Technical Topics DIYs and Coding Discussions G20 Grill Replacement Guide
      10-22-2020, 08:09 PM   #89
VipinLJ
VipinLJ's Avatar
Originally Posted by Merami fan View Post
Looks pretty good. Will stop by autozone soon.
I like the blacked out 330i and xDrive badge delete. Considering deleting both on mine. I don't mind the red reflectors, though, given that they fit the design and somewhat match the tail lights. Window trim will be blacked out soon.
View post on imgur.com
I'll PM you instead of taking this thread OT
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      10-23-2020, 02:23 PM   #90
OM3RTA
391
Mission failed successfully! I gave it 10 more minutes, got stuck in the same place, then called for help. Much easier with 2 pairs hands, but we noticed 2 things:
1. The clips were pretty tight and hard to get fully through the slots. Had to use a lot of force and push them down with a screwdriver, even after pulling them out partially. I think a trim removal tool would have helped here, as you said.
2. It took more force than I would be able to exert with one arm used holding down a clip if I were doing it alone. He said he gave it about 80 pounds of force.
I did follow your advice and tape it, and that may have saved my paint. It definitely came off at a downward angle and easily could have hit the paint. Thanks for all the advice and encouragement!
Please excuse the holes in the bumper. I don't know why dealers put these horrible, horrible plastic plate guards on such beautiful cars. Especially with such big screws... I will switch to a thin frame or no frame once I get my actual plates--still on temps.
Well done for persevering with it, it looks 10x better
      11-28-2020, 03:52 PM   #91
iNcorruptible
Drives: BMW 330xi 2020
Angry Grill with brown hue?
Hello,
I brought replacement black grills and installed them earlier today. Looks great, but in direct sunlight there is a clear brown hue to them.
Has anyone noticed that too or did I get duds?
      11-28-2020, 04:01 PM   #92
Merami fan
めらみぽっぷ fan
Merami fan's Avatar
Drives: 2020 330i xDrive
Originally Posted by iNcorruptible View Post
Hello,
Where did you get the grill from? There shouldn't be a hint of brown; the OEM grill is very, very black.
Username and profile picture in admiration of the goddess of treble, めらみぽっぷ (Meramipop).
https://www.youtube.com/watch?v=fQYWhQXOeQg
https://open.spotify.com/playlist/1w...1L3y6cmPEyGSoI
      11-28-2020, 04:03 PM   #93
iNcorruptible
Thanks for letting me know. I got them from PartsGeek (Action Parts brand)
      11-28-2020, 04:37 PM   #94
Merami fan
めらみぽっぷ fan
Merami fan's Avatar
Probably a Chinese replica. An OEM part should have a sticker with the part number on it. I guess it doesn't really matter--send that shit back. You can get a genuine part for sure here if you don't want to chance it again with PartsGeek: https://www.bimmerworld.com/Shadowli...138072085.html
      11-28-2020, 04:45 PM   #95
VipinLJ
VipinLJ's Avatar
Mine is pure black too. It is an OEM black grill with the sticker and part number on it.
      11-28-2020, 05:04 PM   #96
iNcorruptible
Thanks. Just ordered the bimmerworld part. I guess you always get what you paid for!
      01-25-2021, 08:54 AM   #97
rblackb@yahoo.com
Drives: BMW 330xi 2021
2021 BMW 330xi  [0.00]
Thanks for posting the installation guide!!
I couldn't find any information on the internet and stumbled upon your post. Also glad to find the BIMMERPOST site!!
      01-26-2021, 08:40 AM   #98
k4sh_90
k4sh_90's Avatar
Drives: 2020 BMW M340i xDrive
Originally Posted by G20NZ View Post
For those interested in a bit of diy, the chrome surround separates from the slats with just a few push clips once you get the grill off so it's super easy to repaint the factory surround black.
