Technical Topics DIYs and Coding Discussions ESYS G20 coding - getting started
      01-24-2020, 05:00 AM   #111
Basti@G20 320D
Basti@G20 320D's Avatar
Sweden
25
Drives: E30, E36, E46, F30, G20
Bought EsysX and i can confirm it works like a charm .........no need to wait for any princes to responce to u.
I am just not sure about 1 thing, and that's how to get the cheat sheet downloaded,and how to use it together with EsysX?
Last edited by Basti@G20 320D; 01-26-2020 at 04:42 AM.. Reason: I had more on my mind
haruny96.50
      01-28-2020, 06:50 PM   #112
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
Originally Posted by siegester View Post
Getting Started
Items I am still researching
- Seat heater distribution
--- I was able to enable the seat heat distribution menu in Idrive, but it would not allow me to set values. It even acted as though only the driver's seat had seat back heating, with the other 3 seats only have seat bottom heat. I also enabled 2 settings in BDC_BODY to allow the distribution to be set for front and rear, but I also saw some settings stating there was only 1 controller per seat, so it may not be possible to get this working. Anyone know of any other settings to check?
SM2 -> SHZ_TYP -> werte 02
BDP -> SITZHEIZUNG_FRONT_schichtung -> active
BDP -> SITZHEIZUNG_FOND_schichtung -> active
than you can set the values for the driver's seat only...
anyone got update for other seats?
      01-28-2020, 08:02 PM   #113
tommytexter
tommytexter's Avatar
Drives: 2020 M340ix
I used to code this on my old f32. Same code didn't work for G20. Can't find the value.
Used to be FEM_Body FH_TUERAUF_STOP_MAUT
Also how to code out seat belt warning and camera all time?
Used to be these but can't find them on G20
      02-02-2020, 11:50 AM   #114
sneer82
Drives: G82
I really dislike the new style dashboard, especially the non-linear spedometer increments (where at the beginning of scale one notch is 10mph difference, while at the end it's 40mph).
I've noticed different digital dashboard styles on M8 and some spy shots of G80 M3. Is there any hope there will be a way to enable this on G20?
      02-04-2020, 12:52 PM   #115
MF-Racing
11
Drives: M340i
Question
Hi guys,
Hoping you can help...
Trying to code my M340i and having problems with the cheat codes not showing up for any module. Tried reinstalling launcher/E-sys about 5 times now, tried updating the cheat codes in the folder with ones from the net, no difference. Everything works great apart from no cheat codes showing up. Anyone got an idea?
Thanks
      02-04-2020, 10:47 PM   #116
siegester
siegester's Avatar
345
Drives: '20 M340i
2020 BMW M340i  [0.00]
Originally Posted by MF-Racing View Post
Hi guys,
Thanks
Have you selected the authors you want to load in launcher before opening esys? Only a few have codes for our platform, so make sure they are selected
      02-05-2020, 03:56 AM   #117
MF-Racing
11
Drives: M340i
Yes I have. Also tried new cheat codes, only loading one (or a few) authors. Nothing seems to make a difference?
      02-05-2020, 08:23 AM   #118
bimmerbriva
bimmerbriva's Avatar
Drives: 2019 330i xDrive
Has anyone heard from Tokenmaster in the past few weeks? It has been almost a month (1/8) since he was sent my donation confirmation and another email a few days later to verify that he received it.
      02-05-2020, 04:35 PM   #119
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
@MF-Racing,
Not meaning to poke a stick in your eye, but after opening a CAFD to code in E-Sys, did you click on the REFRESH button underneath the cheat code section?
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
      02-05-2020, 04:41 PM   #120
RSnic
RSnic's Avatar
tommytexter ,
Regarding FH_TUERAUF_STOP_MAUT, I found it in CAFD 44ED; it turns out that BDC_BODY has a couple of CAFD files
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
      02-06-2020, 04:17 AM   #121
MF-Racing
11
Drives: M340i
@MF-Racing,
Hope that helps!
Yes mate, pressed refresh, and even tried the autoload option. No joy!
Running out of ideas
      02-06-2020, 10:02 AM   #122
MF-Racing
11
Drives: M340i
Fixed it! Reduced the memory allocation for my Win VM, and they then appeared!
siegester344.50
      02-16-2020, 05:19 PM   #123
siegester
siegester's Avatar
345
Drives: '20 M340i
Thanks, that works. Will explore further for other seats.
      02-18-2020, 07:08 AM   #124
MF-Racing
11
Drives: M340i
Does this coding actually do anything? Ie can you control the back and bottom of the seat separately?
chiefy18.00
      02-20-2020, 05:22 AM   #125
Chris177
Drives: 2020 BMW M340i Xdrive
I have a 2020 m340i and downloaded esys 3.27.1 and launcher 2.8. Followed directions perfectly and connected to my car perfectly with no errors. I wanted to enable the driver assistance package but my following the directions here and looking for the files as described on the youtube video the files were not there to enable. 0 results. It has a build date of 3/19 and the car has driver assistance pro. Car is fully.loaded with the exception of adaptive suspension. Do I have to use the new esys and new launcher or did I do something wrong? Thanks.
      02-20-2020, 09:18 PM   #126
siegester
siegester's Avatar
345
Drives: '20 M340i
There is this warning about launcher 2.8 on the coding guide I linked.
Originally Posted by Almaretto
Launcher Pro 2.8.x
NOTE: Pro Launcher 3.x has newer mapping so you risk coding incorrect FDL's for G-series
So you should get 3.x to prevent issues and see all the mappings.
      02-20-2020, 09:19 PM   #127
siegester
siegester's Avatar
345
Drives: '20 M340i
It stores the value in iDrive, and at first didn't appear to do anything. However, it does appear to be working now. My back no longer roasts while my rump freezes
      02-22-2020, 04:58 AM   #128
Chris177
m340i cheat codes
So after no response from Tokenmaster i purchased the lifetime license and got the key within 48 hours. This does not use launcher to start esys. Am i correct by saying that cheat codes work with launcher only and that I have to make the changes manually with this instead? If I am correct where can I get the coding thats available for my vehicle? It would take hours just searching through the modules and applying changes that could mess up something. I have successfully made these changes so far: 5 turn signal flash, lane change assistant, driver assistance screen and the alpina dash (this one is pretty cool). Thanks.
      02-22-2020, 01:48 PM   #129
vet23
Drives: G30 530D
Does anyone know how to add a red highlight?
      02-24-2020, 05:01 PM   #130
RSnic
RSnic's Avatar
siegester ,
I saw your initial post on this thread regarding driver's seat heat distribution and am really interested in that as I had previously "hard changed" one of the 3 heat setting for a particular set of temperatures (low temp for seat, but moderate for back -- great for long drives to relax your back) on my F30, but really like the idea of being able to adjust "on the fly"
I got a little confused as this thread built with your comments and those of luckyfrederic .
My question is does that the heat distribution feature work? If so, what are the value, functions and modules to do so?
Appreciate your help
Thanks
Al
Retired: 2014 328i
BMW CCA
      02-24-2020, 09:55 PM   #131
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
Speed Limit Assistance for x5
https://g05.bimmerpost.com/forums/sh....php?t=1687106
these co-ordinate are exist in G20, but DSC-VIP cafd is different.
should it work?
      02-25-2020, 05:41 AM   #132
MF-Racing
11
Drives: M340i
siegester ,
Thanks
Yer I could do with some more guidance on this as well. Thanks
