Technical Topics Wheels and Tires Max tire size M340 Square setup
      06-26-2020, 12:01 PM   #45
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Originally Posted by iPetey View Post
BarryB's setup looks nice.. I don't think i can do the same as I seem to have 225/40/19 Bridgestone Turanza runflat . Someone correct me if i'm wrong plz. Can i run 245/50/19 all around or what is the best sizing for the pilot sport 4s? Tire rack shows the recommended size for the 2020 m340i at:
Front: 225/40R19 93Y XL
Rear: 255/35R19 96Y XL
Mine came from factory with these fitted..
Front 8j x 19 with 225/40 R19 Michelin Pilot Sport 4 S
Rear 8.5j x 19 with 255/35 R19 Michelin Pilot Sport 4 S
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      07-03-2020, 05:48 AM   #46
Kaps335i
Drives: 2013 335i xDrive
Which is correct on an xDrive with 19" 792M?
245/35 - all four
or
235/40 - all four
or
None of the above
My car came with the Bridgestone turanza ls100a rft and I am trying to replace with the Pilot Sport 4S.
2020 M340i xDrive
Dravit Grey Metallic
Modifications
July 23rd - Dyno Tune
      07-03-2020, 10:06 AM   #47
Kaps335i
245/35 - all four
or
235/40 - all four
or
None of the above
Apparently 245/35/19 doesn't meet the weight requirements for the car. I ended up ordering 235/40.
2020 M340i xDrive
Modifications
      07-04-2020, 09:37 PM   #48
Voodoo_G80
Drives: G
Hey guys. Need ur input please! I have 19x8 rims squared NOT staggered but want that staggered look. I’m in the process of ordering tires. Do all the tires have to be the same size? Such as 245/19 all around? Or can I do 275 rear and 245 front? Thinking Michelin pilot sport 4s Thanks!
      07-15-2020, 08:02 AM   #49
Sheezus
Sheezus's Avatar
Drives: BMW M340i
Ordered 19x8.5 rims (32 mm offset) all around with 245/35 tires, will let you know if there are any rubbing or fitment issues. Tired of staggered tires due to very limited tire rotations.
UPDATE: No rubbing or fitment issues. Front wheels are very close to strut tube but it's not touching. Looks great.
      07-17-2020, 08:21 PM   #50
aTriz
Drives: 2020 BMW M340i
Post up some pics!
2020 Portimao Blue M340i
      07-20-2020, 01:22 PM   #51
Sheezus
Sheezus's Avatar
Drives: BMW M340i
      08-21-2020, 01:30 PM   #52
jxlhomes
jxlhomes's Avatar
Drives: 2020 G20 M340i
I have 19 squared setup, thinking about swapping out the run flats to ps4s with 235/40 F and 245/40 R, should be fine right?
      08-21-2020, 02:19 PM   #53
OffK
Drives: 2020 m340i Xdrive
Have the same exact setup as Sheezus! Also have 13mm/10mm spacers from Burger
      09-15-2020, 11:43 PM   #54
Auditobimmer42
Drives: M340i
Curious if you ended up doing this, and if so, did it work out well?
I have the 19 squared setup with the skinny 225/40s and was thinking about bumping it up to 235 or 245 all around or 235/40 front and 245/40 rear.
      09-26-2020, 07:29 PM   #55
Kbpolaris
Drives: Audi S4 B9
If you order the non RFT summer tires with the M340 xdrive do you get the staggered setup with the Michelin PS4S tires?
      09-27-2020, 06:16 AM   #56
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
My '20 M340 Xdrive came with Pirelli PZero RFT:
• Front: 225/40 R19.
• Rear: 255/35 R19
I intend to replace with same sized non-RFT Michelin A/S 3+ (or 4+)
This non-square setup seems to working quite well
Al
Retired: 2014 328i
BMW CCA
      09-28-2020, 02:32 PM   #57
althafazh
Drives: 2013 F30 335i Xdrive
2013 bmw 335i  [0.00]
anybody running 225/45r19 squared ? current 225/40s getting bumps
      10-29-2020, 12:12 PM   #58
JoCamp
Drives: 2020 BMW M340i xDrive
Originally Posted by BarryB View Post
They are 8" wide from the stock 225 run flats for sure.
I wanted less gap so a taller tire helps with that and better for potholes.
I purchased 2 8.5" rims for the rear and have 265/35 on there.
Pics once I get home and pick up from the dealer.
HI Barry, sorry for quoting an old post but you've had those tires for about a year now. Any rubbing with those 40 series tires? I'm getting the same setup as you. Thanks
      10-29-2020, 03:25 PM   #59
JTYAMSHAYIN
JTYAMSHAYIN's Avatar
Drives: BMW 330i
Have the thin 225s squared runflats but wanting to replace for a bit better handling and hold onto the runflats for the lease return. I put on the Michelin PS4S on my f30 and was really happy with them.
So for the G20 I'm wondering if i should do a staggered 225/40 front and 255/35 rear like i had on my f30 or if I should do a squared set up. Any tips from those of you who like to take your car on some fun drives?
      10-30-2020, 10:14 AM   #60
BarryB
BarryB's Avatar
Drives: 30Jahre M5 plus a few more M's
Zero rubbing and feels and looks way better.
Use the exact sizes I did as there are no issues with AWD
Current non-BMW's
20 Jeep Grand Cherokee
03 Cooper S (Maxi Tuned 50bhp)
60 Impala (43k orig mi)
15 Turbo S (Kobb tune and Kline exhaust)
      11-02-2020, 10:58 PM   #61
BarryB
BarryB's Avatar
Correct, I have those on my stock front 8" rims with no issues.
No issues with rubbing even at full lock? You mind posting some pics so we can see how the 245s look on the 8" wheel?
I posted pics on the thread a while back. Would have to go digging in my phone to find. See if you can find that thread.
Zero rub until I added spacers. They will rub a little with 12mm up front.
Current non-BMW's
      11-03-2020, 09:40 AM   #62
enginediver
enginediver's Avatar
Drives: Mexico Blue 2018 F80
And Barry...is your car on stock suspension? I pulled the trigger on the 245s and I already bought some 13mm spacers... Was the rubbing while turning?
      11-03-2020, 12:08 PM   #63
JTYAMSHAYIN
Drives: BMW 330i
Are you happy with the 235/40 squared? Im leasing so really don't want to buy a set of rear wheels just to do the 255. Trying to see if I should do 225 squared or if 235/40 might be the answer
      11-14-2020, 03:30 PM   #64
BarryB
BarryB's Avatar
Rubbing only on full lock in reverse
Current non-BMW's
      11-20-2020, 04:05 PM   #65
enginediver
Finally all done! Just put 13mm spacers on all 4. Also, running 245/40/19. I'll see in a few days if it rubs too much.
      11-20-2020, 05:23 PM   #66
JTYAMSHAYIN
Drives: BMW 330i
What size were your rims?
