12-20-2019, 06:57 PM | #45 |
Rep 315
So for those looking for technical data on the new B46TU and B48TU engines. According to that .pdf, the engine in G20 is supposedly B46TU, not B48TU, but I thought B46TU was for American models only where the rest of the world has the B48TU? Anyhow, the summary of upgrades and differences between B46/48TU and B46/48 is very descriptively explained in this pdf guide.
https://f30.bimmerpost.com/forums/at...9&d=1553708460 |
12-20-2019, 09:56 PM | #46 |
1942
Rep 3,521
So basically what happened to my car was it threw a hissy fit while being flashed and refused to start once flashing was complete. I used a MacBook Pro with the firewall turned off and antivirus disabled. I downloaded the bootmod3 agent and went through their blog to make sure I was doing everything right.
Got the code, activated it, flashed the car like how they said. And bam. Car throws two errors that refused to go away even when I did online coding. Car was driven just before being flashed and it drove perfectly with zero errors. One error was a car in gear error where it said car cannot be idled when in gear. Weirdly, it showed that the car was in Park on the cluster and gear selector. Another error was a parking brake error saying it was parked on a steep roadway. Again, it was parked on level ground, inside my garage. Accessories turned on but my car refused to crank. I thought I’d give it a few minutes before trying again since I remember something similar happening in my VW long ago when it was flashed. Tried again after a bit but these two errors kept popping up and car refused to crank. This was when I started becoming tensed. Car was parked in the middle of the garage and I couldn’t park the other cars in the garage because of how I parked this one (to be closer to the wifi router). And it wouldn’t start at all. I flashed back to stock. Same issue. It said flashing was successful but these errors refused to go away. I mailed PTF. Lots of mails were passed back and forth to make sure I did it correctly. They even deleted my OTS map and sent me a new one to try reflashing. Flashed again with it for a third time. No luck. This was when I started to worry properly. I couldn’t keep spending more time since I had to get back and I was away for almost the entire day. I hoped leaving it locked in the garage for a few hours would fix it. Came back after 6 hours and no luck. I scoured through the internet in the meantime and people said that their cars sometimes fixed itself overnight. Mine didn’t even after 6-8 hours. I flashed back to stock again and locked the DME this time (4th flash). Still no luck. I then disconnected the battery in the hopes that that would help. Left it disconnected the entire night. I couldn’t sleep that night and my wife wasn’t happy about it. Plus it was her birthday the next day (today). And I was cranky. That didn’t work. I also messaged g20beam and Mike@xph in the meantime. Thank you very much guys! Next day, I wake up and go downstairs to reconnect the battery. Reconnected the battery and bam. The errors popped up again. My heart sank some more. It was almost 24hrs now with my car dead. I have lots of family here, visiting for Christmas and new year. And they could see I wasn’t happy. My father-in-law said he was almost sure it wasn’t the flash that caused it and it was probably a fault that popped up, unrelated to the flash. I think it was an unfortunate coincidence too. Just that it had to pop up right when the flash said it was completed. I was in touch with PTF all through. They had a lot of other customers to talk to as well. But I’m satisfied with their response time, all things considered. I messaged Mike again and he said he’d help me. I was contemplating taking my car to BMW and even called a service advisor there and he said he has never heard of this issue and asked me to call RSA and tow the car. I said I’ll bring it in on Monday. Mike and g20beam said it wasn’t a good idea and I listened to them. And finally, PTF said they’ll remote help me if I can get access to a windows laptop. Set one up like they wanted (but I couldn’t disable the firewall for some reason). Halim from PTF helped me out remotely and fixed the car in a jiffy. Honestly, it took more time to download Esys and winrar on that laptop to clear the issue. He asked me to start the car and I did and voila. It started. The parking brake error disappeared. He tried logging in to my bootmod3 but couldn’t because of the firewall. And he had to rush to help another customer. I drove the car around for a bit. Turned it off and on many times and it works perfectly. Unluckily, it is still flashed with the stock map. I’m too scared to try it once more, lest it happens again and PTF get tired of me Only problem is I know have an “i” on the lower part of the instrument cluster and a notification on my iDrive saying “Check control - Engine start only when idling”. It refuses to go away. It’s visible only when I pull down on the iDrive screen and with the “i” on the cluster. I’m going to BMW tomorrow anyway to check out an X3 for my wife. So thought I’d pop in and ask the service tech about it. But yes. PTF was very helpful. So were g20beam and Mike@xph. If I had taken my car in and not listened to them, I’d probably be stuck with a $6000 bill by BMW asking me to replace the DME or something. At first, I thought I’d return the tune and get a JB+ for the time being and maybe dip my toes in later. But my father in law wants to me to flash my car and see how it is (since he also likes anything that makes a car go faster). So I might try it again on Monday. But honestly, for the timebeing, I’m scared. But let’s see. Was the error due to the tune? I’m willing to hazard a guess and say no. It was probably just an unfortunate coincidence. Was I satisfied with how PTF dealt with me? Yes. Will I buy from Mike@xph again? Undoubtedly. |
