Technical Topics DIYs and Coding Discussions Your BMW Might Have A Hidden TESLA Mode?
      05-25-2020, 02:22 AM   #67
rockhach
rockhach's Avatar
12
Drives: Bmw 330i g20
Originally Posted by Basti@G20 320D View Post
You cannot use Bimmercode to code it.
Yes you can... I just coded assisted driving view this morning on my G20 April 2019 build. You need to sign up as a beta tester and go into expert mode.
      05-25-2020, 08:42 PM   #68
mlavio829
Drives: 2020 BMW 330i X Drive
Enabling Lane change assistant with BimmerCode would be awesome.
Anyone figure out how to do this?
      06-02-2020, 09:43 AM   #69
RoboPapa
Drives: BMW
Hi ,
I have not attempted this yet. I was going to use E-Sys. I would like to enable Assisted Driving View but no one until now has confirmed if it is possible on a pre-July 2019 build. My 330i is also an April 2019 build.
Please advise whether you are using BimmerCode IOS or Android and the version number that you had success with. Can anyone sign up as a beta tester?
Have you had any luck with Lane Change Assist?
      06-02-2020, 10:00 AM   #70
jk1112
Drives: 2019 BMW 330i
Originally Posted by RoboPapa View Post
Hi ,
My car is a 11/2018 build and lane change as well as driving assist view coded with no issues using esys
      06-03-2020, 11:16 AM   #71
digitallust
digitallust's Avatar
Drives: 2019 G20 BMW 330i M-Sport
Hi ,
I used BimmerCode iOS app straight from the App Store (non beta) with uniscan OBD2 and worked a treat on my April 19 build
__________________________________________________
On Order - 2022 BMW i4 eDrive40 M Sport Mineral White, Fully Optioned
Current - 2019 BMW G20 330i M Sport Alpine White
Retired - 2018 - Range Rover Velar SE D240
Retired - 2015 - Mercedes Benz C250d AMG Line W205
      06-03-2020, 05:10 PM   #72
RoboPapa
Drives: BMW
Were you able to code Assisted Driving View and Lane Change Assist with BimmerCode?
If so can you advise where you find the settings in BimmerCode?
      06-04-2020, 01:22 AM   #73
Basti@G20 320D
Basti@G20 320D's Avatar
Sweden
25
Drives: E30, E36, E46, F30, G20
You CANNOT use Bimmercode to enable lane change becoz there is missing 1 module SAS1 (i think) i wrote to Bimmercode and got the answer that its not possible now and maybe never.
      06-04-2020, 01:04 PM   #74
dwlc1983
Drives: 2020 330xi
It's disappointing - I found the modules in HGU and BDC for lane change assist, which are now both switched to active. It shows up as an option (which is showing checked/active on the HU) but it is not functioning. Hopefully it gets worked out to be code-able with Bimmercode (as I believe ESYS is able to do it without issues).
      06-30-2020, 04:51 PM   #75
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Marcelo_BSB ,
As I posted some time ago, I coded your great discovery and have had both Driver Assist view on the instrument panel and Lane Change Assist working terrifically, UNTIL about a week ago. Now, Driver Assist View continues to work like a champ, BUT Lane Change Assist has stopped working. I have it checked on the iDrive menu.
Any ideas?
Thanks
Al
Retired: 2014 328i
BMW CCA
      06-30-2020, 06:09 PM   #76
Marcelo_BSB
Drives: 328
Marcelo_BSB ,
Any ideas?
Thanks
My lane assist never worked.
      07-01-2020, 09:44 AM   #77
jk1112
Marcelo_BSB ,
Any ideas?
Thanks
Your car didn't get a remote software update did it? I had to re-code certain stuff after my OTA update to 11/2019 recently.
I'd make sure SPURWECHSEL_ASSISTENT in BDC is still active as well as C_SWA_Vorhanden set to nr001 in SAS.
      07-01-2020, 09:56 AM   #78
phayze
Drives: BMW
Will the lane change assist work if only code SPURWECHSEL_ASSISTENT to active?
