Technical Topics DIYs and Coding Discussions BimmerCode
      10-15-2020, 07:38 PM   #177
Mr.G20 M340
Mr.G20 M340's Avatar
Drives: 2020 Portimao Blue M340-x
Originally Posted by mikeyb74 View Post
Originally Posted by daniel88br View Post
Hi Mikey, can you please tell what enet cable and ethernet to lightning adapter you are using? I wanna take my first steps on coding and I have an iPhone 11. Tks!
Sure can.
I purchased the Bimmercode recommended enet cable and ethernet lightning adapter.
Enet Cable
https://www.amazon.com/Ethernet-Inte...54840370783b07
Ethernet to Lightning Adapter
https://www.amazon.com/Amatage-Light...7c0075428ca9c8
So I got this exact setup and for some reason it doesn't always work. It seems like I have to change the cable source to kiwi and then go back to enet cable to make it work.
Instagram: Bmw_Captivate
2020 Portimao Blue M340 X Drive and adaptive suspension.
Mods: custom exhaust, VRSF Catted DP, Injen intake and Chargepipe.
      10-20-2020, 03:56 PM   #178
mikeyb74
mikeyb74's Avatar
Drives: G20 330ix M Sport
Sure can.
Enet Cable
It worked for me a few times and now it's intermittently works. So ordered replacements of both and it still doesn't work all the time. So I ended up buying the OBDLink MX+. Which works every time I use it.
OBDLink MX+ OBD2 Bluetooth... https://www.amazon.com/dp/B07JFRFJG6...p_mob_ap_share
      10-22-2020, 11:12 AM   #179
WilsG30M550i
Drives: 2018 bmw m550i x drive
That’s what I use it’s super easy and self explanatory
      10-23-2020, 06:23 PM   #180
achk
Drives: BMW U11 iX1 Xdrive 30
Does Bimmercode work with software 7/2020.xx? I don't mind doing the recoding but just want to know if the latest idrive software is supported yet?
If not, I may wait before downloading the upcoming OTA as I don't want to lose the ability to recode some of the features.
      10-23-2020, 08:14 PM   #181
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
achk ,
After my car got updated at dealer with version 07/2020.45, I used Bimmercode to code back in all of my custom coding without a problem-- BUT please bear in mind that Bimmercode can't code SAS2 module yet
Al
Retired: 2014 328i
BMW CCA
achk132.50
      10-23-2020, 08:45 PM   #182
lance666
Drives: 320i
Anyone has problem getting active sound design working with 07/2020 firmware? Tried coding off and on still no sound.
      10-25-2020, 05:37 AM   #183
Osxboy
Drives: G21 320d
I’m also struggling with the enet cable and Ethernet to lightening connector. In the instructions for BimmerCode it says turn the ignition on and then press the start 3 times rapidly which brings up the message about diagnostics mode but the app won’t connect - any tips?
      10-25-2020, 06:32 AM   #184
biglesias31
biglesias31's Avatar
Drives: BMW X3
Turn on diagnostics mode in the car. On your iPhone, disable WiFi, Bluetooth and turn on airplane mode. Connect the your iPhone to the car with the enet cable. Then go into your iPhone settings and tap Ethernet. Wait until it automatically generates the IP addresses and then launch BimmerCode. Works every time , for me at least. Good luck!
      10-25-2020, 01:18 PM   #185
Osxboy
Drives: G21 320d
OK I tried this but still no joy. Do I need to only plug the cable in after turning off WiFi etc? I can get the Ethernet settings to work but I get a full internet IP of the form: 169.254.253.xxx with a subnet mask of 255.255.0.0 I was expecting a local address e.g. 192.168.x.xxx
Any thoughts
      10-25-2020, 01:24 PM   #186
Osxboy
Drives: G21 320d
I’m running iOS 14.01 and about to update to 14.1 if that is relevant.
      11-12-2020, 09:58 PM   #187
clipz85
Drives: g20
Im having issues with my coding after the 2020/07 software upgrade,
After changing the instrument cluster to "M layout" the address at the bottom is misalligned to the right
      11-12-2020, 11:32 PM   #188
ruczko
Drives: '20 330xi
Any thoughts
Turn off all of your wifi/blutooth, then go into your car, hit the button 3 times, check your ethernet settings and once you have an IP then load in the app - that should work for you. Just be patient when you do it.
      11-13-2020, 02:17 AM   #189
Osxboy
Drives: G21 320d
I managed to get it working, in settings on iOS you have to find BimmerCode and set it to allow connection to the local network.
      11-15-2020, 02:03 AM   #190
achk
Little help please. I just did the OTA update to 7/2020.54 and set about recoding my previous coding mods.
I'm using an iOS device (tried iPad and iPhone 11pro) with a modBMW Enet WIFI adapter.
While trying to access the BDC module, it comes back with an error. Is this a known issue or am I missing something?
I've had no problem accessing the other modules and I certainly have coded things in BDC before.
I even tried deleting and re-installing the BimmerCode app.
The things I want to code in BDC are starting in adaptive, reduce the passenger side mirror dipping angle when reversing, rear DRL.
thanks in advance!
      11-15-2020, 02:37 AM   #191
phayze
Drives: BMW
You will need beta version to access BDC on 07/2020 software.
thanks in advance!
achk132.50
      11-16-2020, 04:14 AM   #192
achk
BimmerCode just released an iOS update. BDC is now accessible.
      11-16-2020, 11:43 AM   #193
cilas
Drives: Z4 30i (G29)
So it doesn't need the beta to get BDC anymore?
My OBDlink MX+ is coming today so i'd like to know if the beta is necessary.
The new version you are talking about is the beta or this one?
      11-16-2020, 01:31 PM   #194
achk
Not necessary. The updated app will work with the BMW software 7/2020.54 (OTA update that has been pushed out recently). I was able to access BDC module whereas I couldn't before the bimmercode app was updated. There's no need to request and download the beta version.
      12-01-2020, 11:18 PM   #195
warrenw
Food Critic
warrenw's Avatar
South Korea
1086
Drives: 19 AW M2C, 21 M340i
Anybody using the VeePeak adapter?
      12-03-2020, 12:29 AM   #196
JneneJ
Drives: 2018 320i
I'm having the same issue! Any luck?
Jb
      12-04-2020, 07:25 AM   #197
mkcobain
Drives: BMW G20 320i
Hi, I just registered, searched the forum but couldn't find anythnig related.
Can I code my car to auto lock when I walk away from it? It seems like the car has all the hardware and software to perform this task.
Is it possible?
      12-04-2020, 07:53 AM   #198
cilas
Is it possible?
It is a OEM feature. At least the 330i MSport here in brazil, has. No coding needed for this.
