Technical Topics DIYs and Coding Discussions Coding More Ambient Colors And Amber Sidemarker Delete?
      10-06-2020, 12:56 AM   #199
takky
takky's Avatar
Thailand
18
Drives: 330e 2020 -->> m340i Lci 2023
Originally Posted by Joedeejay View Post
The issue is with 07.2020 software mate, you are on last July 2019 which is fine
From Bimmercode
The Android version will receive an update as soon as the mapping is available.
Kind regards / Schφne Grόίe
Stephan Gauch
Hope the app will get update soon!!! so bored with the original light.
      10-21-2020, 07:39 AM   #200
330e
330e's Avatar
Drives: G20
If you have ESYS you can upload CAFD from your BDC3 and upload here:
https://gryzunokbaby.ru/ambientbdc3/
and change colors
      10-21-2020, 04:36 PM   #201
mnavis29
Drives: BMW 435xD
and change colors
Is this working also for a G05?
      10-21-2020, 05:58 PM   #202
hkleyman
hkleyman's Avatar
Drives: 2019 BMW X5 50i M-Sport
and change colors
Yep, although the mappings are slightly different since G05's have more zones.
      10-23-2020, 03:49 AM   #203
330e
330e's Avatar
Drives: G20
Pink power :P
Poochie9099.00
ssgm1x417.50
      10-23-2020, 09:04 AM   #204
hottroc
Drives: BMW 330e
It would be nice if we could add more colours, as the post title suggests, rather than just modifying the limited number we have. Ie so we could have pink, red/blue, blue/red and all the original colours. Is there any way this might be possible?
      10-23-2020, 12:23 PM   #205
VipinLJ
VipinLJ's Avatar
I don't think so. The only way for now is to change whatever limited colors we have on the idrive. Adding is not an option atm.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      10-29-2020, 05:38 PM   #206
sztmek
Drives: BMW 3 G20
I can confirm that firmware 07.2020/54 with newest beta test bimmercode 11702 bring access again to 360A and 360D directory and mapping. My is iOS version on iPhone . Check it at your car
VipinLJ1936.50
takky18.00
      12-16-2020, 12:02 PM   #207
AmooManiak
Drives: 21 X5 M50i -> M2C -> 21 M5C
Sorry to bump this up, but does anyone know how to code out the sidemarkers on a G05? Recently upgraded to the Euro Spec laser headlights and got them coded, however I'm still getting the front sidemarker error message for the headlights...
      12-18-2020, 12:39 PM   #208
Joedeejay
Drives: BMW G20
Just to share my setup
Bytes 18,19,20 FF,00,00
Bytes 23,24,25 00,20,FE
Bytes 28,29,30 90,E0,90
Byte 2 01
Byte 3 03
Results in changing Bronze and White layout to Red door handle and pocket lights, blue light strips, blue footwell lights, white map dome lights
VipinLJ1936.50
oreoOozZz126.00
      12-21-2020, 03:40 PM   #209
HEBREWHAMMER0913
Drives: BMW 540
A. Under LIC_LCI_COLOR_LIBRARY_DATA (360A):
1. Original hex values:
Byte 18 - D7
Byte 19 - 6E
Byte 20 - 14
Byte 23 - D7
Byte 24 - 6E
Byte 25 - 14
Byte 28 - D7
Byte 29 - 6E
Byte 30 - 14
2. New hex values:
Byte 18 - FF
Byte 19 - 00
Byte 20 - 00
Byte 23 - FF
Byte 24 - 00
Byte 25 - 00
Byte 28 - FF
Byte 29 - 00
Byte 30 - 00
B. Under LIC_LCI_COLOR_PROFILES_DATA (360D):
Byte 2 - 01
Byte 3 - 00
Byte 16 - 04
Byte 17 - 00
New hex values:
Byte 2 - 01
Byte 3 - 03
Byte 16 - 03
Byte 17 - 01[/QUOTE]
I did this setup but I have panoramic sky lounge in my x5 and its red I wanted it to be blue any idea how to code that ?
      12-21-2020, 07:44 PM   #210
VipinLJ
VipinLJ's Avatar
Byte 18 - D7
Byte 19 - 6E
Byte 20 - 14
Byte 23 - D7
Byte 24 - 6E
Byte 25 - 14
Byte 28 - D7
Byte 29 - 6E
Byte 30 - 14
2. New hex values:
Byte 18 - FF
Byte 19 - 00
Byte 20 - 00
Byte 23 - FF
Byte 24 - 00
Byte 25 - 00
Byte 28 - FF
Byte 29 - 00
Byte 30 - 00
Byte 2 - 01
Byte 3 - 00
Byte 16 - 04
Byte 17 - 00
New hex values:
Byte 2 - 01
Byte 3 - 03
Byte 16 - 03
Byte 17 - 01
I did this setup but I have panoramic sky lounge in my x5 and its red I wanted it to be blue any idea how to code that ?[/QUOTE]
Do you have the same number of bytes in 360A and 360D as us G20 owners?
