Technical Topics Suspension / Chassis / Brakes What is the OEM Suspension Height for the M340IX?
      10-01-2020, 11:07 AM   #23
VipinLJ
VipinLJ's Avatar
I agree. Reach out to BMW Canada. Send them a nicely worded mail but make sure they know you aren't going to give up easily. Tell them what the dealership said too. Hopefully they'll have a solution soon!
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      10-11-2020, 06:06 AM   #24
DanVlnStud
DanVlnStud's Avatar
Drives: 2020 BMW M340i XDrive
Originally Posted by Burrcold View Post
I would call BMW Canada instead of going to each dealer. Most of them will say the same thing since they didn't do the initial repair.
Contacted BMW Canada, explaining the issue, and that I took it to and independent mechanic saying it was too high and I booked an appointment with Pfaff BMW in hopes to get things rectified, if not, please don't get discouraged for wanting to get out of this lease.
Pfaff reported that they fixed the issue, and ride height is to spec. I measured, and it’s still not to spec, maybe a half-inch lower but not to spec. I saw another m340i with the same wheels as mine, measured, and it came to 14.5, mine was at 15.2. I told the SA I'll just let BMW Canada know, and then he said before I do that, come back after Thanksgiving and talk to the foreman. What, so they can feed me more BS?
I also indicated that I had moisture in the headlight and rattling in the exhaust flap, and all they could say is that they found no moisture, and the noise is the flap was normal, and all M3's make the same noise.
The Independent mechanic said the exhaust has to be replaced, and there is no other fix, and moisture in the headlight is a severe problem.
All these dealers are full of shit man. why they hell won't they just fix the issues. It's under warranty, I dont get it.
      10-11-2020, 09:37 AM   #25
Gdiddy23
2015 BMW F30  [0.00]
Did you 100% confirm the shipping blocks were taken out?
2020 M340xi PB (sold)
2020 Ram 1500 Laramie (Daily)
2019 Shelby GT350R (Weekend)
      10-11-2020, 09:42 AM   #26
Burrcold
Drives: 2024 M3 Comp xDrive
That really sucks. 15.2-15.5 is the spec for a 330i xDrive with the base suspension (perhaps they're looking at the wrong specs?).
      10-13-2020, 06:55 AM   #27
DanVlnStud
DanVlnStud's Avatar
I even gave them 5 copies of the newtis spec sheets before handing it over to them. I'm heading over to pick the car up today and talk to the foreman so he can feed me some more bs that ill just add to the shit list of things that went wrong and then file a lease lawsuit
      10-13-2020, 06:56 AM   #28
DanVlnStud
DanVlnStud's Avatar
I even gave them 5 copies of the newtis spec sheets before handing it over to them. I'm heading over to pick the car up today and talk to the foreman so he can feed me some more bs that ill just add to the already long shit list of things.
      10-14-2020, 09:48 PM   #29
DanVlnStud
DanVlnStud's Avatar
How it currently sits side by side 2 other m340i's with a full tank of fuel.
      10-14-2020, 09:51 PM   #30
DanVlnStud
DanVlnStud's Avatar
how it use to sit
      10-14-2020, 10:24 PM   #31
VipinLJ
VipinLJ's Avatar
how it use to sit
Even my 330i with the base suspension doesn't sit that high!!!
      10-15-2020, 08:12 AM   #32
DanVlnStud
DanVlnStud's Avatar
Just measured mine and it's at 655mm front, and the rear is a little lower. Isn't that the spec for a base 330i?
Yes, that would be what the newTIS.info states and your measurements appear to be consistent with mine. FYI, the link I posted is for the M340i xDrive.
Consistant with yours? Do you work for BMW? Sounds like a load of bs they've all been feeding me. The numbers are so off, you may have thought im driving a base 330i, but my car is fact an m340i. Thanks for the spec sheets, that are no longer available to the public.
2020 M340ix
2017 Porsche Macan Turbo
2014 Audi RS4
2010 E60 M5
2006 Honda S2000
2001 Integra Type R
      12-17-2021, 12:44 PM   #33
yipching
yipching's Avatar
Drives: BMW M340i
It wouldn't be the first! I know lots of people who took delivery of cars with the shipping blocks still in place. I know of one guy who drove with it for 1000s of miles before realising it because his car looked high and the ride quality was horrible!
I know this thread is ancient, but I just discovered my M340i with 7,000 miles on it had all the shipping blocks in place... Sigh. You'd think a simple checklist could avoid this.
      05-07-2023, 06:59 AM   #34
DanVlnStud
DanVlnStud's Avatar
Attachment 2767673
Attachment 2767674
Apologies for the delay in seeing your post. I have a picture of something that appears to be similar to what you have in your picture. Could it be a shipping block that is still under the boot after 37,000km? If so, I would be very concerned. How did you manage to remove it?
2020 M340ix
2014 Audi RS4
2010 E60 M5
2006 Honda S2000
2001 Integra Type R
      05-10-2023, 09:43 AM   #35
Burrcold
Those are your bump stops. Don't remove them.
      05-10-2023, 10:41 AM   #36
G22b58
Drives: G22
I have an M440i so I can't give you measurements to compare to. But looking at your distance between the tire and the spring cup might indicate that the wrong parts have been mounted. I don't know of any pictures on M340 with standard tires but this post (linked below) shows a tire that (from nominal size) should have about 8mm larger radius. So assuming you have a standard size (e.g. 225/40-19) I would expect to see about 8mm more clearance in your picture. It looks more, doesn't it?
https://g20.bimmerpost.com/forums/sh...24&postcount=4
      05-20-2023, 10:59 PM   #37
DanVlnStud
DanVlnStud's Avatar
Thank you for sharing the picture. I appreciate your concern and the comparison you've provided. After carefully examining the picture, it's evident that there is a significant difference in the positioning of the wheel cup compared to my own vehicle.
I believe there may be an issue with the installation or alignment of the wheel cup, which is a cause for concern. I plan to address this matter again with my dealership to ensure that everything is properly aligned and in accordance with the manufacturer's guidelines.
2020 M340ix
2014 Audi RS4
2010 E60 M5
2006 Honda S2000
2001 Integra Type R
      07-26-2023, 03:33 AM   #38
Jamaicalandwelove
Drives: M340XI
I hope they fix it
