11-20-2020, 07:25 PM | #67 |
Rep 82
8 in. It came with the square 225 set of runflats. Like Barry said...it does rub in reverse on full lock...only with the spacers (13mm). Nothing crazy so I'm gonna keep em on.
11-20-2020, 09:03 PM | #68 |
Rep 404
Looks perfect 👌🏻
enginediver64.50 |
12-12-2020, 07:13 PM | #69 |
Rep 187
Been exploring the 245 fitment as well. It clears - 245/40 on 19 inch rim - with 0.25 inches (a small finger width) of gap to suspension strut.
Super close, but as enginedriver above said, no rubbing. It's 0.6-0.7 inches taller than OEM size but clears. Comes down to personal choice if it works for you or you want to consider a size down. Cheers, M |
enginediver64.50 |
01-09-2021, 01:56 PM | #70 |
Rep 252
Drives: 2020 M340 xi
Hi Guys,
I am getting a used 2020 M340 X in a couple of weeks. It has a square set of 18" 790M wheels with all seasons with 225 Turanzas all around. I know those tires won't look good, too skinny for the car. I am trying to avoid buying a new set of wheels right away. I am wondering your thoughts if I put 12/15mm spacer front/back. Or do you know if I am to change tires and go for a 245 tire on the 7.5 790 wheel? Thanks
2020 M340xi Portimao Blue
Retired: 2005 545i manual/2011 M Sport Coupe Manual/2011 M Sport Sedan Manual/2014 M Sport/ 2017 M Sport X MPPSK |
03-02-2021, 02:19 PM | #71 | |
Rep 11
APO
04-05-2021, 03:30 PM | #73 |
Rep 4
Can I get rims swapped out on a Lease for my 21 M340?
Wondering if the dealership will allow me to swap rims for $$. I got the car with the "cartwheel" rims and they hide the blue M Calipers. Anyone have estimated costs? |
04-20-2021, 11:20 PM | #75 |
Bashar
416
Rep 1,121
Wouldn't a 245/35/19 be better than 245/40/19 for the front?
There's a smaller % difference in diameter size vs stock. Also wouldn't the slightly shorter sidewall of the 35 be better to reduce sidewall flex compared to the 40? |
05-02-2021, 04:17 PM | #76 |
Rep 17
18x10 Supra Wheels?
Think these will fit?
Apex group buy: https://support.apexraceparts.com/hc...-Fitment-Guide Front comparison: https://www.willtheyfit.com/index.ph...=10&offset2=30 Rear comparison: https://www.willtheyfit.com/index.ph...=10&offset2=30 |
08-30-2021, 06:26 PM | #77 |
Rep 2
Mine also came with the 225/40/19 square setup (19x8 wheels). Those run flats are terrible, so I'm going for new tires soon. From what I see 235/40/19 should fit fine but I just want to confirm because all the tire sites (Discount Tires, etc.) flash warnings that 235s won't fit my model (M340i xDrive). Are those just default warnings because it's not the OEM size?
08-30-2021, 06:40 PM | #78 |
Rep 2,700
I run 245/40-19 on my 19x8.5 et30 Track/Winter wheels and just bought some 255/40-19 tires for next season.
I think 265/35-19 square could be possible with the right offset + additional camber. Apex are doing all the test fitting and stuff right now so we should have an answer soon.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
08-30-2021, 07:12 PM | #79 | |
Rep 2
09-06-2021, 02:52 PM | #80 | |
Rep 354
If you can, maybe a pic or two? My car came with the staggered MPS4s. 8 x 8.5 19" non run flats too. Wondering if i can go 245/40/19 x 265/35/19 or just settle for the 235/40/19 in the front like you did. |
09-09-2021, 10:35 AM | #82 | |
Rep 2,700
09-09-2021, 02:07 PM | #84 | ||
Rep 2,700
09-11-2021, 11:09 PM | #85 |
Rep 42
I come here with the sauceeee. 330I, but the wheelwell should be the same as a M340i
Took a few wheel spec here as reference and took a gamble on these FlowOne wheels on sale on TireRack, I think it turned out pretty good. Tires are some clerance 265/35-18 RE71R TireRack found in storage. Wheels and tire are both square setup. Car has since been dropped on Dinan Springs, no rubs or issues so far. Wheels are 18x9 +35 The front ended up needed a 5MM spacer cause it wouldn't clear the strut. |
09-13-2021, 11:43 AM | #86 |
Tourist
230
Rep 212
So I took my 2021 M340iX to the track with square 225 PS4S tires and took it to my limit.
I also met a BMW engineer at the track who confirmed my suspicion that staggered is generally worse than square from a performance perspective and is "only for looks," but that's not the point. What I can confirm is that square 225s, while fine for spirited road driving, do not cut it on the track. They seriously held me back. I would get about four laps in per session before the car started stepping out of line and kind of dancing around, and this at speeds below 100mph on sweeping cambered turns. The car itself is brilliant though. Held in with the novice group nicely until the tires got squishy. With a some strut braces and proper tires I could absolutely see hanging with the intermediate sessions. |
09-13-2021, 04:07 PM | #88 | |
Rep 42
