Technical Topics DIYs and Coding Discussions Coding Sport+ On G20 w/ Bimmercode
      09-25-2020, 03:31 PM   #221
masonwoyt
Drives: 2020 BMW 330i
Originally Posted by VipinLJ View Post
It used to happen to me too. All I needed to do was close and open bimmercode a few times for it to work. If you have a Samsung phone, I suggest you return the LX and get a wired enet cable and usb c to lan adapter. So much better!
VipinLJ could you provide more detailed instructions of how to use an ethernet cable and a USB-C adapter to program?
Where do I connect in the car?
Am I using my computer now?
What computer program do i use?
I appreciate all of the help!
      09-25-2020, 07:26 PM   #222
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
Heya
To code using a Samsung Galaxy phone, you can use a USB C to Enet adapter (https://www.amazon.com/gp/aw/d/B07VP...b_b_asin_title) and an enet cable (https://www.amazon.com/gp/aw/d/B00ME...b_b_asin_title).
You also need to buy the Bimmercode app from Google Play.
You connect the enet cable to the car via it's OBD port (pic in the link https://g20.bimmerpost.com/forums/sh...&postcount=120). And then connect the enet cable to your phone via the USB C adapter.
Once connected, enable “Static IP“ in the Android Ethernet settings(“Connections“ > “More connection settings“ > “Ethernet“ > “Configure Ethernet device“ > “Static IP“) and make the following entries:
IP Address: 169.254.250.250
Netmask: 255.255.0.0
Default gateway: 0.0.0.0
DNS address: 0.0.0.0
Disconnect the cable and connect it again to make the changes take effect.
Open the settings in the BimmerCode app and make sure the correct adapter type is selected ("3 dots on the top right of the app" > "Settings" > "Adapter" > " ENET cable")
Tap “Connect” on the start screen in the BimmerCode app.
Upon first use a dialog is displayed and you have to allow BimmerCode access to the UBS device. Please confirm with “OK“ and then tap “Connect” again.
You then have to choose your car from the list and it'll access all the modules in your car.
You do not use a laptop for coding. Only your phone or tablet.
Also, make sure your phone is in airplane mode before you code. If someone calls you while you're coding your car, it can mess things up. So make sure it's in airplane mode and has enough charge.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      09-26-2020, 07:40 AM   #223
masonwoyt
Heya
You connect the enet cable to the car via it's OBD port (pic in the link https://g20.bimmerpost.com/forums/sh...;postcount=120). And then connect the enet cable to your phone via the USB C adapter.
Once connected, enable "Static IP" in the Android Ethernet settings("Connections" > "More connection settings" > "Ethernet" > "Configure Ethernet device" > "Static IP") and make the following entries:
Tap "Connect" on the start screen in the BimmerCode app.
Upon first use a dialog is displayed and you have to allow BimmerCode access to the UBS device. Please confirm with "OK" and then tap "Connect" again.
VipinLJ awesome! Thank you so much for the detailed instructions. As someone who is new to the forum life AND new to BMW family it makes doing things like this possible.
And as a side note: I want to shout out you and g20beam for all of the work that you put into this thread. You guys really grinded to make this awesome mod super easy for rookies like myself. Thanks a bunch. Hopefully I'll be adding sport+ soon!
VipinLJ1941.50
mikeyb74113.00
      09-26-2020, 09:02 AM   #224
VipinLJ
Petrolhead
VipinLJ's Avatar
You're welcome! Just trying to pass along whatever little I know. I was in the same spot as you a while back. So I know how that feels
And honestly I haven't done anything. It's the others mainly who have been doing a lot of research. Huge shout out to all of them (too many to list here). You all know who you are!
Current:
      10-06-2020, 02:33 PM   #225
mikeyb74
mikeyb74's Avatar
Drives: G20 330ix M Sport
I finally got sport + coded after a warranty repair. What a headache that was. I ended up emailing Stephan at Bimmercode to become a beta tester. He sent the invite and I was finally to code all the features that I couldn't code without the beta. I noticed that the driving mode screen doesn't come up when you change the driving mode. Is that in the settings or did I code it to be turned off. It doesn't really matter because I can go into the settings still. Come to think of it the passengers don't need to know when I change the driving mode. Another thing I wish Sport + had was tighter steering. I miss the tight steering on my Cooper S JCW. I looked thru to see it sport + steering is a thing but I didn't see anything. Ideas?
"It is funny...people who drive anything expensive often get labeled by folks who drive less expensive cars. I have found, without exception, that douchebags cover all demographics and incomes."
