2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums AUSTRALIA BMW G20 Dashcam and Battery Installation.
      04-15-2020, 01:30 AM   #1
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
I spent my time over Easter in isolation from the world, just like everyone else. Although I have a Drive Recorder installed in the car I felt the need to have dashcams to record any unfortunate events while parked. In addition, the dashcams also give you cool video while driving and also records events on the road that would otherwise not be recorded by the Drive Recorder - like the time a Merc driver decided to brake test me in a 40 kph zone (complete with middle finger) - WTF?
So I put the time to good use and installed the following in my car:
1. BlackVue DR900S dual channel dashcams.
2. Cellink Neo6 battery to run the dashcams while parked.
As I have not installed a Power Magic Pro, I have not conducted the research on how it should be installed. I'm sure someone else will be able to help with this.
In the meantime, here is a video on the installation and a PDF file of photos and a few tips to assist you, should you wish to install something similar in your own cars.
File Type: pdf BMW G20 M340iX Dashcam and Battery Installation.pdf (2.14 MB, 3011 views)
Appreciate 15
bcoz80.50
Slideit49.00
cfm56d7b5922.50
baturbo47.50
Soul_Glo13381.50
BMKILLA50.50
Emrick43.50
Xsapper238.50
Terman9.00
k4sh_90539.00
vadimo311.50
TTG936.00
      04-15-2020, 09:18 PM   #2
pmunger
Drives: F82 M4
Nice work!
F82 M4 | Silverstone | Sunroof | 19" light alloy 437 Black.
      04-15-2020, 10:52 PM   #3
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Very nice work indeed. Thanks for sharing. I have the same setup.
      04-15-2020, 11:23 PM   #4
Slideit
Slideit's Avatar
49
Drives: BMW 330e
Yeah, this is why I'm leaving the Merc tribe and joining the one where we don't have to signal for lane changes.
On a serious note, how does the BMW recorder compare to this high-end set-up?
      04-15-2020, 11:47 PM   #5
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
Actually, I’ve found that the Beemer shakes the steering a little on a merge lane if I don’t signal, even with lane departure deactivated, but with active cruise activated. Clever huh?
The BMW Drive Recorder uses the front, back and side cameras and will be really useful in the event of a side impact, but it is inactive when parked.
Therefore, the main reason for me is that I’ve put in the dashcams to ensure recording continues while parked and unattended.
They also record visual events on the road, resulting in no impact, that the Drive Recorder would not pick up, ie near misses, dickheads, etc. They also record GPS speed so that you could supply this info in the event of a contested speeding event. A further reason is to see what happens to the car during servicing at the dealer - providing the bastards don’t pull the power lead out, as has happened in the past.
To me the drive recorder is my secondary set of cameras to the primary dashcams.
      04-16-2020, 12:12 AM   #6
Slideit
Slideit's Avatar
49
Drives: BMW 330e
I have a cheap dashcam in my Merc at the moment. When it comes back from MB service, it's disconnected. But when I've taken it to my independent guy, it stays connected and records when the ignition is turned on.
      04-16-2020, 12:59 AM   #7
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
I guess the answer is to fit a tamper proof dashcam.
I had planned on doing this to my current car, but I stuck the camera down in slightly the wrong position (idiot!). I’ll move it down a little to take the tamper proof casing once I can get my hands on some fishing line to cut through the 3M adhesive.
Slideit49.00
      05-05-2020, 12:31 AM   #8
firetitanx
firetitanx's Avatar
100
Drives: BMW 330i M Sport 2020(G20)
Hi Steve
Excellent video and pdf mate , I will be definitely installing the same setup as you
Have you thought about buying the Blackview polarizing filters?
I noticed in the footage of the front camera there was the reflection of the speaker grille
I will also buy the tamper proof lock for front camera.
A quick question , you did not have to buy any longer cables for the Blackvue right, they were all enough length to go from front to back ?
What brand Micro SD card did you buy and what capacity and is your current capacity sufficient . 128GB can store 7 hours of 4k footage so I was thinking of that capacity, the Samsung EVO
I think max is 256GB but maybe thats a bit too much especially when they advise you change cards every few years due to degradation.
One more question, are you getting any funny messages in your BMW display because of the install or does everything work 100% no issues.
Thanks
      05-05-2020, 03:48 AM   #9
Slideit
Slideit's Avatar
49
Drives: BMW 330e
Hi guys
Blackvue seems to be very popular. But I’ve seen good reviews on Thinkware and Viofo. Anyone have views on those two?
      05-05-2020, 04:54 AM   #10
kaipajo
Drives: G20 330e
Im I the only one who has like 5fps on the video? Not happening on any other YouTube videos.
      05-05-2020, 06:29 AM   #11
MrMickeyG
Drives: BMW 330i G20
How are you viewing the video? I had a similar problem - i think i was viewing them on my phone, or maybe the desktop program, but viewing the raw file was fine.
