Technical Topics Wheels and Tires G20 Winter wheel and tire thread - post your setup!
      11-12-2019, 02:29 PM   #45
Delta5
Drives: 2020 M340i, 2018 X3 30i
First drive on the SottoZero3's in actual winter conditions and I'm extremely impressed. They're not foolproof, but the grip and control on ice and (light) snow is quite impressive. My first time on winter rubber, I wasn't sure what to expect. Wow, I'm a convert.
No issues getting around with RWD. Even small snowy/icy hills that appeared to be challenging for other cars and SUV's (all four wheels spinning) was not a problem for me.
Also very impressed at how quiet and composed the tires are on a very cold, 5-degree (F) morning.
      11-12-2019, 03:11 PM   #46
MassBimmer
MassBimmer's Avatar
Drives: 2023 i4 M50
2009 BMW  [9.24]
Is everyone going with the staggered setup for the OEM option? I'm thinking thinner wheels are better for snow traction. Even with xDrive I'm not sure I want a 255 tire out back.
      11-12-2019, 09:01 PM   #47
TheObviousChild
TheObviousChild's Avatar
323
Drives: '23 M3 Comp xDrive - '21 X3M40
Just delivered. 19" Enkei Tuning Raijins w/ Sotozero's
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i
      11-12-2019, 10:17 PM   #48
WXdrivefun
WXdrivefun's Avatar
Drives: G20 330Xdrive
I have OEM staggered setup with 791M bi-colour wheels went with 19" Pirelli Sottozero 3 Non-Runflats.
We just had our first winter downfall yesterday and although not perfect, definitely helps with braking and accelerating. Still slips and slides, but better than All-seasons, drive with caution guys!
I can't tell if there is any difference in driving when downsizing to 18". Any feedback on these Pirelli Sottozero 3 tires compared to Nokian Hakkapeliitta R3 or Michelin Pilot Alpin PA4?
      11-12-2019, 11:12 PM   #49
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
They are really great tires in any cold conditions. Usually you have to decide on dry/wet vs snow/ice but they excel at quite a wide range of conditions and are quiet and comfortable too. I think I like them better than the Michelin PA4 which I've had on 3 previous BMWs.
      11-13-2019, 04:27 PM   #50
Burrcold
Drives: 2024 M3 Comp xDrive
Originally Posted by Burrcold View Post
I ended up getting a set of OEM replicas (with BMW center caps) in satin matte black. 19x8.5 225/40/19 square set up that will clear the ZTK brakes. I went with you my tried and true Pilot PA4's. I love those tires and didn't want to make a mistake.
Here are the wheels I got.
I decided to change my order based on Transfer post (225 vs 235). The wheels I got are 8.5 and I think 225 would have been such a stretch, so I went with 235/40/19 (approximately 1.4% height delta vs the 225). Stuck with the Pilot PA4's though they were much harder to source in 235.
They are being mounted on this replica 791 rim:
Transfer5254.00
      11-13-2019, 08:42 PM   #51
g20beam
g20beam's Avatar
Drives: G20 330i M Sport
2019 BMW  [0.00]
Hi, so I have a G20 and I found a set of Pirelli Sottozero that are 245/50/r18, which were originally on an X3. I’m trying to figure out if they will fit? Or will it be too big for the G20?
      11-14-2019, 10:10 AM   #52
remmib
General
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
I'd say too big. It's 6.44% bigger.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      11-14-2019, 11:19 AM   #53
Full Court Press
Drives: 2020 M340
BMW recently issued 2019-20 cold weather wheels and tires catalog.
      11-14-2019, 03:26 PM   #54
scorpion53
Drives: 135, M235, 328X, 330x, m340x
square or staggered setup?
Originally Posted by Transfer View Post
Ok the winter season is fast approaching so let's use this thread to document how to go about winter mode on the G20. Hopefully this helps people figure out what fits. Post your setup!
I just installed my kit and I think it is FANTASTIC. Highly recommended for a performance OEM look. I bought via Tire Rack for a little under $2k pre-tax including TPMS. Installed without any issues, perfectly balanced, and tires seem to handle quite well even in today's dry 60F weather here. I live up a bunch of hills and drive in typical cold wet conditions with occasional snow and will also do some trips into the mountains. My car is an xDrive.
MSW (OZ) Type 73 wheels, 5x112
Centerbore 72.6(?) Hub center rings included for BMW 66.6, fits snug
19 x 8 ET30 square setup
Wheel bolts included look like a slightly larger cone seat than OEM bolts so I used them (although they're silver)
BMW center caps fit perfectly
Pirelli Sottozero 3 performance winter tires
Size 235/40/19 (1.2% taller than OEM square setup)
This setup compared to OEM by the numbers pushes toward outer fender by 2 mm in the front and sits at the fender the same in the rear although looks like a couple mm pushed out.
Bolt torque 103 ft-lb
Tire pressure 38 PSI all around
The pics...
OEM summer 792M with staggered PS4S:
Winter mode
OEM strut clearance
Winter set strut clearance
Close ups
Fender aspect
I'm pleased to confirm that the OEM 18" 796M set will indeed fit a M340i with the HP Tire & Cooling (ZTK) package.
Ordred them from my dealer. Took 4 business days to arrive. $2,4xx out the door, including dealer installation and storing the off-season tires. I've only driven on them for about 25 miles, but the ride quality is improved. Especially with temps in the 50's today, the P4S's were getting hard. Less crashy over bumps, and feels just as responsive in normal driving. Smooth and quiet at 75+. I'm very happy with the results.
