03-23-2020, 12:23 PM | #1 |
Rep 170
Dream garage essentials?
Currently getting started building my new house (great timing right?) and with this quarantine had some time to plan out my garage.
Here's what I'm planning on doing: Swisstrax flooring Twin Busch scissor lift Hose bib inside the garage for wall mounted pressure washer High lift garage door conversion Jackshaft garage door openers Sonic (or equivalent) cabinets 7 4-bulb led fixtures What "essentials" would you want in your dream garage. |
03-23-2020, 12:31 PM | #2 |
Rep 310
Personally I would do a 2 post lift.
You covered almost everything else, and I don't know if it would matter in your climate, but I would have an internal floor drain. Oh, and wiring for computer, and sound system. |
flipnkraut135.50 Dackelone10538.50 |
03-23-2020, 12:34 PM | #3 |
Rep 381
Drives: '21 330i xDrive
I'd want epoxy flooring like they have in high grade clean rooms with the wraparound corners, probably with yellow and purple/magenta flakes on a black drop, lots of storage space, and one of those tool chests because I've always wanted one of those. Proper drainage too
Also would love to have some sort of speaker system that I can connect to easily. I am a sucker for smart home stuff though |
flipnkraut135.50 |
03-23-2020, 12:41 PM | #4 |
Rep 83
4 post and 2 post(both have their benefits
Air at all corners Middle hanging air and electrical reels all plugs on their own separate dedicated 20 amp fuses(hey, you said dream, right?!) Tig and Mig setup 60 gallon compressor outside enclosed Wash bay with boom pole above Enough lighting capability to see from the moon Heat/AC system High end filtration Obviously large QLED TV and sound system Fully smart(HVAC, lighting,security, even my filtration able to be controlled remotely from phone) A full matching box/tools I think thats about it. I think it's a fair ask. |
03-23-2020, 12:44 PM | #5 | |
Rep 83
In reality: NICE epoxy floor Mini-split GOOD lighting Nice tv and sound Internet access SPACE |
flipnkraut135.50 |
03-23-2020, 01:17 PM | #6 |
C2H5OH
3915
Rep 2,144
you'll want a wash sink, ceiling fan, in floor heat would be nice.
Swisstrax flooring does not sound floor jack friendly, which means you're left using the lift for simple tasks all the time. A vacuum system added to the water/air may be useful. Central vac. But depending on garage size might not be a friendly price. |
flipnkraut135.50 |
03-23-2020, 01:27 PM | #7 |
Rep 1,910
Things I personally use most in my totally not dream garage
1. Wall mounted vacuum 2. Celling mounted air hose 3. Love my epoxy floors Things I wish I had 1. More cabinets & counter top space, can't have enough so I don't have shit lying around 2. AC and or fans mounted all over the place 3. Wish I had a way to wash the cars inside the garage, probably not big enough though 4. Wish my truck fit in it |
flipnkraut135.50 |
03-23-2020, 01:28 PM | #8 |
Rep 880
Drives: 2011 E90 M3, 2019 F150
I do not understand swisstrax. If you get oil or dirt under it, what do you do? Seems like way more trouble than its worth and they are stupid expensive.
- Drain - Wash bay - Slotted walls for storage all the way around - Mini-split - 110V outlets everywhere - 220V in one location - Air all the way around - Epoxy concrete floor - 2 post lift - In wall/ceiling speakers with bluetooth hookup - Walled off section for woodwork - Walled off section for metalwork I think that basically covers it |
flipnkraut135.50 wdb4732.00 |
03-23-2020, 02:11 PM | #9 |
Rep 5,577
03-23-2020, 02:27 PM | #10 |
Rep 740
My list:
- Large Slop Sink - Epoxied floor (blow off & mop to make it look like new) - Finished interior painted white (makes it much brighter for working) - Enough shelving/cabinets that NOTHING has to remain on the floor (Reduces locations for mice to run/hide, makes cleaning much easier) - Shelving is nice for things commonly used (detailing supplies, etc) - Cabinet are nice for chemicals, they can be latched/locked to keep small children at bay - Ceiling mounted retractable extension cord - LED replacement elements for standard fluorescent bulbs - about twice as bright, helpful with 'old eyes' - Rolling tool box that can be rolled to either side of the vehicle being worked on (reduces the number of steps required for a typical project) - A reasonably-sized work surface, preferably with a vice for holding your work. - Fridge: don't want to have to track much inside the house when going for a water or a beer - Stereo: having music tends to make the projects go quicker |
flipnkraut135.50 spazzyfry1234358.50 |
03-23-2020, 02:50 PM | #11 |
Space Force - 4 Star General
11463
Rep 3,264
You forgot the most essential of all garage accessories: A tool holder...
03-23-2020, 02:56 PM | #12 |
I'll get back to you
7560
Rep 2,132
my truck needs some work can I bring it over when you are done
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
03-23-2020, 04:19 PM | #14 |
Bergspyder
1469
Rep 1,212
I want a desk with a computer and stereo....
up on a perch.... high over the kingdom I survey..... So I can look down upon my toys.... That's all....too much???
03-23-2020, 05:23 PM | #15 | |
Rep 170
I personally love that dirt just falls through and you're just left with a clean floor. I'd have having nice looking epoxy floors with dirt and having to sweep/vacuum frequently to keep it clean. |
03-23-2020, 05:25 PM | #16 | |
Rep 170
03-23-2020, 05:25 PM | #17 |
Rep 96
Seems like a lot of this has already been said so I'll just repeat probably:
Ceiling mounted electrical and air hose reels. A fuckton of LED shop lights, get them at costco and you can link them together Wall mounted horizontal power strips Saferacks storage from above or heavy duty wall hooks, never look at the ground for storage... look up. Wall mounted wheel storage racks A good easy to turn on music source like Sonos or similar I run a PC and TV in my garage, all off of wifi that gets a good signal from the house via Orbi I always wanted opaque glass garage door panels for more daylight in my garage. Any shelving or heavy things you have sitting on your floor, put wheels under them. That way any time you want to move them you can. |
flipnkraut135.50 |
03-23-2020, 05:27 PM | #18 | |
Rep 170
Floor drain would be nice but would probably be cost prohibitive where I am. |
03-23-2020, 05:34 PM | #19 |
Rep 4,107
I want a garage...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
wdb4732.00 Flying Ace4984.50 |
03-23-2020, 06:02 PM | #20 |
Rep 310
More accessibility around the vehicle, less to work around when pulling big drivetrain parts etc. I do things like engine swaps and big jobs a lot more than the average home hobbyist though.
03-23-2020, 06:15 PM | #21 |
Rep 1,897
Hard pass on the Swisstrax. Instead I would go with a high quality industrial grade floor coating. I would also invest in wiring and outlets to support 2-3 (depending on size and configuration of garage) Level 2 or Level 3 EVSEs. While you may have no use for them today, the proliferation of the EV is not too far off. I would also consider elevated electrical outlets for flat panel televisions, floor drain/grate running the width of the garage, W/D hookup, and smart garage door opener. That's all I've got for now. Let's see some photos when it's done!
wdb4732.00 |
03-23-2020, 06:38 PM | #22 | |
Rep 170
The only legitimate con I've seen is that it's uncomfortable to walk on barefoot. |