      05-05-2020, 07:30 AM   #12
kaipajo
Drives: G20 330e
On my phone. I'll check with desktop, thanks
      05-05-2020, 03:25 PM   #13
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
Originally Posted by firetitanx View Post
Hi Steve
Thanks
Yes, the reflection of the speaker grill is rather annoying, and I haven’t yet played around with camera angles and filters. I didn’t have this problem with a similar setup in my F30.
I’m not sure a filter will get rid of the reflection, but I’d be interested in purchasing one if it does the job. I haven’t researched this at the moment.
I’m using a Blackvue 128 GB SD card. I’m not sure why they are supposed to better than other cards, but it was convenient for me at the time to get all Blackvue kit. Having said that, I almost bought a SanDisk card. I have found these to be fast and robust in other applications such as DJI Drones.
If you want to increase time on the card, you can drop the quality and frame rate a little.
With regard to degradation, I used the same Blackvue SD card in my F30 for 7 years. It never failed, but I used to reformat the card every now and then........not once a month as was suggested.
Last thing......no funny message on the BMW display, and no messages regarding battery drainage (for obvious reasons).
      05-05-2020, 03:28 PM   #14
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
I’m sorry the video is not performing properly for you.
I have just viewed it from the Post on my iPad and it looks fine to me.
If you’re still having problems, I can find the link on YouTube and post it for you.
      05-05-2020, 11:08 PM   #15
firetitanx
firetitanx's Avatar
100
Hi Steve ah thanks for that feedback.
If you goto https://dashcamsaustralia.com.au/sho...-cpl-filter-2/
You will see in the video the guys shows the difference between dashcam with and without filter, it seems as soon as he puts on the filter, the reflection gos away, so well worth investigating it's $50
I was looking at the samsung 128GB Pro Endurance which is recommended for continuous recording, on that dashcam web site they don't recommend sandisk though.
Great to hear no issues with cellnet and blackvue installed , warms the cockles of my heart
Ah yes and reformatting I did'nt think you needed to do it every month.
Be careful with reducing the resolution fro 4K though, my friends car was in a trolley hit and run while parked and the numberplate came out but he installed the non 4k dashcam so numberplate was just legible, if he had installed the 4k one then he would of had no issues so that is a consideration.
Thanks
SteveAus265.50
      05-06-2020, 01:16 AM   #16
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
Thanks
Thanks for the tip on the polarizing filter. It’s much better than I thought it would be. I’ll be getting one, for sure.
Yes, like you, I’ll be leaving my cam on 4K.
I was surprised that the SanDisk has such a poor reputation. I have been using fast SanDisk SD’s in a 4K drone for a couple of years. The drone gets very hot after 30-60 minutes of flying but I have never had a failure. Admittedly, I usually format the card once full and downloaded, not continuous recording as is the case with a dashcam.
      05-16-2020, 06:59 AM   #17
firetitanx
firetitanx's Avatar
100
Hi Steve
I was just doing some more research, they are dropping the price of the 900DR 2CH on dashcams australia I think the new 900x is coming now.
It includes.
1. Better thermal design (i.e more holes in the plastic
and a metal carbon tubing surround to dissipate heat,
2. Able to connect to an 4G LTE box in which you can place a nano sim
Have a look
Does not help you aargh, but for newbie buyers I think they should wait now until the new one comes out.
Having that 4G LTE box (CM100LTE I think it's called ) is very useful as you can remote connect via your phone to watch your car at any time and receive real time sms/email alerts on any incident.
Slideit49.00
BMW11279.00
      05-18-2020, 01:15 AM   #18
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
Hi Steve
It includes.
Have a look
Bugger!! There’s always something new hitting the market.
Not to worry. I’m sure my expensive, ancient, defunct and decrepit 900S will work just fine for a year or two.
BTW, I bought the polarizing lens that you suggested. It works beautifully. Many thanks again for suggesting this.
      05-18-2020, 01:37 AM   #19
firetitanx
firetitanx's Avatar
100
Hahaha, yes technology its amazing nothing stops it !!
Ah that's great good to hear
      05-19-2020, 01:32 AM   #20
vlo238
Drives: BMW 330i ,17 Impreza,16 Pulsar
Hi Steve
It includes.
Have a look
Hi SteveAus
For the polarising lens did you get it for both front and back? Is there a big difference once installed?
Where did you also get it for as I may want to kit it for both cars
      05-19-2020, 01:43 AM   #21
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
Originally Posted by vlo238 View Post
Hi SteveAus
I just got a polarizing lens for the front camera as I was getting a lot of reflection off the dash speaker grill. I didn’t bother with the rear camera as the window tint took care of any reflection.
The lens makes a huge difference, especially in bright, sunny weather. It doesn’t cut out the reflection completely, but it is significantly reduced.
I bought the lens from dashcams Australia, as suggested by Firetitanx.
The link is below.
      05-19-2020, 01:52 AM   #22
vlo238
Hi SteveAus
The link is below.
Thanks SteveAus and firetitanx - I will get on it too thanks for the advice
