Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications M340i Low engine oil warning at 3000 miles
      10-14-2019, 12:14 PM   #23
raptorapture
raptorapture's Avatar
Drives: 2020 m340i
2020 M340i  [0.00]
Just got back from the dealership, the service manager stated that "this is normal, these engines burn about a quart every 1000 miles."
Given that these are advertised to be serviced every 12mo / 10k miles for an oil change, this information is quite concerning as you would have cars coming in with no oil with months of starvation.
1 quart per 1000mi is acceptable on engines that have 100k+ on them but not on a brand new platform that is out of the break-in period.
I will be calling BMW NA to voice my concerns regarding this. While I love the car, I cannot (time wise) afford to be taking this in every 1000-2000 miles.
MBM3401026.00
      10-14-2019, 04:31 PM   #24
EXE46
EXE46's Avatar
Drives: 2020 M340i RWD Aka New E39 M5
That manager is full of it. I would take the car to another dealership. That is certainly not normal, they'll tell you anything so they don't have to diagnose your issue. I have experienced that scenario before at a Lexus dealership and went to another place because i knew the issue I had was legitimate. Second place ended up swapping out spark plugs and injectors which fixed the issue I had with the car going into limp mode. Not all dealers are created equal, some have very poor customer service so the consumer must be willing to find another dealership who will take his/her concerns seriously.
Prior's: E36, E46 x2
chenry2357.50
MBM3401026.00
      10-14-2019, 05:35 PM   #25
Weiner0123
Weiner0123's Avatar
Drives: 2020 m340i. 2013 328i
No tell him to shove it.. that is not normal
      10-21-2019, 03:14 AM   #26
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Please call BMW NA and request field engineer to inspect your car as well as approve additional diagnostics. Once these are approved, the dealer will find the the problem.
Again, this oil consumption is excessive and not normal at all. If the head gasket turns out to be OK, the next likely culprit is the turbo.
      10-21-2019, 09:47 AM   #27
themnmd
themnmd's Avatar
Drives: 23 X5MC
just added 1 quart at 3300 miles. if it does not occur until 10k service then i would leave it alone. however i will mention it to SA. i will address it sooner if the car prompts me again
      10-21-2019, 05:02 PM   #28
raptorapture
Drives: 2020 m340i
2020 M340i  [0.00]
Also thinking it could be a piston ring issue as there is no signs of oil in the bay at all, but yeah I will continue to follow up with them as I do not want to enter Lemon Law territory.
      10-21-2019, 05:29 PM   #29
bimmer456
Drives: 340i
Proof Lexus reliability is overrated.
chenry2357.50
      10-21-2019, 05:33 PM   #30
bimmer456
Drives: 340i
Originally Posted by evo2335 View Post
Mine asked for oil around 4500 miles. Just took it to the dealer and it was topped off. iirc, my 340i did the same thing after 3-4K miles as well.
My car said low oil right after an oil change done by the dealer. Obviously they did not put enough oil in. One of those situations where the car left the dealership in a worse condition then when it went in. Good thing I keep all the service records. Some of my service records say 2.0 turbo is the engine though I have the B58 so maybe that's why.
      10-25-2019, 11:30 PM   #31
nola2atx
nola2atx's Avatar
My oil low warning just popped on as well, but at 4300 miles. Seems early...
///M340i Portimão
My Exes:
E36, E46, F30
      10-26-2019, 09:59 AM   #32
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
LMFAO at 1 qt per 1000 miles. So that's how they do 10k mi oil changes. You've already cycled out 10 qts by the time you're due for a change. That guy is horseshit. I would tolerate 1 qt every 5000 miles but any more than that and I'm raising concerns.
chenry2357.50
MBM3401026.00
      10-26-2019, 11:35 AM   #33
raptorapture
Drives: 2020 m340i
2020 M340i  [0.00]
Which dealer are you going through for Service here in ATX?
I purchased and have serviced with South, but after all this I will probably start using the North dealer.
      10-26-2019, 09:57 PM   #34
nola2atx
nola2atx's Avatar
Went through north Austin on McNeil for my last one and will probably schedule with them for this one as well. Nothing but positive things to say as far as service. Sales is another story.
///M340i Portimão
My Exes:
E36, E46, F30
      11-01-2019, 03:30 PM   #35
tazzi831
tazzi831's Avatar
Drives: BMW M340i
2020 BMW M340i  [0.00]
This happened at 4480 miles for me.
      11-03-2019, 01:45 PM   #36
5mall5nail5
Not stock
5mall5nail5's Avatar
Drives: E34 525i Turbo
Originally Posted by DonTheDon View Post
I needed it at 4k
Has nothing to do with a manufacturer and everything to do with a specific engine. Volvo has had their oil consumption issues. Honda too. Lexus, yes, has had it as well.
That said, take it in - seems a bit excessive.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM
1992 525i
1987 325e
      11-08-2019, 09:52 AM   #37
raptorapture
Drives: 2020 m340i
2020 M340i  [0.00]
Taking mine into a different dealership than previously serviced at for the OBD reprogram recall as well as the camera recall next Wednesday, I have mentioned the oil consumption issue to them as well as BMW NA, and they will look into this while they have the car.
I will update with my results when I get the car back.
      11-08-2019, 10:58 AM   #38
nola2atx
nola2atx's Avatar
For those that didn't see the other thread:
Mine ended up not actually being low, but my oil sensor was bad. Now waiting three weeks for replacement to part. Do not just add oil! Bring it in! Could be a bad sensor like mine...
///M340i Portimão
My Exes:
E36, E46, F30
      11-09-2019, 09:52 AM   #39
xacoffeemx
Drives: 2017 320i, 2020 M340i
Thanks everyone for the insight on the oil and that this is not normal. I took the car in for service couple days ago to get the recalls done and I also mentioned the oil consumption rate being rather high.
It's been about 1.5k miles since I last did a top off and I went in for service. BMW found 6.8 quarts of oil out of 7 when they drained the vehicle.
They would like for me to return after another 2K miles to have this measured and inspected again. I will update here when I reach there!
      11-16-2019, 12:58 PM   #40
EXE46
EXE46's Avatar
Well it finally happened to me today while out driving, warning message popped up to add quart of oil. I am just over 3200 miles, sucks because I now have to find time to schedule an appointment for this. With my annual vacation coming up in a week I won't get to do this until after Thanksgiving. Hopefully the oil level sensor is the culprit.
      11-16-2019, 04:41 PM   #41
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
It's not the oil level sensor, that's just a dealer rolling the dice at an issue they can't address.
I had a bad oil level sensor before; the oil reading was incomplete not registering as it should, this particular issue is a correct reading but excessive usage of oil.
This vehicle's motor just naturally burns oil rapidly and based on the feedback here, it's a pretty common occurrence.
      11-16-2019, 05:16 PM   #42
EXE46
EXE46's Avatar
Hmm, well i managed to get an appointment for next week. I will take it in and let them diagnose it.
      11-16-2019, 10:58 PM   #43
themnmd
themnmd's Avatar
Drives: 23 X5MC
Not normal but too common
      11-25-2019, 03:21 PM   #44
bmw_md
Drives: 2020 BMW m340iX
My car (2020 M340) at 4080 KM or 2550 miles -
The warning "Engine oil at minimum level add 1 quart of engine oil" "Refill oil immediately"
Dealer says It's normal WTF?
