58 PM   #70
VipinLJ
VipinLJ's Avatar
That might be the case then. Because g20beam has his ASD coded off but his exhaust valves work normally and it makes a difference for him. In my car, my ASD hasn’t been coded off but my exhaust valve is always open via a JB4 setting and it makes a difference in my car too.
So I assume it affects both.
      07-04-2020, 01:54 PM   #71
jan.muc
Drives: BMW G20 M340ix
Did someone try to code this using E-Sys?
The second parameter is missing in my esys
      07-06-2020, 01:13 PM   #72
jan.muc
Ive just coded this with bimmercode beta. It definitly controls the flap. My ASD is off. Such a nice function!
      07-06-2020, 06:18 PM   #73
VipinLJ
VipinLJ's Avatar
Like someone else previously mentioned, it controls both ASD and flaps.
      07-06-2020, 09:19 PM   #74
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
its becuz, launcher 3.7 has mis-matching code name.
anyway I will give you cheat code for Engine sound
<FDL>
<cafd id="00003E52" name="MGU" author="jaimeen" series="S18A">
<code description="ENGINE SOUND">
<group id="3000">
<function start="9" end="9" mask="00000100b" comment="display_menu_configuration_engine_sound"> 01</function>
<function start="14" end="14" mask="01100000b" comment="display_engine_sound">01</function>
</group>
</code>
</cafd>
</FDL>
      07-06-2020, 09:54 PM   #75
VipinLJ
VipinLJ's Avatar
Does it stick for you guys who coded it with esys? With the bimmercode method, it resets everytime the car is turned off.
      07-06-2020, 09:57 PM   #76
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
It also resets everytime
      07-06-2020, 10:02 PM   #77
VipinLJ
VipinLJ's Avatar
Ahh. So there's probably one line of code that is missing. I wonder how it is for the X3 guys.
      07-07-2020, 07:44 AM   #78
hkleyman
hkleyman's Avatar
Drives: 2019 BMW X5 50i M-Sport
I have ASD disabled from the factory but I do have an exhaust flap, I coded these options last night and was able to view / select, but they had no impact on the exhaust valve.
The only sure fire way of opening it constantly since I was upgraded to 03/2020.58 (which made the valve only open during motion and no longer at idle) is to manually open it in Bimmerlink.
      08-17-2020, 03:25 PM   #79
AlexxZeman
AlexxZeman's Avatar
Germany
23
Drives: BMW G20 320iX
Coded "sport+" for my 320i (no valve in the exhaust) sounds better than in "sport" but not that much burbles as I heard at earlier 320/330 cars.
Any experience to improve sound for a car without valve in the exhaust?
      08-18-2020, 12:54 AM   #80
Heliot077
Drives: BMW G21
When was your 320i built? I thought, that all 320i do have the valve.
      08-18-2020, 02:13 AM   #81
jw390898
Drives: G20 320i M Sport
Mine (UK) was 09/19 and there is no valve fitted or ASD.
I believe all after around July 2019 no longer thad these, all to do with new EU regs.
      08-18-2020, 03:51 AM   #82
Heliot077
Drives: BMW G21
OK Thanks!
      08-20-2020, 08:07 AM   #83
AlexxZeman
AlexxZeman's Avatar
Germany
23
No, mine is without vavle, but with M-sport pack and sport gear box with launch control
Production date
2019-11-05
      08-20-2020, 08:13 AM   #84
AlexxZeman
AlexxZeman's Avatar
Germany
23
I guess the only way to have a good sound and burbles for 320i, not only when in Parking mode but also while driving would be an aftermarket exhaust replacement.
      08-21-2020, 04:50 AM   #85
Heliot077
Drives: BMW G21
Hmm strange. Some have a valve and some not.
Other exhaust is not possible in my case...its a company car.
      09-09-2020, 01:22 PM   #86
treska37
treska37's Avatar
Drives: G20 2019 330i Msport
Hmmm i seem to be in the minority I coded this a few days ago and mine stays on sporty never resets to depending on mode, UK 330i Msport tried different settings at stand still and deffinatley activates the valve as you can hear it actuating the motor of valve.
I do still have ASD enabled coded couple other things at same time as well msport logo in speedo cluster & M style font.
      09-12-2020, 11:34 AM   #87
Krislovesbmw
Drives: 2013 BMW 528i, 2019 BMW X7 40i
Can I change the Exhaust Sound in G07 with Bimmercode ?
      10-27-2020, 11:35 PM   #88
ruczko
Drives: '20 330xi
The M-Sport logo, did you add just that or did you have to update the whole cluster to the M one? I'm confused with these settings, the logo and font.... are they standalone?
