Technical Topics DIYs and Coding Discussions Your BMW Might Have A Hidden TESLA Mode?
      01-25-2020, 11:32 AM   #45
Basti@G20 320D
Basti@G20 320D's Avatar
Sweden
25
Drives: E30, E36, E46, F30, G20
Originally Posted by RoboPapa View Post
Has anyone with an early 2019 build G20 vehicle with the Driving Assistant Professional option actually got the Enhanced Assisted Driving View fully working through Coding?
I believe it was only enabled by BMW for builds from July 2019 onwards.
Could anyone clarify this from experience?
Thanks.
I am not sure when my car was build but i picked it up 30 Juli 2019, and I coded driving view and lane change assistant
      01-25-2020, 04:09 PM   #46
RoboPapa
Drives: BMW
Thanks for that but I’m trying to identify if this works on vehicles built earlier in 2019 as other posts have suggested that it doesn’t especially if built before July 2019.
Anyone else able to comment?
      01-25-2020, 04:16 PM   #47
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
There is a sticker on the door pillar (beside the tyre pressure sticker) which shows the month the car was built.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      02-06-2020, 02:39 PM   #48
matbl
Drives: G31
So will a G2x built AFTER July 2019 with driving assistant pro have this enabled from the start?
Or is coding still needed?
      02-06-2020, 04:19 PM   #49
hamera
hamera's Avatar
442
Drives: 320i M Sport (G20)
Still needs coding.
      02-07-2020, 04:00 AM   #50
matbl
Drives: G31
Originally Posted by hamera View Post
Still needs coding.
That doesn't match this stated on the first page of this thread.
Cars that were produced during and after July 2019 came with the active driving assistant view functionality enabled (if they had the proper package).
Cars produced before July did not have the active driving assistant view feature and, even after upgrading to the same (or greater) software version, it still is not enabled. It may be a bug or it may be intentional that it's not enabled for pre-July builds, but either way this coding exercise will enable it (again, assuming you have the correct driving assistance package). I have not seen any evidence that post-July builds have hardware changes.
      02-07-2020, 09:06 AM   #51
king YU
king YU's Avatar
Drives: G20
I was able to activate this
      02-07-2020, 09:55 AM   #52
AtticusHoy
Still needs coding.
Why the question marks? If your car was built before July 2019, but has the Driver Assistant Professional package, then you must unofficially code/alter your car in order to enable the Active Driving Assistant View. As of February 2020, there is no official software upgrade that will enable the View for you even if your car is capable of using it.
My original point was this could be a feature (buy a post-July build!) or a bug (oops it should be enabled for all cars with the Driver Assistant Professional package)—but it sounds like they're touting it more as a feature as this point.
Which I think is a terrible strategy, but given BMW's current software and services problems might actually be for the best.
      02-07-2020, 12:11 PM   #53
hamera
hamera's Avatar
442
Let me explain. I'm talking about coding lane changing feature. The assisted driving view is available in cars made July 19 and after but the lane changing feature isn't available without coding.
      02-07-2020, 12:34 PM   #54
matbl
Drives: G31
Aha. Got it, thanks.
Wonder why lane changing isn't activated though. It's on the 5 series..
      03-02-2020, 03:47 PM   #55
duraace
Drives: G20 320d
Can this be coded with bimmercode?
      03-09-2020, 05:56 PM   #56
Deltusurf
Member
Drives: Arctic White 650i, 2020 M340i
2013 BMW 650i  [0.00]
I feel like a moron, I can't even get Launcher Pro... Go to the website... watch the video click everything clickable and nothing. Where do I go to email Tokenmaster? I'd love to try this FDL coding but E-sys is requiring a token.est file.
If anyone can dumb it down for me, I'd appreciate it.
I have followed the links on other pages and must be missing a step.
Thanks
Update-
Since I posted this earlier... I've found a gmail address. Hopefully this will work.
      03-10-2020, 03:23 AM   #57
Basti@G20 320D
Sweden
25
You cannot use Bimmercode to code it.
      03-10-2020, 08:28 PM   #58
oln08
Drives: '19 M2
Yes you can code the "Driver Assistant View" using bimmercode, I just did this today and worked perfectly.
This is courtesy of zachart. I just posted his instruction here for me because I don't know how to link this to his thread.
QUOTE by zachart
- go into Expert Mode in KOMBI ECU
- search for each parameter (there is a search box)
- change
- Code
CB_FZG_UMGEBUNG_FAS: aktiv (01)
CB_PRESELECT_NAVI_ANSICHT_FZG_UMGEBUNG: aktiv (01)
PIA_FZG_UMGEBUNG_FAS: aktiv (01)
SICHT_ABSICHT_ENABLE: aktiv (01)
This is the guide I followed - I didn't have a PIA_FZG parameter so I only changed the three things and it still works for me.
Same as his situation, I did not see the PIA_FZG also, so I skipped that and still worked for me.
Now just waiting for anybody to figure out how to code "Lane Change Assist" using bimmercode.
haruny96.50
      03-12-2020, 01:48 AM   #59
902
Drives: 2020 M340i xDrive
QUOTE by zachart
- change
- Code
You need the beta version of BimmerCode to code this. It's not available in the public version yet.
You can't code the lane change assist in BimmerCode, at least not yet.
      03-12-2020, 07:25 AM   #60
oln08
Drives: '19 M2
QUOTE by zachart
- change
- Code
huh? Mine is paid version of playstore and did it without a problem. Quite sure I dont have the beta.
      03-12-2020, 11:03 AM   #61
902
QUOTE by zachart
- change
- Code
Just checked, you're right. They released the android version only. The iOS version still hasn't been released. Those features have been in beta for a while though.
      03-20-2020, 10:25 AM   #62
Oniongc
Drives: 2019 g20
Thanks
Update-
@Deltusurf did you have any luck/response with the email you found?
      03-22-2020, 06:52 AM   #63
Deltusurf
Member
I found his name at gmail, but haven't heard anything yet. It's been a few weeks.
      03-22-2020, 04:57 PM   #64
Oniongc
Drives: 2019 g20
@Deltusurf
Yeah same with me. Has anyone tried one of the eBay purchased pro launchers? Do they work or are they scams?
      04-30-2020, 04:55 PM   #65
sztmek
Drives: BMW 3 G20
Hi mates! Is there actually possible to code assistance drive view via bimmercode iOS? My car doesn’t have assistant pro but I have 360 cameras and professional package. Car production is 03.2020 and last software is also 03.2020. Thanks in advance
      05-25-2020, 02:19 AM   #66
rockhach
rockhach's Avatar
12
Drives: Bmw 330i g20
Thanks.
Hey bro
I have a G20 330i built in April 2019..just coded the assisted driving view and works perfectly. I used bimmercode on my phone and went into expert mode to code it. Took me 5 minutes. Very easy to do. Lane change assistant was a different story. I couldn't find the right lines to change on bimmercode. Still trying to figure that one out but assisted driving view works flawlessly
