03-26-2020, 06:24 AM | #1 |
Rep 250
330e charging settings / preconditioning?
Hi,
I am thinking about the new G20 330e as my next car. How is it to use as an EV in daily life. Can you set max charge / minimum charge? For my daily shopping etc, I wouldn't need more than 60-70% state of charge on the battery. My daily commutes are less than 20km. How about preconditioning. Can you leave your car in the sun while shopping, then start the A/C on max a few minutes before you come back to your vehicle?
Current: 2018 X1 F48 & 2014 F20 116i. Before: 2009 BMW E90 320d LCI, 2008 E92 M3 &
03-26-2020, 09:43 AM | #2 |
Rep 4,210
I am a one car family so I use my 530e as my daily driver. It works great as one.
There is no reason I can think of to only charge it part way...and I don't think that is even especially good for the battery. If you don't use all your charge today, that just means you have to add less charge tomorrow. You can definitely do the starting the AC. I live in hot greater Phoenix and in the summer the temperature can climb above 110F (43 Celsius). I will play golf in the morning and when I get through with the second to last hole I take out my phone and turn on the AC and the car is comfortable by the time I get to it. But I do use Battery Control on the way to the course to make sure I have adequate charge available to turn on and run the AC. So it will work, just make sure you have adequate charge. This is, by the way, another good reason to always fully charge when you can. My caveat on that is that you do want to charge where and when it is least expensive. So that can impact on your charging decisions. In my city, for example, the peak time for electric rates is 3 PM to 8 PM. So I don't charge in that window. |
04-07-2020, 02:45 AM | #3 | |
Rep 250
04-07-2020, 06:12 AM | #4 |
Rep 7
I drive a 745Le (EU), you cannot set the min/max battery charge in mine. It always does 100%.
But it doesn't go to 0%, I was driving with an empty battery and drove into an eZone, it suddenly turned on electric driving while it said "—- km". So it seems to always leave some charge in it. |
04-07-2020, 12:26 PM | #5 | |
Rep 243
"To optimally operate the high-voltage battery, charge the vehicle regularly and fully" Is it possible that BMW made the system smart enough to not overcharge? Ie when it says it is 100% charge it's really only 80% or 90%? I've heard that there is still charge left even when it says Zero too. |
04-07-2020, 01:48 PM | #6 | |
Rep 4,210
04-08-2020, 11:45 AM | #8 | |
Rep 22
There's a clue to it in the stated capacity stated in ev-database "The battery of the BMW 330e has a total capacity of 12 kWh. The usable capacity is 10.4 kWh." |
