Technical Topics DIYs and Coding Discussions Esys on G20
      09-10-2019, 09:28 PM   #45
calllka
Hi, yes, or LEGAL_DISCLAIMER_TIME in HU_NBT, but I can't find any of these. I have 7 CAFD under BDC_BODY, and I looked through all of them, but they all just have numbers and no names. The only one with name was the one for ASS. Am I doing something wrong? Using Esys 3.27.1.
Attached are two screenshots of what I'm seeing.
Thank you.
      09-10-2019, 09:37 PM   #46
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Thank you.
You need E-sysX or Launcher Pro 3.4+ in order to read ECU's from G20.
Launcher 2.8 does not have mapping.
      09-11-2019, 07:48 AM   #47
calllka
Thank you. I emailed Tokenmaster donation, so hopefully I'll get the Launcher Pro 3.4 soon. Do I use it with Esys 3.27.1 or do I need a newer version?
      09-11-2019, 05:21 PM   #48
CyclingBroStyle
CyclingBroStyle's Avatar
Sport plus code has anyone been able to do it?
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey
BMW CCA #522637 use me as a referral for BMW CCA
      09-11-2019, 09:10 PM   #49
Almaretto
Almaretto's Avatar
2374
You can use 3.27.1 or newer. I use it and 3.33.4.
      09-11-2019, 09:16 PM   #50
Almaretto
Almaretto's Avatar
2374
Launcher Cheat Codes have that as option.
      09-12-2019, 06:15 AM   #51
rajens00
Drives: 2019 330xi
I haven't done any coding since 2014 and it appears much has changed. May I ask what kind of cable you are using for the G 20 and where you got it?
      09-12-2019, 10:44 PM   #52
Almaretto
Almaretto's Avatar
2374
Same ENET cable can be used on F/I/G-series BMW's.
I have both made my own and purchased. I like these. They have thicker CAT5/6 for durability, Velcro for easy storage, and metal contacts. Similar ones are found on Ebay and Amazon.
      09-20-2019, 09:31 AM   #53
kon
Singapore
21
Drives: F30 310i > G20 310i
No cheat sheet, but there are launcher cheat codes.
Two generations newer ECU's. So, you will need Launcher Pro or E-sysX to read.
All those can be done.
I'm finally going to code the vehicle this weekend.
Have esys 3.27.1 + PSDZdata 4.18.22 + Launcher Pro 2.8.2
To code, to do FDL coding, do we just "on" the car (like how F30 coding were done), or need to press the 'start engine button' thrice to enter diagnostic mode?
TIA!
      09-20-2019, 09:33 AM   #54
kon
Singapore
21
oh no!
      09-20-2019, 11:34 PM   #55
Almaretto
Almaretto's Avatar
2374
TIA!
Pro 2.8.2 will not do you any good for coding a G20.
Engine should be on, unless coding engine ECU.
      09-21-2019, 09:38 AM   #56
kon
Singapore
21
Finally have a taste of the problems. Lol
Triple press or with engine running could get 24 ecu. With just a press to "on" the car only return 20 ecu.
Error on dkombi read (missing file)
ihka were all flat numbers without description.
Dme try to code away auto start stop. Found the option change to werte 01. Coded successfully, but nothing happen. Fearing the 'translation is wrong, recoded back to werte 0
Need to patiently find new launcher pro and new psdzdata
      09-22-2019, 06:58 PM   #57
mrgicm
mrgicm's Avatar
441
Drives: BMW M
Does anyonw know with live cockpit is there a Alpina version option to be coded in D Kombi?
      09-23-2019, 09:21 AM   #58
Who's on first
Who's on first's Avatar
Drives: A-10C
There is.
      09-23-2019, 12:04 PM   #59
CyclingBroStyle
Originally Posted by Who's on first View Post
There is.
How did you do that??
      09-23-2019, 12:06 PM   #60
Who's on first
Drives: A-10C
There is.
Reach out to Almaretto he will square you away.
      09-23-2019, 12:09 PM   #61
CyclingBroStyle
There is.
I have so many questions! do you know how to code sport plus? Can it be done?
      09-23-2019, 12:17 PM   #62
Who's on first
Drives: A-10C
There is.
Lol.
It's OK to have so many questions everybody needs to learn at some point not to mention things are always changing.
Send Almaretto a PM, he will convey to you what's available to code.
There's more options available than most people think on the G20.
      09-23-2019, 01:56 PM   #63
Almaretto
Almaretto's Avatar
2374
Yes, Sport Plus can be coded.
      09-28-2019, 12:37 PM   #64
unclez
Drives: VW
Do you know if it is possible to code HBA?
      09-28-2019, 12:47 PM   #65
Almaretto
Almaretto's Avatar
2374
If car has hardware, then yes it can be added.
      10-04-2019, 01:12 PM   #66
calllka
Hello,
Do any of the cheat codes work with G20? I'm using the latest launcher pro, and downloaded latest cheat code xml files, however when I'm in esys, no matter which module, it always shows "Found 0 code for current ECU". The drop down for Author just shows All, and nothing else. Does that mean that Esys is not seeing the xml files, or is it because it's G20?
Aside from that, I've been able to code things that I manually found, like removing the disclaimers, etc...
Thank you.
