04-13-2020, 08:21 AM | #155 |
Rep 1,479
Drives: 2020 M340Xi (G20)
MY86 ,
Here's what I coded, using E-Sys & ProLauncher, but should work with Bimmercode in Expert Mode: × DKOMBI4 ECU Anzeige_Configuration> 10Seglen_In_Comfort_Modus from 00 to 01 * HG_MGU: Not sure which function (HMI_SPEECH?) Global_Conf_Sailing from 00 to 01 Eff_Dyn_Sailing from 00 to 01 Sailing_Counter from 00 to 01 You end up with a check box to check on iDrive under SETTINGS, CAR This will give you coasting in Comfort; you should already have in EcoPro (check box in SETTINGS, CAR,DRIVE MODE) Hope that helps!
Al
MY8615.00 |
04-13-2020, 10:47 AM | #156 |
Rep 48
Thanks a lot RSnic That worked like a charm.
Do you also have an idea about how to make G Meter appear on the digital cluster? Unfortunately, we don't have the G meter widget available from the factory. Also the 'valet parking mode' could be done with coding? siegester Last edited by MY86; 04-13-2020 at 11:21 AM.. |
05-03-2020, 03:26 PM | #157 |
Rep 43
Hi, I have been trying to read up as much as possible on coding for my G20. Am I correct in assuming that EsysX is the only current (other than Bimmercode) option for G20, as the developer of esys launcher 3.x isn't currently active? Thanks.
I am trying to code Sport+, Lane Change Assist, and Assisted Driving View. I think that bimmercode would work for Sport+, and ADV, but I don't think there is currently a way to code LCA with bimmercode is there? |
05-04-2020, 03:20 AM | #158 |
Rep 5
You will be able to get esysx more reliably than TokenMaster‘s Launcher. I’m using both, but esysx is weird, too. Bought a license in 09‘19, now I can’t access the web portal anymore, unknown login. Weird.
05-11-2020, 05:09 PM | #159 | |
Rep 1,479
I have coded with E-Sys & ProLauncher -- mainly because I used it on my old F30; think I did Assisted Driving View & Lane Change Assistant with it. I also have used Bimmercode with a MX+ OBDLINK. This is quite handy, BUT urge you to turn off car's Bluetooth while using and not all modules have expert mode yet Hope that helps!
Al
05-12-2020, 03:24 AM | #160 | |
Rep 243
And it's not cheap either. I paid more for EsysX that I might use once or twice ever, than I paid for MS Office that I use every day (and I don't have to compromise my other applications for Office). If you're a G-series owner it's really not looking good for the future of coding at the moment. |
05-12-2020, 07:35 AM | #161 | ||
Rep 43
05-17-2020, 07:42 AM | #163 | |
Rep 43
Just have a question. I see that you coded this:[*]ASS memory (dme) I tried to do it using the shortcuts (and manually) and had a coding error in esys. While coding the car turned off in the middle. I tried it twice (once shortcut, once manual). Same thing happened. Hopefully it didn't do anything bad. How did you manage to get it working? Thanks! |
05-17-2020, 08:33 AM | #164 | ||
Rep 1,479
Because you are coding DME_BACKUP (which controls some engine functions), the engine turns off -- I had the same thing happen. What I discovered is that, using E-Sys, I do everything up to turning TSA_MEMORY to aktiv, then BEFORE I tap the CODE button, I turn engine off. If, on the other hand, you use Bimmercode, you don't have engine running, just car in diagnostic mode (3 quick pushes on Engine Start button WITHOUT pushing down on brake) As I said, I made same mistake. I haven't noticed any problems except that ASS always switches off when I unlock & open driver's door (I have coded car to start in EcoPro). Having said that, oddly ASS stays off going into & out of the other driving modes. Hope that helps!
Al
05-17-2020, 08:41 AM | #165 | |
Rep 43
05-17-2020, 09:24 AM | #166 |
Rep 1,479
@TheGrok ,
For the error, as best I can figure, that's exactly right. I got that tip from one of the real coding gurus, shawnsheridan
Al
TheGrok7.00 |
05-17-2020, 09:46 AM | #167 |
General
10415
Rep 40,668
Drives: 2018 Alpina B6 650ix GC
Code with motor running all ECU EXCEPT DME/DDE. You can't code motor ECU if Motor is running. Engine will stall and DME/DDE CAFD will become missing or corrupt.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
TheGrok7.00 |
05-17-2020, 09:48 AM | #168 | |
Rep 43
05-17-2020, 09:58 AM | #169 |
General
10415
Rep 40,668
Yes, if car stalled out during coding. Check DME and see if CAFD is still present, and if so, is not named cafd_ffffffff-255_255_255.
TheGrok7.00 |
05-17-2020, 10:07 AM | #170 | |
Rep 43
05-17-2020, 10:23 AM | #171 |
General
10415
Rep 40,668
Looks ok. You got lucky.
TheGrok7.00 |
05-17-2020, 10:38 AM | #172 |
Rep 43
05-17-2020, 10:52 AM | #173 |
General
10415
Rep 40,668
Yes, but not because you saved anything.
TheGrok7.00 |
05-19-2020, 05:15 AM | #174 | |
Rep 50
05-20-2020, 03:49 PM | #175 |
Rep 1,037
Has anyone enabled SMS/enhanced Bluetooth functionality with BimmerCode?
05-23-2020, 06:48 PM | #176 | |
Rep 43
Hi, wondering how you coded ASD OFF. Unless I missed something, there aren't shortcuts available for that and I am not sure which values I need to change in ESYS nor in which module. Thanks! |