      07-01-2020, 02:13 PM   #79
RSnic
RSnic's Avatar
jk1112 ,
While I've read that remote updates are being rolled out in a bigger way, even here in US, as best I can tell my car has not received a remote update
Great suggestions; will get out my laptop & check those functions out
Thanks
UPDATE: Lane Change Assist is working fine. Apparently, there are three modes & I somehow got into the incorrect mode -- all I did was tap mode switch & all was well DUH!!
Al
Retired: 2014 328i
BMW CCA
      07-06-2020, 07:14 AM   #80
alackofspeed
Drives: G21
What software and launcher versions are people using to make this change please?
I've got e-sys 3.27.1, pro launcher V2.82.2.162b and v.4.24.12_PSdZData_Lite.
It seems my setup isn't mapping the CAFD data, so searching for the relevant settings isn't working.
All assistance is most welcome. Thanks.
      07-14-2020, 06:51 PM   #81
phillyd2
Drives: 2020 M340i XDrive
Originally Posted by oln08 View Post
Yes you can code the "Driver Assistant View" using bimmercode, I just did this today and worked perfectly.
This is courtesy of zachart. I just posted his instruction here for me because I don't know how to link this to his thread.
QUOTE by zachart
- go into Expert Mode in KOMBI ECU
- search for each parameter (there is a search box)
- change
- Code
CB_FZG_UMGEBUNG_FAS: aktiv (01)
CB_PRESELECT_NAVI_ANSICHT_FZG_UMGEBUNG: aktiv (01)
PIA_FZG_UMGEBUNG_FAS: aktiv (01)
SICHT_ABSICHT_ENABLE: aktiv (01)
This is the guide I followed - I didn't have a PIA_FZG parameter so I only changed the three things and it still works for me.
Same as his situation, I did not see the PIA_FZG also, so I skipped that and still worked for me.
Now just waiting for anybody to figure out how to code "Lane Change Assist" using bimmercode.
I just looked at Bimmercode Beta for iOS and did not see KOMBI ECU. I then looked through all the expert modes for all of the modules and didn't see it anywhere.
Where did you find KOMBI ECU and what exactly did you code?
      07-14-2020, 08:05 PM   #82
oln08
Drives: '19 M2
QUOTE by zachart
- change
- Code
In android, Kombi (dkombi) is under "instrument cluster" then press the expert mode. Using the search, type in all items that are listed above.
phillyd2218.00
      07-15-2020, 06:15 AM   #83
phillyd2
Ah, I completely misunderstood. I was looking for KOMBI under "instrument cluster" but I just realized that "instrument cluster" IS KOMBI and in expert mode I needed to swipe down to see the Search Box. Anyways, all worked so thank you very much.
      07-20-2020, 08:15 PM   #84
phillyd2
Update - it works and is very cool.
      07-21-2020, 04:44 AM   #85
azka
Drives: BMW 330e Sedan
I am looking to buy the new 3-series, and i really want the Driver Assistant Professional. I see some of the cars have the equipment-code "Preparation for Driver Assistance", does that mean i can upgrade to Driver Assistant Professional? I've been trying to find information about this everywhere but noone seems to know, not even the BMW salesman i talked to at my dealership.
      08-04-2020, 05:32 AM   #86
RoboPapa
Drives: BMW
Anyone re-coded Lane Change Assistant after 11/2019.70 OTA Update?
Of the three sections that need coding, the following section was no longer available!
SAS2 > CAFD_42C1 > C_SWA_VORHANDEN
Default: Nr000_nicht_vorhanden
Change to: NR001_VORHANDEN
I coded the other two sections and Lane Change Assistant seems to be available now.
Anyone have the same experience?
      08-04-2020, 06:40 AM   #87
del82
Drives: BMW M340i xdrive
Not sure it is possible. There are quite a lot of hardware differences between driver assistance and driver assistance pro.
- radar in front bumper
- radar in rear for blind spot monitoring
- I think the camera in the windscreen is different
I think it can be coded but the lane change assist doesn't work. Happy to be corrected on this because I know it's been discussed in the forum.
Current: 2020 M340i
Past: M140i, Z4 35is
      08-04-2020, 07:14 AM   #88
phayze
Drives: BMW
What did u use to code? I am looking to code using bimmercode but it does not have access to SAS2 in expert coding.