01-04-2020, 07:51 PM | #47 | |
Rep 191
Maybe there will be some value checking the link below for information contained. This has me nervous to increase boost, HP and TQ for the 330i version of the B48. It seems BMW upgraded certain parts like the crank, pistons and bearings when increasing the HP and TQ for the mini etc. It would have been significantly cheaper for BMW to just have remapped the ECU to achieve the higher figures for highest HP and TQ B48 version if they thought it was safe as-is hardware wise. Thoughts? Click on ‘models’ drop down. https://en.m.wikipedia.org/wiki/BMW_B48 |
01-04-2020, 10:18 PM | #49 |
1942
Rep 3,521
01-05-2020, 02:10 AM | #50 | |
Rep 130
01-05-2020, 04:57 AM | #52 | |
Rep 191
Do we know what the stock boost level is for a 2019 and 2020 330i USA spec engine and non-USA spec engine? I wonder if the USA spec runs hotter / leaner because of emissions standard differences. So many questions. |
01-05-2020, 08:48 AM | #53 |
1942
Rep 3,521
01-05-2020, 09:07 AM | #54 |
Rep 191
What is pretty interesting is that back in the early-mid 1990s, DSM Eagle Talon and Mitsubishi Eclipse boys were running 300+ WHP/TQ with stock internals and limited bolt-ons, mainly just boost increases, fuel pump increases, etc. With 3” exhaust systems, uprated turbos and a few other minor bolt-ons they were running 400+ WHP/TQ on their 1990s technology level 2.0 litre turbos, some over 500. Even with direct injection, VVT / Vanos, etc., how much have we really progressed over the last 2+ decades? Quite a rabbit hole question as emission and mpg regulations haven’t helped. These DSM cars were under 3k lbs. and a little over for the AWD versions. Again, safety regulations along with more driving and entertainment tech hasn’t helped either.
This whole conversation takes me back to my JDM Sti7 days, worrying about fuel octane levels and safety of the engine while contemplating running higher boost than stock. How much of a hindrance are the current emissions components and MPG saving components costing us power wise with the B48? Another concern is to achieve higher mpg I wonder if these engines are running dangerously lean or if this is not a real issue because at WOT etc. they keep them nice and rich for safety and / cooling properties and the lean situation is only at highway constant speeds that requires minimum boost, etc. So much to discuss, so many rabbit holes but at the end of the day there is no free lunch to achieve power. Wonder how our block (aluminum) and internals stack up against those 1990 DSM cars. Last edited by Razor2010; 01-05-2020 at 09:12 AM.. |
01-05-2020, 09:39 AM | #55 | |
Rep 191
Would love to know exactly what engine is coming on my non-USA destined 2020 330i that is currently in production in Germany and what exactly the differences are between all these variations: B48,46,TU,D, etc. |
01-05-2020, 10:32 AM | #56 |
1942
Rep 3,521
I have the exact same doubt too regarding the differences between these engines. Or is it just a ploy by BMW to confuse us.
01-05-2020, 10:36 AM | #57 |
Rep 191
I could see different emissions requirements across different countries yielding different mapping profiles or adding in an extra CAT etc., but to have enough differences with the actual engine to cause a different engine number seems a bit odd.
01-05-2020, 01:32 PM | #58 |
Rep 191
Let’s get the discussions going, I know there must be some people on this forum with expert knowledge about tuning turbos, risks, etc. that can offer some knowledge on the B48.
Also, still searching for the stock boost on a 2020 non-USA spec 330i, no luck yet. I would guess with the compression somewhere around 15 psi? |
01-06-2020, 10:21 AM | #61 |
Rep 440
Wait, so whats the most effective way to figure out what engine we have??
Cant believe they would put the weaker engine in US cars. Those are the one that will most probably get modded anyway.
E36 318ti
01-06-2020, 11:13 AM | #62 | |
Rep 191
What I am concerned with is BMW thought it necessary to upgrade certain components: crank, pistons and bearings (see my post further up) for the B48 when it was put in certain car models for BMW and Mini that sold at 300+ HP stock. BMW could just have easily turned up the boost along with other mapping parameter tweaks to get to this 300+ HP but they spent extra money to install uprated internals obviously because they were worried about engine reliability at this 300+ HP. We all know they would have preferred to save money and just do the map change. So, my question and concern is, just how much further wear and tear are people doing by pushing the standard 330i B motor to 300+ HP, is it a little as would be expected, or is it quite severe, hence why BMW uprated the 300+ HP B4 engines from factory. |
A6bullet337.00 |
01-06-2020, 12:53 PM | #63 | |
1942
Rep 3,521
Power and torque are the same as euro spec cars. I guess different internals? |
01-07-2020, 01:43 AM | #64 | |
Rep 440
Like you said, if the internals had to be upgraded when pushing 300+ then maybe this needs more research? Maybe there are some weaknesses to the stock B46 parts, maybe just lower quality parts. IDK, maybe Im just being paranoid.
E36 318ti
01-07-2020, 01:44 AM | #65 |
Rep 440
Yours is 2020?
E36 318ti