      10-08-2020, 06:07 PM   #226
lakers2426
Drives: 2020 330i M Sport
Just finished coding Sports+ and can confirm there is pretty noticeable difference in the amount of pops and burbles coming out of the exhaust. Does anyone know why this was restricted in the US in the first place?
      10-09-2020, 01:32 PM   #227
masonwoyt
Please grant me leniency if this is against forum rules (Moderator please delete if it is).
Is there anyone around the Pittsburgh, PA area that has the equipment and has done this? Sure it may only cost me like $40 all in, but I'm cheap what can I say.
      10-09-2020, 07:18 PM   #228
VipinLJ
Petrolhead
VipinLJ's Avatar
It’s not called being cheap. If there isn’t much one wants to do with bimmercode, doesn’t make sense buying it. I would’ve done it for you but I live in IL unfortunately.
Current:
      10-10-2020, 05:20 AM   #229
helmet91
helmet91's Avatar
Netherlands
298
Drives: BMW G20 330i X-Drive M-Sport
BimmerCode and the associated plugs/wires is hella cheaper than the interface required for VAGCOM/VCDS for Audi and VW... I had no hesitation buying BimmerCode and the adapters, they're damn near free.
      10-10-2020, 09:35 AM   #230
VipinLJ
Petrolhead
VipinLJ's Avatar
Yup. I think I paid around $100 or so for OBDeleven. Can't remember how much exactly. BMW is significantly cheaper but still.
Current:
      10-17-2020, 07:47 AM   #231
lance666
Drives: 320i
Any idea why after i select sports or comfort mode, idrive not showing anything.
      10-17-2020, 08:45 AM   #232
VipinLJ
Petrolhead
VipinLJ's Avatar
Originally Posted by lance666 View Post
Attachment 2439693
You mean like the case below?
https://g20.bimmerpost.com/forums/sh....php?t=1766862
If so, I've written why that may have happened in that thread itself.
Current:
      10-17-2020, 09:46 AM   #233
lance666
Drives: 320i
Previously before 07/2020 FW not issue when press sport or comfort. The idrive will display. But now only instrumental cluster show besides speedometer but nt idrive.
      10-17-2020, 09:49 AM   #234
VipinLJ
Petrolhead
VipinLJ's Avatar
Yup. Go to car, general settings, scroll down to pop ups and see if drive experience control is checked or not. Rarely, that can get unchecked when you do codings or get software updates and it won't pop up on the idrive screen when you change modes.
Current:
      10-18-2020, 12:55 AM   #235
lance666
Drives: 320i
Your awesome!!!
      10-18-2020, 08:49 AM   #236
phillyd2
Drives: 2020 M340i XDrive
Sorry but there’s no ‘cheap’ excuse. It’s under 50 bucks for the app and cable but more importantly you will need to redo the coding whenever your software is updated to a newer version.
      10-18-2020, 09:32 AM   #237
VipinLJ
Petrolhead
VipinLJ's Avatar
Your awesome!!!
I'm glad that fixed it!!
Current:
      10-26-2020, 06:19 AM   #238
barneys46
Drives: Bmw 330e
2019 Bmw 330e is it possible to code sport plus
just wondering if I can code sport plus to my g20 330e will it improve the exhaust note any do u get pops and bangs etc my car is December 2019 330e with the b type engine if that makes any difference
      10-26-2020, 09:14 AM   #239
mikeyb74
mikeyb74's Avatar
You should be able to code sport plus on your 330e. It add pops and bangs.
      10-26-2020, 12:50 PM   #240
mij
Germany
Drives: BMW 330e
Please be aware that you can have either xtraboost or Sport+, not both. For me coding Sport+ in my 330e didnt add any sound, but maybe you are more lucky than I
      10-26-2020, 02:05 PM   #241
barneys46
Drives: Bmw 330e
Bmw 330e
so is sport plus just the same as xtra boost no point in coding sport plus in my 330e if its just xtra boost with a different name
      10-26-2020, 04:07 PM   #242
masonwoyt
So after all of the "cheap" slander I gave it another thought and decided to pay the ~$72 ($20 for ENET adapter + $20 for Ethernet to Lightning + $32 Bimmercode). The main reason I was hesitant about doing this was because the car is a lease so most likely I will be getting something different in 2 years and who knows if i'll ever use this equipment or app again. For approximately $0.07/day I figure it will be worth it.
Question: After purchasing the full version of Bimmercode do I still need to request access to TestFlight?
Copyright ©2000 - 2024, vBulletin Solutions Inc.