Before (yesterday), 19" 792M with Summer Michelin PS4S...
Front...
After, 18" 796M with Pirelli Sottozero...
Front rotors don't look much different than with the 19's. Calipers are close but they're no tighter than with the 792M's.
This is awesome! Did you go with a square setup 225/45/18? or the staggered setup that is offered on BMW's site? Can't see the rear size.
      11-17-2019, 06:39 AM   #55
bmw_md
Drives: 2020 BMW m340iX
I ticked the box to add TPMS to my Tire Rack order but I don't know what they are. I'm assuming they are not BMW OEM and they work just fine.
Did you have to do anything to program it? or just perform a reset?
      11-17-2019, 06:46 AM   #56
bmw_md
2020 BMW m340 xDrive
I don't intend on using the car much in the winter.
Front 225/40-19 - kumho wintercraft wp72
Rear 255/35-19 - kumho wintercraft wp72
Wheels Front FastWheels FC04 8.5" +35
Wheels Rear FastWheels FC04 9.5" +35
Aftermarket TPMS (Take note there is two version of TPMS for G20 depending on your production date. I found out the hard way)
The shop did 10 or 12 cars of the G20 model (mostly 2019), had no issue, with mine the shop had to re-install an updated version (gen2) of the aftermarket TPMS.
I was expecting to RUN into issue with TMPS, and i did (but its solved)
      11-17-2019, 09:47 AM   #57
Delta5
Staggered. Ordered via my dealer SA from BMW.
796M package;
225/45 on 7.5x18 front.
255/40 on 8.5x18 rear.
FWIW, Stock 792M setup is
225/40 on 8x19 front
255/35 on 8.5x19 rear.
      11-17-2019, 12:56 PM   #58
Transfer
Transfer's Avatar
5254
Just did a standard reset. Your kit looks great!
      11-18-2019, 02:45 PM   #59
CrownRoyal79
CrownRoyal79's Avatar
Drives: BMW 435i
Summer Setup: 20" 794M wheels with Pirelli P Zero PZ4 R-F tires in 225/35R-20 (front), 255/30R-20 (rear). The performance is really good on dry roads. With the Adaptive suspension, the ride is harsh in comfort mode and very harsh in sport modes.
Winter Setup: 19" 791M wheels with Pirelli Sottozero 3 R-F tires in 225/40R-19 (front), 255/35R-19 (rear).
I was immediately shocked by how much smoother the ride is. In sport modes, the car now rides noticeably smoother than my summer setup does in comfort mode! I know it's a combination of the higher profile tires and the softer rubber of the winter tires but I'm not sure which one is having the greatest effect. I haven't had a chance to test the performance of the winter tires yet but for now I'm enjoying the smooth ride.
      12-15-2019, 10:48 AM   #60
MassBimmer
MassBimmer's Avatar
Drives: 2023 i4 M50
2009 BMW  [9.24]
Another OEM set up, just think these wheels suit the car so well! Huge thanks to Evan@Tischer and Jason@Tischer for this beautiful set up. I've shopped with them for over a decade and won't buy OEM parts anywhere else!
Transfer5254.00
WWM3968.00
      12-16-2019, 02:18 AM   #61
luckyfrederic
Drives: BMW G20
Here is my modest contribution.
Initially I did not expect to take a winter kit (no more money )
But finally I found these nice and not very expensive rims.
Summer :
Winter :
It's not bad for my little G20
Rims Alkatec 8x18 ET30 and tire Nankang Snow SV3 225/45/18 with TPMS.
A6bullet337.00
      12-16-2019, 03:02 PM   #62
Evan@Tischer
Evan@Tischer's Avatar
3352
Drives: Online Parts Sales
Thank you!! Love the black on blue!!
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts!
      12-20-2019, 07:33 AM   #63
MPCZ
Drives: BMW 3 G20 Verde Mantis
Summer set-up:
Wheels: Style 795M 20''- Ferric Grey Gloss Milled (Bi Color)
Tires: Pirelli P-Zero PZ4 RFT
Tire Sizes: Front: 225/35R20 90Y XL | Rear: 255/30R20 92Y XL
Winter set-up:
Wheels: Style 791M 19" - Jet Black/Polished front
Tires: Continental WinterContact TS 860S FR, XL, SSR
Tire Sizes: 225/40 R 19 93V | 255/35 R 19 96V
I might sound ridiculous, but with adaptive suspension I consider the grip and comfort on quite high level, the ride is not bumpy at all.
      12-21-2019, 10:16 PM   #64
Burrcold
And installed...
Transfer5254.00
      12-27-2019, 04:43 PM   #65
Prissy
Prissy's Avatar
Taiwan
1069
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
2010 BMW E92  [10.00]
19" staggered OEM wheels
Cinturato P7 All Season Run Flat 225F/255R
With 10mm F/13mm R spacers.
      12-28-2019, 05:39 PM   #66
Orenco
Drives: BMW M340i
Winter Setup by Tirerack shown in photo:
18" x 8" OZ MSW 73 Wheels
225/45R18 Michelin X-Ice tires
Summer Setup:
19" BMW 791M Wheels
Goodyear Eagle F1 tires
Front 225/40R19
Rear 255/35R19
