Technical Topics DIYs and Coding Discussions ESYS G20 coding - getting started
      02-25-2020, 11:52 AM   #133
siegester
siegester's Avatar
345
Drives: '20 M340i
2020 BMW M340i  [0.00]
siegester ,
I saw your initial post on this thread regarding driver's seat heat distribution and am really interested in that as I had previously "hard changed" one of the 3 heat setting for a particular set of temperatures (low temp for seat, but moderate for back -- great for long drives to relax your back) on my F30, but really like the idea of being able to adjust "on the fly"
I got a little confused as this thread built with your comments and those of luckyfrederic .
My question is does that the heat distribution feature work? If so, what are the value, functions and modules to do so?
Appreciate your help
Thanks
Seat heat distribution works, and the values you need to change are in the original post. With that said, the behavior is a little odd. I haven't played with it enough to figure it out, but I frequently end up with only upper or lower back being warm even though the slider isn't all the way to one side.
      02-28-2020, 01:56 PM   #134
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
siegester ,
Just coded what you had in first post. How do you access the Seat Heating Distribution -- in other words, how do I get to it on iDrive?
Thanks
Al
Retired: 2014 328i
BMW CCA
      02-28-2020, 02:49 PM   #135
RSnic
RSnic's Avatar
Owner's Manual in Motion
Hi,
When I coded Video in Motion, it worked for videos, BUT it didn't seem to work for the on-board owner's Manual. I did some digging in the HG_MGU module of my M340 and found the following functions which I changed from Aktiv to NichtAktiv to allow use of the on-board owner's manual:
  • SL06_IBA1
  • SpeedLock_IBA_Access_CCM
  • SpeedLock_IBA_Short
  • SpeedLock_IBA_Index
  • SL20_Contacts_Note
While the last function is not part of the manual, I found it useful to also make it available while in motion
Al
Retired: 2014 328i
BMW CCA
      02-28-2020, 08:11 PM   #136
siegester
siegester's Avatar
345
Drives: '20 M340i
siegester ,
Thanks
These menus change a bit based on what is enabled, but it should be either in the same place as the auto seat heater configuration, or in a stand alone seat heating menu under the climate control menu (I believe there is even a third menu configuration, but I cannot recall what it was).
      02-29-2020, 01:07 PM   #137
RSnic
RSnic's Avatar
siegester ,
Hmm, I just checked and can't find that menu in either place or anywhere. I coded the two BDC & one SM2 functions in your original post, but I suspect some function has to be coded in the HG_MGU ECU -- perhaps:
  • HVAC_SeatHeat_Distribution_Fond to Aktiv
  • HVAC_SeatHeat_Distribution_Front to Aktiv
Is that correct?
Al
Retired: 2014 328i
BMW CCA
      03-01-2020, 10:49 AM   #138
Oniongc
Drives: 2019 g20
Got a few questions. Has anyone heard from tokenmaster? I have been waiting since December with no response. Also is any of this coding possible with just Esys alone and not the launcher? Trying to get lane change assist and the auto heated steering wheel working on a g20. Everything else I’ve done with Bimmercode. Thanks in advance for any info.
      03-01-2020, 03:37 PM   #139
siegester
siegester's Avatar
345
Drives: '20 M340i
siegester ,
Is that correct?
My apologies, yes I have coded both of those. For now I just use the Front since I have not yet been able to get anything but the driver's seat to work. I will update the original post. Also I checked last night and I currently have a seat and wheel heating option when I push the AC Menu button on the dash.
Did you email him and follow the instructions he sends you exactly? If so he usually responds within a few days to a week. If you don't get a reply after that, you most likely did not do something exactly as he asks. It sucks that he just ignores incorrect ones, but I imagine he gets a crap load of requests so I somewhat understand.
You cannot really code without esysx or launcher pro as they provide the mappings which make the trimmed values make sense to a human
RSnic657.50
      03-01-2020, 05:20 PM   #140
Oniongc
Drives: 2019 g20
Thanks siegester. I figured as much in the esys. I'm pretty sure I did every thing correct for tokenmaster. I paid him directly. He had no problem taking my money! I've been looking to see anyone acknowledge talking to him or getting the latest launcher but I haven't come across anything past December.
      03-03-2020, 01:13 PM   #141
RSnic
RSnic's Avatar
siegester ,
That did the trick! The driver slide seems to work fine, bu I see what you mean about front passenger -- can't get it to save slide setting; oh well!
THANKS!!!
Al
Retired: 2014 328i
BMW CCA
      03-05-2020, 09:15 AM   #142
Basti@G20 320D
Basti@G20 320D's Avatar
Sweden
25
Drives: E30, E36, E46, F30, G20
Hi guys i coded lane change, temp when stearing wheel starts, but one thing i can't find and its when trying to code heat distribution i can't find "SM2 -> SHZ_TYP -> werte 02"......Where is this "SM2"??