      12-22-2020, 09:31 AM   #211
hkleyman
hkleyman's Avatar
Byte 18 - D7
Byte 19 - 6E
Byte 20 - 14
Byte 23 - D7
Byte 24 - 6E
Byte 25 - 14
Byte 28 - D7
Byte 29 - 6E
Byte 30 - 14
2. New hex values:
Byte 18 - FF
Byte 19 - 00
Byte 20 - 00
Byte 23 - FF
Byte 24 - 00
Byte 25 - 00
Byte 28 - FF
Byte 29 - 00
Byte 30 - 00
Byte 2 - 01
Byte 3 - 00
Byte 16 - 04
Byte 17 - 00
New hex values:
Byte 2 - 01
Byte 3 - 03
Byte 16 - 03
Byte 17 - 01
Be careful setting zones to FF, there's a bug where if the two small ambient lights by the sunroof controls are set to FF, they will be dark after vehicle startup until you change the color.
Once shutting the vehicle off, it needs to fully sleep for around 15 minutes before you'll restart and see the lights don't come back. Again this seems to only impact the two small projector ambient lights next to the sunroof controls.
We found a workaround in the main tutorial and that's basically setting any value you want at full as FE instead of FF. You won't notice a difference in color but it avoids the bug.
Regarding the actual color of the light up sunroof itself, it's all trial and error. There are definitely some bytes in the mix that control them. I had to play around until I found which ones were which.
VipinLJ1936.50
      12-22-2020, 09:35 AM   #212
hkleyman
hkleyman's Avatar
Byte 18 - D7
Byte 19 - 6E
Byte 20 - 14
Byte 23 - D7
Byte 24 - 6E
Byte 25 - 14
Byte 28 - D7
Byte 29 - 6E
Byte 30 - 14
2. New hex values:
Byte 18 - FF
Byte 19 - 00
Byte 20 - 00
Byte 23 - FF
Byte 24 - 00
Byte 25 - 00
Byte 28 - FF
Byte 29 - 00
Byte 30 - 00
Byte 2 - 01
Byte 3 - 00
Byte 16 - 04
Byte 17 - 00
New hex values:
Byte 2 - 01
Byte 3 - 03
Byte 16 - 03
Byte 17 - 01
Do you have the same number of bytes in 360A and 360D as us G20 owners?[/QUOTE]
We have more in G05 and even more in G07. It's based on ambient zones within the vehicle. G07 has 3rd row zones and I'm assuming B&W stereos get additional.
      12-22-2020, 10:20 AM   #213
VipinLJ
VipinLJ's Avatar
We have more in G05 and even more in G07. It's based on ambient zones within the vehicle. G07 has 3rd row zones and I'm assuming B&W stereos get additional.[/QUOTE]
Yes. So one of those extra set of bytes probably changes the pano roof light. You'll have to change one of those to a code for a different colour. Or to white. And keep coding to find out which lights change. That's how I found out the combo in my car.
      12-22-2020, 10:51 AM   #214
hkleyman
hkleyman's Avatar
Yes. So one of those extra set of bytes probably changes the pano roof light. You'll have to change one of those to a code for a different colour. Or to white. And keep coding to find out which lights change. That's how I found out the combo in my car.[/QUOTE]
Correct I was answering the question as well, the quote looks strange. I have a G05, the user above has G20.
      12-22-2020, 12:00 PM   #215
VipinLJ
VipinLJ's Avatar
Correct I was answering the question as well, the quote looks strange. I have a G05, the user above has G20.[/QUOTE]
Sorry. I thought I was responding to HEBREWHAMMER0913 Looks like he has a G05 too.
      12-22-2020, 12:27 PM   #216
HEBREWHAMMER0913
Drives: BMW 540
Ok Im still so confused I just changed the codes to match jaimeen77 but I don't know where I would mess with the color in 360A or 360D ?
      12-22-2020, 12:29 PM   #217
HEBREWHAMMER0913
Drives: BMW 540
now that Im looking at it I think I just change the 360D to 00 somewhere is that correct ?
I'm also using the g20g21 profile and everything else gets selected should I be using the g05 one ?
      12-22-2020, 05:05 PM   #218
VipinLJ
VipinLJ's Avatar
Do you have a G20 or G05? If it's a G05, you should be changing the G05 (preselected) option.
      12-24-2020, 11:50 AM   #219
HEBREWHAMMER0913
Drives: BMW 540
I have the g05 but when I change the g20 it works
      12-24-2020, 03:00 PM   #220
VipinLJ
VipinLJ's Avatar
It works because it saves it as a totally new profile (saving the old original one) which is the one that is selected. But I thought the G05 had more bytes and hence more changes? I can't answer since I don't have a G05.
