BIMMERPOST Universal Forums Off-Topic Discussions Board Photography/Videography *OFFICIAL* general photography conversation thread
      05-12-2016, 01:27 PM   #5083
dcstep
Drives: '09 Cpe Silverstone FR 6MT
2009 M3  [8.40]
Originally Posted by Mik3ymomo View Post
Also the autofocus systems are good but they rely on contrast and sometimes you won't get really good contrast. Lastly some lenses have such razor thin depth of field like say a 50mm F1.2 or an 85 F1.4 that you will want to focus it yourself for the best results.
For instance; shooting people. It's difficult to get the camera to focus directly on the eye. It wants to pick up the cheek or nose or forehead/hair etc. with a very thin DOF you run the risk of getting the eyes soft in the shot. My opinion is that the eyes should be the sharpest part of a portrait or animal.
The more you shoot with your equipment the more you will realize it's shortfalls and do your best to work around them for the best images you can produce.
The thinner your DOF the more you need AF! I routinely shoot super-telephotos at 500mm to 1,000mm (1600mm equivalents) and, even at f/8, DOF is razor then. You can get a bird's eye in focus and the end of its beak will be out of focus. I tried MF and it just doesn't work fast enough.
Steering the AF point or sector is the key to getting the part that you want in focus. Either steer, or focus on the eye and recompose. Those are techniques that any portrait photographer must learn. (Even more true for us wildlife photographers).
Dave
      05-12-2016, 02:13 PM   #5084
Weebl
Weebl wobbles but eats Pie
95
Drives: 2012 X5 d,2008 335i, 2000 740i
This is thin dof, 2.8
Kevin Goto
2000 740i-Annalisa (sold 2018) 2008 335i-Weebl. Weebl may wobble but has DTC 2012 X5d in Sparkling Bronze ( The Ultimate Cat Carrying Machine)-RIP BMW buyback 2019:2017 A3, 2018 Audi SQ5
      05-12-2016, 02:17 PM   #5085
dcstep
2009 M3  [8.40]
She probably thinks it's plenty deep.
      05-12-2016, 03:32 PM   #5086
jtodd_fl
2nd Asst to Dept Undersecretary
jtodd_fl's Avatar
6704
Drives: People crazy
2015 F82 M4  [9.00]
2016 F87 M2  [0.00]
2011 E92 M3  [0.00]
Love shallow DoF shots. A big fan of good bokeh.
Here is an experimental shot (bummer there was an artifact on the inner lens, so it hosed the shot).
Bachelor Button in Bloom - Michigan
This space for rent.
      05-12-2016, 03:42 PM   #5087
dcstep
2009 M3  [8.40]
Yeah, too bad. You can clone most of that out, if you want to rescue it.
      05-14-2016, 11:28 AM   #5088
justanotherdude
justanotherdude's Avatar
Drives: 2010 AW 328 [Sold]
2010 BMW 328i  [0.00]
Well, it's in the final stages at the moment unless I decide to add more presets to the package. Currently sits at five matte-influenced presets. I might try to add a few more but I'm not sure.
Still on the fence about releasing it.
      05-14-2016, 08:22 PM   #5089
Mik3ymomo
Mik3ymomo's Avatar
206
Drives: 540i XDrive
Dave
I couldn't manual focus a twitchy ass bird's little eye in flight if my life depended on it. I'm speaking about portrait photography and static photography of people and animals. Also night photography/Astro photography.
Plenty of times I've missed focus on the eye with my 200 F2 lens if I wasn't close enough to get a focus point on an eye. The focus point covers too large an area to zero in on the eye in those situations, I end up having to dial it in a bit.
You could prob trick a prime lens with autofocus if you changed the in camera lens adjustments to back focus slightly. That way if it focuses on the nose of a dog/coyote/wolf looked directly at you; you end up with the eyes in focus. I would need to calculate where the 200 F2 DOF is compared to the 500 F4 but it can't be any deeper. Great for isolating the subject... Easy to miss the exact target unfortunately. I have plenty of wolf shots with the forehead or nose in focus but the eyes were soft. Autofocus is great if you are close enough to get it entirely on the eye. Not always possible...
      05-14-2016, 08:25 PM   #5090
Mik3ymomo
Mik3ymomo's Avatar
206
Drives: 540i XDrive
This is an easy fix if you want to send me the original file.
It's my user name at yahoo
      05-14-2016, 08:47 PM   #5091
dcstep
2009 M3  [8.40]
I would like to add that there are times when you will need to manually focus. If you shoot at night and set up long exposures, do time lapse's and light painting you will very likely need or will absolutely need to manually focus the lens and completely shut off the autofocus system.
