08-23-2020, 10:25 AM | #1 |
Rep 10
BMW m340iX G21 upgrade to G3X M-performance brakes
Hi
Upgraded my front brake setup to the G3X M-performance calipers and 395mm rotors. This is a bolt on upgrade, you only need to modify the dust plate a bit with a screwdriver. Also upgraded the rear rotor to the dotted version. Front calipers partnumber: 34106880679 + 34106880680 Front rotor partnumber: 34106887657 + 34106887658 Rear rotor partnumber: 34206896227 + 34206896228 Big thanks to blau3er for supplying the calipers and pads! And yes, the car needs a wash |
08-23-2020, 10:30 AM | #2 |
Rep 623
Awesome!
Looks great and I’m fairly certain that you are the first G2x owner to do the 395mm front upgrade from G30 G11 etc. So much better than the M Performance option! |
08-29-2020, 01:57 PM | #5 |
Rep 1,041
Looks great.
Almost did this myself using those calipers from the same seller but have decided to hang back for now & go 374mm as I want to keep the weight down. One question why is it only the rear disks have the slots?? |
08-31-2020, 05:33 AM | #6 |
Rep 10
Thanks!
I was considering the same thing, saving weight! - But again, it is a daily driver, and not at track weapon OEM discs, and it seams that I cannot get slotted front discs, or I was not able to find the correct partnumber. |
OM3RTA392.50 |
01-02-2021, 06:43 PM | #8 | |
Rep 623
The ///M discs bolt on, but the retaining screws do not line up. If you want ///M discs, then you can fit X3M / X4M discs to your car with the 395mm caliper you have - however, again, the retaining screw doesn’t line up. |
01-04-2021, 07:04 PM | #9 |
Rep 57
or just get these:
https://g20.bimmerpost.com/forums/sh....php?t=1787733 |
01-07-2021, 11:22 AM | #10 | |
Rep 623
They are VERY protective of their brand / unique parts... |
02-24-2021, 12:26 PM | #12 |
Rep 22
Anybody tried to fit rear g30 370mm brakes?
I have opportunity to buy full set from 540i, it's a 374mm front and 370mm rear Front is no problem, but I'm wondering if rear also fits |
06-28-2021, 09:04 AM | #14 |
Rep 428
Very nice. Did you guys have to upgrade the brake booster and master cylinder as well? Heard pedal still feels mushy or the same if you don't.
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive |
07-25-2021, 09:03 AM | #15 |
Rep 11
Did you find torque specs for the calipers? If you did where did you find the spec so I can find the number for my brakes. (Blue M brakes on the m340i)
07-25-2021, 10:21 AM | #16 |
Rep 2,700
Can someone confirm that you need 20inch wheels to run the 395mm setup ? I already have 374mm on my car and I don't see how bigger rotors could fit in the 19inch wheels..
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
07-27-2021, 07:32 PM | #17 | |
Rep 1,041
*edit* reply was for the rear set up of 370mm. Last edited by OM3RTA; 07-28-2021 at 04:42 AM.. Reason: Info correction. |
11-17-2021, 03:15 PM | #18 |
Rep 10
11-17-2021, 03:16 PM | #19 |
Rep 10
No negative brakepedal feel, if any the brake pedal feel is even better, and with 4 people in the car the amount of pressure to stop does not change, I'm very happy with the setup.
11-17-2021, 03:17 PM | #20 |
Rep 10
08-26-2022, 07:19 PM | #21 |
Rep 236
03-06-2023, 01:33 PM | #22 | |
Rep 10
Wheels are these: https://www.litespeedracing.com/vs10 Front brakes are from 5 series, rear is stock but with dotted roters. |
