2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Speedometer is off? Four miles per hour higher then GPS/Phone
      03-16-2020, 02:01 PM   #1
MineralM
MineralM's Avatar
249
Drives: BMW 2020 M340xi
Does anyone else have this issue?
Taking my car to BMW Tomorrow for them to check it out.
      03-16-2020, 02:25 PM   #2
Krabbypatty
80
Drives: BMW M340i xDrive
2020 BMW M340i  [10.00]
What country are you based in?
      03-16-2020, 02:26 PM   #3
VipinLJ
VipinLJ's Avatar
Mine shows exactly 2 MPH higher (always) than my phone’s GPS as well as the roadside speed warning signs that show what speed you’re traveling at. Doing a bit of reading, I found out that that’s how BMW codes the speedometer. The correction can be turned off in older cars to show the exact speed. It should be doable in the G20s too.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      03-16-2020, 03:37 PM   #4
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3449
2020 BMW M340i  [0.00]
This is nothing new.
https://www.google.com/search?rlz=1C...71.-ioDqp63gLc
jpichardo@tulley.com
      03-16-2020, 03:57 PM   #5
Weiner0123
Weiner0123's Avatar
Drives: 2020 m340i. 2013 328i
I thought they do it in purpose?? I remember reading it somewhere
themnmd1687.00
      03-16-2020, 04:03 PM   #6
VipinLJ
VipinLJ's Avatar
Yup. It’s done on purpose.
      03-16-2020, 04:08 PM   #7
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
441
Yes it does read high on purpose. It is so that when you are in a speed control area and you do the advised speed on the speedometer then the car will always be below the required speed. Allows for some error in instruments and stops any legal action against car manufacturers.
Or put another way (from a U.K. website)
To ensure that they comply with the law and make sure that their speedometers are never showing less than true speed under any foreseeable circumstances, car manufacturers will normally deliberately calibrate their speedos to read ‘high’ by a certain amount. As your satnav is not the designated device by which a car’s speed is measured, it does not need to incorporate any fudge factoring.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      03-16-2020, 04:09 PM   #8
HighlandPete
Drives: BMW F11 535i Touring
Yes, Type Approval in Europe dictates over reading. Must never under read.
Appropriate regulation....
3. For all true speeds of between 25 mph and 70 mph (or the maximum design speed if lower), the difference between the indicated speed and the true speed shall not exceed—
V / 10 + 6.25mph
where V = the true speed of the vehicle in mph.
      03-16-2020, 05:40 PM   #9
hamera
hamera's Avatar
442
Drives: 320i M Sport (G20)
Same here
      03-16-2020, 06:44 PM   #10
siegester
siegester's Avatar
341
Drives: '20 M340i
You can code it to be accurate, I have done mine
      03-17-2020, 06:26 AM   #11
cnichols138
X3M Comp is a beast
89
Drives: 2022 BMW X3M Comp
sometimes my M340I is accurate. However using Waze its sometime 4 to 6 mph off. Showing lower than the speedo. Makes me wonder if I am going slow. Could be why drivewise from Allstate does not catch all my over 80 incidents.
      03-17-2020, 08:38 AM   #12
seccsc
seccsc's Avatar
Drives: G20 M340xi
This is no different from my E90 and was also programmed to be about 75 MPH (by gps) while driving at 80 by indication.
      03-25-2020, 08:17 PM   #13
JoCamp
Drives: 2020 BMW M340i xDrive
What did you use to code it out?
      03-26-2020, 04:43 AM   #14
HighlandPete
When you say code it to be 'accurate', what tire tread depth do you set it at? Say you code/set it for a new tire, it will not be accurate when at minimum tread depth.
      03-27-2020, 07:05 AM   #15
JSaid
JSaid's Avatar
Drives: 2022 BMW M340i xDrive
[QUOTE=JoCamp;25969488]What did you use to code it out?https://g20.bimmerpost.com/forums/sh....php?t=1697373
