Technical Topics DIYs and Coding Discussions Your BMW Might Have A Hidden TESLA Mode?
      08-04-2020, 12:59 PM   #89
RoboPapa
Drives: BMW
Originally Posted by phayze View Post
What did u use to code? I am looking to code using bimmercode but it does not have access to SAS2 in expert coding.
I used E-Sys 3.34 and Launcher 3.70 and v.4.24.21_PSdZData_Lite.
SAS2 does not seem to be available to code when I attempted it.
I did it previously without any problem but I was on 11/2019.41 then and now I’m on 11/2019.70 after OTA Update which removed coding for Lane Change Assistant.
So now I can select Lane Change Assistant (tick box) but it does not work. Presumably need to code SAS2 with the above value but I can’t as it’s not there.
      08-04-2020, 04:40 PM   #90
rickkap
Drives: 320d XDrive M Sport (G20)
Have you tried PSdZData_Lite v4.23.21? I used this after the update and it allowed me to switch LCA back on.
      08-04-2020, 05:05 PM   #91
RoboPapa
Drives: BMW
Thanks for the tip.
As I am on I-Step 11/2019.70, is it ok to use PSdZData_Lite v4.23.12 and not the latest?
      08-04-2020, 06:14 PM   #92
rickkap
I'm on the same 11/2019.70 and it worked for me and i'm UK base. Give it a try and see if SAS2 is there
      08-04-2020, 10:34 PM   #93
phayze
Drives: BMW
Are you able to get lane change assist to work without coding the SAS2 part?
      08-05-2020, 12:59 AM   #94
RoboPapa
Drives: BMW
No, it doesn’t work even though it appears in the Driving menu and is selected.
I will try using PSdZData_Lite v4.23.12 later today as rickkap suggested and report back on what happens.
Have tried PSdZData_Lite v4.23.12 but still no SAS2 section in the 'Tree Of Modules'.
      08-05-2020, 09:25 AM   #95
RoboPapa
Drives: BMW
Ok. Fundamental error on my part and a solution.
Without engine started and running, only 9 ECU modules are discovered.
With engine running, 30 ECU modules discovered including SAS2.
So Lane Change Assistant now coded and working properly again at last.
Thanks to all for your suggestions.
      08-05-2020, 09:47 AM   #96
phayze
Drives: BMW
Check with you, do you code with engine running or in diagnostics mode without engine running when you use esys?
      08-05-2020, 11:15 AM   #97
RoboPapa
Drives: BMW
Code with E-Sys with engine running and not in diagnostic mode.
      08-05-2020, 01:37 PM   #98
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
RoboPapa & phayze ,
As opposed to no engine running, but in diagnostic mode for Bimmercode
Al
Retired: 2014 328i
BMW CCA
      08-05-2020, 08:16 PM   #99
rickkap
Which PSdZData_Lite version did you use?
      08-05-2020, 11:19 PM   #100
phayze
Drives: BMW
Are we suppose to code with engine running or in diagnostic mode?
Or engine running or not need to depend on what software we use?
RoboPapa & phayze ,
      08-06-2020, 02:01 AM   #101
RoboPapa
Drives: BMW
I used PSdZData_Lite v4.23.12 which has the specific data for I-STEP 11/2019.70.
The engine must be running in order to pick up all the ECU modules.
      08-06-2020, 05:29 AM   #102
RSnic
RSnic's Avatar
phayze,
Engine running with E-Sys or Diagnostic mode with Bimmercode
Sorry for confusion
Al
Retired: 2014 328i
BMW CCA
      09-05-2020, 07:23 PM   #103
G20NZ
Drives: 2010 135i
Wondering if anyone can help, I recently coded in the driving assistance view and sport plus into my 2019 G20 using bimmercode and it works great however I noticed that the sport display in my HUD no longer appears when in Sport mode. I've got it set to turn on when in sport mode in the HUD setting but nothing happens. When I set it to 'always on' it works fine however. Any help would be appreciated
      09-06-2020, 01:05 AM   #104
ifr
ifr's Avatar
1198
Drives: Tesla MY LR AWD
RoboPapa & phayze ,
There is no single answer for this, but for esys coding the gold standard is diag mode with a voltage regulator connected.
Never code DME ECU with the engine running.
SAS etc won't appear except in diagnostic mode/engine running
VIP2 cannot be coded on later I-step except in diag mode
So the best approach is diag mode but then there is increased risk of battery drain and shutoff hence using the voltage regulator/battery charger to be minimise risk.
      09-06-2020, 03:20 AM   #105
fdopperen
Netherlands
Drives: 3serie / G21 / 330i
today i trie to change lane assist. not working for me
see only numbers not description
the tesla mode i have it from factory but lane change i can't find the files.
      09-06-2020, 01:46 PM   #106
Chappati21
Chappati21's Avatar
France
Drives: BMW M340ix Touring (G21)
Just FYI, I've just seen this news:
BMW Driving Assistant Professional gets additional functions
https://www.bmwblog.com/2020/05/27/b...-professional/
      09-07-2020, 02:25 AM   #107
mij
Germany
Drives: BMW 330e
Those features went live with 07/20 cars and software, so my car for example had all of the features mentioned (except automatic lane change because of German law) from the factory.
      09-09-2020, 02:31 AM   #108
fdopperen
Netherlands
my g21 is update last week with latest software
also android auto but no lane change assist.
i order a usb c network adapter and enet cable i had alreaddy
and i can see every module but can't find the files to active
for lane change assist.
is it possible with bimmercode ?
      09-09-2020, 05:49 AM   #109
fdopperen
Netherlands
today i trie again with bimmercode but can't find it.
22-07-2019 is date from the car manufactory
      09-10-2020, 05:00 AM   #110
G20NZ
Drives: 2010 135i
Nope lane change assist can't be coded in via bimmercode.