I may end up trying this. I would like to have the F-series style vertical slats, but keep cerium gray surround
      03-05-2021, 11:50 AM   #99
Jasperistops
29
Drives: BMW 330e m sport
Sorry to open an old thread again but I've just took delivery of my g20 and the first thing I have tried to do is change the grille. The heat shield is slightly different now and has 4 clips and 4 grommets. I've tried to get the grille off but I cannot release the side clips. I get all the top clips out but the side ones are stuck fast. Any advice before I try again
      03-05-2021, 12:13 PM   #100
VipinLJ
VipinLJ's Avatar
Yup. The clips on the side are the ones that are a pain to remove. What I did was shine a light in through the gap to see exactly which clip I had to remove (there are two clips; one holds the entire grill to the car and the other one is for the outer chrome part to attach to the rest of the grill). Once you figure out the correct clip (the one holding the entire thing to the car body), use a trim removal tool to push and prod at it to dislodge it. Took me around half an hour for the one clip on the left (when you're looking at the car from up front). Once that was out, the rest of the grill came off easily and the clip on the right only needed some wiggling and pulling before that popped out too. Frustrating experience and I don't think I'll be doing it again
      03-05-2021, 12:31 PM   #101
Jasperistops
29
Cheers for the info. I'll give it another go tomorrow. It seems as if when removing the top clips it's putting pressure on the side clip. Absolute pain
VipinLJ1936.50
      03-05-2021, 01:21 PM   #102
VipinLJ
VipinLJ's Avatar
Yes it does. Makes the clips on the side tighter. But that can also help when you're trying to remove it since there's enough pressure to slightly dislodge it. It needs a lot of patience which I kinda lacked towards the end. Lol
      03-07-2021, 02:30 PM   #103
Jasperistops
29
Second attempt but success at last. Like someone mentioned earlier,it's all about having the nerve to give that extra pull.
VipinLJ1936.50
      04-27-2021, 10:30 AM   #104
adam.b
Drives: iX3 Premier
I have noticed that I'm missing plastic covers/panels which are showing in first post over front headlamps.
My is 320i Mspotr 2021model uk.
Any one else noticed this?
      06-04-2021, 06:47 PM   #105
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
I have a 2020 M340 with parking camera in the front.
I got a gloss black grill to replace the cerium gray and can't wait to install as per this thread. The new grill came with a couple of pieces that look like they be for the camera.
Can anyone help me with what pieces are used? How they fit on the grill? And any other tips?
Thanks!
Al
Retired: 2014 328i
BMW CCA
      06-04-2021, 07:23 PM   #106
Merami fan
めらみぽっぷ fan
Merami fan's Avatar
Bit of a late reply, but that was changed at some point during production. Nothing to worry about. Not like the plastic bits really did anything.
Hi,
Thanks!
I thought the only difference is the hole for the camera. What do the other pieces look like? The grill itself seems to be just one piece.
https://www.bimmerworld.com/Shadowli...138072086.html
      06-05-2021, 05:50 AM   #107
RSnic
RSnic's Avatar
Merami fan ,
I got a gloss black framed grill with the diamonds from eBay.
Here's a picture of what I am referring to
Appreciate any help!
Al
Retired: 2014 328i
BMW CCA
      06-05-2021, 09:48 AM   #108
Merami fan
めらみぽっぷ fan
Merami fan's Avatar
Merami fan ,
Oh, it's not OEM. Looks like they designed it to work for all G20 models (camera or not) rather than 2 separate designs like the OEM ones. I'm guessing you just pop or slide the piece with the hole into the obvious spot, then secure it with the small piece.
https://i.ebayimg.com/images/g/x54AA...Dj/s-l1600.jpg
RSnic657.50
      06-06-2021, 09:04 PM   #109
Tskyline
Tskyline's Avatar
Drives: G20 Bmw 330i
Great results but..
Does anybody know how to remove the side chrome trim? I tried couple times with a plastic trim remover but got scared to scratch. At this point I don't want to leave it like this because it looks weird with the chrome. Open to any ideas.
Much appreciate Op for all this info.
TK
      06-13-2021, 02:31 PM   #110
RSnic
RSnic's Avatar
Installed a Hybrid Black Grill
Hi,
Well, I may be the odd duck here, but I got used to the diamond patterned grill, BUT I must admit that I tired of the Cerium Gray surround (as well as the other applications of it on my car). I opted to go with Gloss Black surround with the brushed chrome diamonds.
Found a seller on eBay who provided me instructions on installing two small pieces (a hook at the top of the grill & the center piece that holds the parking assist camera). If anyone would like, I'll be happy to pass along that How to guidance.
Once I got those two pieces finally installed, I followed PigWig earlier post and a KiesSport Video -- and in all honesty, that was the easy part!
Anyhow, here's a before (with old Cerium gray surround grill) and after (with gloss black surround) pictures.
Al
Retired: 2014 328i
BMW CCA