      03-05-2020, 10:36 AM   #143
RSnic
RSnic's Avatar
@Basti@G20 320D,
SM2 is the ECU that handles seat items; on my M340. its CAFD is 2259.
FYI, when using E-Sys (and I think also for Bimmercode), the ECUs are listed alphabetically on the SVT (again in E-Sys)
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
      03-27-2020, 06:59 PM   #144
jason0510
Drives: BMW M340i
brake force display coding done?
hi, just wonder have you tested you brake force display setting and may I know the code you changed ?thanks !!
      03-28-2020, 06:46 AM   #145
chris88
Drives: x3 f25
when changing to werte 2, however, a separate ntc sensor for backrest and seat must be installed in the seat. this is only the case with climate-controlled seats, isn't it?
      04-07-2020, 12:29 AM   #146
VipinLJ
VipinLJ's Avatar
It probably is since people have coded it in but it doesn’t work on the G20.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      04-07-2020, 11:01 PM   #147
siegester
siegester's Avatar
345
Drives: '20 M340i
Originally Posted by Lcar View Post
Thank you very much for sharing. May I ask the URL of the code you gave, there is no script encoded file, where can I find it? thank you very much!
Which file are you looking for? Esys, Launcher Pro, cheat codes? The cheat codes are in a format that launcher pro understands and brings into esys. You just download the code file, and put it in the esys directory (see first post for exact location)
      04-08-2020, 04:41 AM   #148
hottroc
Drives: BMW 330e
Hi guys, new to coding and have a couple of quick questions please:
1) I've seen a few cheap Enet adapters on eBay that say they are for the F-series. Presumably they would work on a G-series too wouldn't they? The pinouts for the ODB2 port are the same for both series I'd have thought?
2) I'm slightly confused whether I need Launcher for G-series? From the 1st post links I've downloaded Esys 3.27.1, PSdZData Lite 4.21.32 and the Launcher Pro that Tokenmaster was giving away in his blog, 2.8.2 build 162. But the Launcher token is only valid till 20th of this month and I haven't got my enet cable yet. But I'm only wanting to code one or two things so I don't really want to pay the £50 to get the token for a newer version especially as some people seem to have difficulty with him responding.
3) Between 1) and 2) above will I have everything I need? (Obviously I have a laptop.)
Thanks.
      04-08-2020, 11:30 AM   #149
RSnic
RSnic's Avatar
Thanks.
hottroc ,
Let me give your questions a go.
I have an ENet cable that I used on my F30 and have also used now on my G20.
On your laptop, you need the items listed. If you want to get the long term token, there are instructions in another thread on this forum or go to BimmerFest coding forum and get them there. From what I gather from posts, you must follow instructions EXACTLY and TokenMaster is notalways quick to respond.
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
      04-08-2020, 02:29 PM   #150
hottroc
Drives: BMW 330e
Thanks for your reply. So that answers the question about the Enet adapter.
I have all the software on my laptop ready to go. Will all the versions I listed work and be suitable for the G20?
And can the coding be done without using Launcher, ie just Esys? It seems that the main software is free but then you have to pay £50 just to add the cheat codes in with Launcher. It's a lot for what I want.
      04-08-2020, 07:44 PM   #151
RSnic
RSnic's Avatar
hottroc ,
Because the data is clipped, you have to use the Launcher which basically. maps function names & the like back with the data. Cheat codes, though used within Launcher, are free & not part of Launcher (I use Almaretto's -- see thread Getting started with E-Sys for how to get). I am not sure what is most current PsdZData set.
if the data set is the same or newer then the software version, you are OK.
Again, you must use Launcher
Hope that helps
Al
Retired: 2014 328i
BMW CCA
      04-09-2020, 04:59 AM   #152
hottroc
Drives: BMW 330e
hottroc ,
Because the data is clipped, you have to use the Launcher which basically. maps function names & the like back with the data. ...
Hope that helps
OK thanks for clarifying. I'll just have to fork out the £50 and hope that Tokenmaster responds promptly. Or if I get my cable in time I'll try the free version. I only really want to code one thing (Enhanced Bluetooth) for now at least. Wished I'd added it when ordering but didn't realise what it was.
      04-09-2020, 11:00 AM   #153
RSnic
RSnic's Avatar
hottroc .
Please be sure to read the instructions earlier in this thread as several didn't and had problems
Good luck and welcome to coding!
Al
Retired: 2014 328i
BMW CCA
      04-13-2020, 07:15 AM   #154
MY86
MY86's Avatar
Turkey
15
Drives: G30 520i G20 320i
Hi guys, anybody know how to enable the Coasting via BimmerCode?