I'm not "getting" your problem. Are you using single-point AF and steering the point around (to the eye)? Alternatively, you can focus on the eye, using center-point and then lock focus and recompose. Getting human eyes in focus should be a piece of cake.
I find that you need enough DOF to get an eye in focus and also the end of the nose. Anything behind the eyes tends to be acceptable. Preview to see actual DOF. You can still get good bokeh at f/4, if you need the DOF.
      05-15-2016, 07:33 AM   #5092
jtodd_fl
jtodd_fl's Avatar
6704
2015 F82 M4  [9.00]
2016 F87 M2  [0.00]
2011 E92 M3  [0.00]
Thanks. Appreciate the offer. I may toy around with post-editing a bit. If I need help, I'll drop you a line.
      05-15-2016, 03:14 PM   #5093
justanotherdude
Anybody here use Back Button Focusing?
      05-15-2016, 03:21 PM   #5094
dcstep
2009 M3  [8.40]
I tried it and didn't see the point; however, I have several friends that swear by it. You still need to steer the AF points or lock focus and recompose. Maybe someone that successfully uses it will comment. It's certainly easy enough to try. Try it for a couple of days, at least, to give it a bit of time to become second nature.
Dave
      05-15-2016, 04:12 PM   #5095
jmg
jmg's Avatar
18659
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
You mean changing the focus button to another button rather than the shutter rel are button? Yes I use that primarily. It allows me to focus on something and then center balance the light meter.
      05-15-2016, 04:54 PM   #5096
justanotherdude
Dave
I just reconfigured my camera to it yesterday. Figured I'd take it for a spin and decide.
      05-16-2016, 09:34 PM   #5097
Mik3ymomo
Mik3ymomo's Avatar
206
Drives: 540i XDrive
It's probably my style of photography... As in I'm lazy to switch from servo focus because of how much racing I shoot. I could probably stand to shoot with you and see how you do it.
I pretty much never change my focus types or settings. I hate the focus tracking where the focus point seems to jump all over the place willy nilly.
I just manually move the focus point around with my thumb. Sometimes it can't move to place I need it so I shut off the auto focus. Manually focus where I want it to focus and recompose.
How's that for a clunky method?
      05-16-2016, 10:23 PM   #5098
Pixel8ed
Pixel8ed's Avatar
Drives: 08 328i
Been doing it since they allowed the swap in the firmware. Would never go back to a one button action.
How useful it is depends on what you shoot. I do mostly studio work or location shoots with models. So speed is not a problem. I can see where for sports or birding it would be a problem.
      05-21-2016, 04:05 PM   #5099
justanotherdude
Alright next question, anyone use a graphic tablet to edit their photos?
I bought a Refurbished Wacom Intuos recently and have started using it but I'm not entirely sure how I feel about it. I'll admit there's some increased control when using the brushes but since all I really use is Lightroom, I'm not sure if it really justifies the tablet. I don't heavily rely on the brushes to begin with.
      05-21-2016, 05:42 PM   #5100
Pixel8ed
Pixel8ed's Avatar
Drives: 08 328i
Tablets are hard to get used to. The disconnect of not looking there your hand is working can be a tough challenge for some. Often you get to the point of wanting to throw it away before your brain starts to put it all together. Once it's on board it is no effort at all. I know some that use the tablet instead of a mouse now.
I am left handed but use the mouse in the right. So I am able to be super efficient with motions as I use the tablet on the left and the mouse on the right.
      05-21-2016, 07:00 PM   #5101
08njSTEP
08njSTEP's Avatar
795
Drives: '07 335i, '66 SS396 Chevelle
I'm kinda new to nonautomotive photography. So I was walking around a couple of old buildings today taking shots. One is an apartment building so there were a few people around. 1group asked if I was a cop....? Really I've got shoulder length grey hair. Another commented "what another foreclosure?" And lastly, "do you have a website?"
Nope, just walking around taking pics for grins and giggles.
Just figured I'd post a new experience.
      05-21-2016, 07:34 PM   #5102
justanotherdude
The only benefit I've noticed is the button shortcuts I have programmed, and like I stated the increased control of the brush when I'm zoomed in. The disconnect wasn't bad but lately Lightroom has started to lag in general, so I'm not sure what the issue is. Laptop might just be getting too old.
      05-26-2016, 03:55 PM   #5103
druu
Drives: 2020 M8
It was a weird change for me, but after using it for certain people photos where i want nothing to change i find a use in it. I still think its a little clumsy though.
      05-27-2016, 04:02 PM   #5104
Pixel8ed
Pixel8ed's Avatar
Drives: 08 328i
It definitely can be clumsey. There is no one way that is perfect for everything. But I have been doing it so long I could not function without it. I think it is just a muscle memory thing at this point.
