Technical Topics DIYs and Coding Discussions Anti-dazzle coding on Laser?
      09-18-2020, 06:17 AM   #177
sztmek
Drives: BMW 3 G20
Thanks for your investigations about laser headlights. I have EU car with laser headlight. Could someone tell me in short words what’s this thread is about? There are a lot of pages. It can be useful for European cars or only for US cars?Thanks in advanced
      09-18-2020, 05:52 PM   #178
Saunders17283
Saunders17283's Avatar
Drives: 2020 M850xi Gran Coupe
Primarily, anti-dazzle headlights get deactivated for cars headed to the US. Since you are in Europe, you shouldn't need to code this.
Current Ride
Previous Rides
2019 X7 / 2018 X5 / 2012 X5 / 2014 750xi / 2011 750Lxi / 2008 335xi
      09-22-2020, 02:57 AM   #179
A6bullet
Germany
337
Drives: 2020 330i Msport
Did you get yours to work properly?
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      09-22-2020, 08:14 AM   #180
Saunders17283
For the most part, yes!
There are a couple sensitivity codes I'd still like to tweak (reaction to glare off street signs, street light sensitivity) but it definitely works.
Current Ride
Previous Rides
A6bullet337.00
      09-29-2020, 12:06 PM   #181
ahass
ahass's Avatar
Drives: 2017 BMW M2
2017 BMW M2  [10.00]
Awesome thread! so just to confirm, this has to be done in E-sys? and can't be done in bimmercode?
      09-30-2020, 08:44 AM   #182
Saunders17283
That is correct. Coding this particular feature requires a VO code and BimmerCode cannot do that.
Current Ride
Previous Rides
ahass48.00
      10-01-2020, 02:32 AM   #183
A6bullet
Germany
337
I am looking for someone that can do a remote coding session for me. Just PM me.
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      10-08-2020, 01:56 PM   #184
Msb12i
Msb12i's Avatar
Drives: Coded G21 330E
Are you from germany?
Do you have a stalk with High beam assist?
I've had it on my F36 and now on my G21.
Buying the high beam assist adds anti dazzle function.
      10-13-2020, 11:27 AM   #185
tommytexter
tommytexter's Avatar
Drives: 2020 M340ix
I can help whomever in Toronto area with this.
      10-13-2020, 06:46 PM   #186
kubax86
kubax86's Avatar
Drives: M2
Really be aware about KAFAS4
      10-20-2020, 10:55 PM   #187
tommytexter
Drives: 2020 M340ix
Care to elaborate?
      10-21-2020, 01:21 PM   #188
larrylam646
larrylam646's Avatar
Drives: 2020 M340i xDrive
Care to elaborate?
Please take a look at post 144.
2020 Black Sapphire M340iX
      10-22-2020, 10:09 AM   #189
Pumxee
Pumxee's Avatar
Drives: BMW X6
Is there a guide on how to do this?
Pum Performance Website Coming Soon!
BMW Parts and Accessories
https://pumperformance.com
      10-22-2020, 07:24 PM   #190
siegester
siegester's Avatar
345
Drives: '20 M340i
2020 BMW M340i  [0.00]
I am working on some Esys cheat codes that might work without VO coding. Hope to test them this weekend.
      10-23-2020, 01:50 AM   #191
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Coding requires mostly FDL coding. BMW must have gotten wise to VO coding and changed boolean logic.
deoxys37.50
      10-23-2020, 09:10 AM   #192
ifr
ifr's Avatar
1198
Drives: Tesla MY LR AWD
Not strictly the case. Anything VO coding can do FDL coding can do better
Well at least the same in any case.
The reason bimmercode can't code anti dazzle, using fdl coding, is that it doesn't support one or more of the ECU's.
      10-24-2020, 04:21 AM   #193
Almaretto
Almaretto's Avatar
2374
VO coding relies on boolean logic. VO coding, if logic is correct, takes guesswork out of deciding what to change and makes adjustments for you.
FDL coding does not make the changes better; it is just manual changes.
      10-24-2020, 04:58 AM   #194
ifr
ifr's Avatar
1198
It was a joke, on the song quote from the musical. Obviously fell flat
I use the activation conditions/understand the underlying boolean intimately, and use it extensively in my code discovery and publishing.
Almaretto2374.00
      10-25-2020, 12:00 AM   #195
siegester
siegester's Avatar
345
Drives: '20 M340i
Put up a PR for the changes required to use anti-dazzle. I haven't fully tested the functionality with FDL only coding yet due to the weather, but basic tunneling is at least present. Other members have reported success with only these changes, but I will verify myself and report back when the weather improves.
Rev_Hi296.50
Poochie9104.50
RSnic657.50
      10-27-2020, 04:30 PM   #196
_Qba_
Drives: G20 330i
I have VO coded anti-dazzle. Works great!
But after coding all apps disappeared from mgu including spotify and carplay.
Anybody had similar situation?
      10-28-2020, 07:58 AM   #197
_Qba_
Drives: G20 330i
Ok, problem solved
Update apps and services
      10-30-2020, 10:03 PM   #198
Almaretto
Almaretto's Avatar
2374
Remember to fdl code flm modules as well.
I think you missed some bdc codes too.
I have coded on g20, g05, g07, and g12... They work well.
